ios app is sucking
psyrob
ios app is sucking
Post by psyrob »
My ios app has not worked for months. Months. I have deleted it, reloaded it, reinstalled my code, made sure ip address is correct, and my port is definitely open. Why wont this freaking thing work? I load my name from the forums, add the ip address and the port and do not enter my username or password into the app. All this info allows me to access my controller from the portal, but not from the ios app. Why not?
My code:
    ReefAngel.AddHumidityExpansion();  // Humidity Expanion Module
    ReefAngel.FeedingModePorts = Port1Bit;
    ReefAngel.WaterChangePorts = Port1Bit;
    ReefAngel.LightsOnPorts = Port2Bit | Port3Bit | Port4Bit;
    ReefAngel.OverheatShutoffPorts = Port2Bit | Port3Bit | Port4Bit | Port7Bit;
    ReefAngel.ActinicLights( Port2 );
    ReefAngel.DayLights( Port3 );
    ReefAngel.DayLights( Port4 );
    ReefAngel.SingleATOLow( Port5 );
    ReefAngel.StandardFan( Port8 );
    ReefAngel.Portal( "psyrob" );
    ReefAngel.DDNS( "psyrob-controller1.myreefangel.com" ); // Your DDNS is psyrob-99.90.0.55.myreefangel.com
Re: ios app is sucking
Are you sure you are using the correct ip address?
Is it the internal or external ip address that you are using?
Are you sure that your port forwarding is setup correctly?
Assuming there is nothing wrong with your port forwarding or connection to the controller, it should work.
Have you tried the web based uapp?
http://forum.reefangel.com/uapp
Create a shortcut to your home screen.
I will work just like native ios app.
psyrob
Post by psyrob »
the uapp doesn't work either. I can connect thru the portal, and I am using the same ip address in the portal that I am in my iphone app and the uapp. The portal connects, but both my iphone app and the uapp keep saying, "Unable to process controller data". I am using the external ip address. and my port is forwarded and it is open
did you enter anything on cloud username and cloud password?
You must leave those empty.
If you did, try deleting the profile and creating another one.
psyrob
Post by psyrob »
I did not enter anything in the cloud settings. Are you sure I have it coded correctly at the end of my code, the DDNS line?
No. remove that line.
psyrob
Post by psyrob »
I removed the line, uploaded the code again. The iphone app connected once and I had all data and labels, then in five minutes I tried to refresh and it keeps saying "unable to process controller data" and all fields are zeros. Same with web uapp. The portal still works, although it shows that I have 8 expansion boxes and lots of LED lights but I don't have any of that
