WIFI Cloud and WIFI Attachment on 2 RA plusses
ecam
Re: WIFI Cloud and WIFI Attachment on 2 RA plusses
Post by ecam »
Hey roberto. Can you confirm if you are getting any info from
My new id. EcamFT. This would be under the old wifi not the cloud unit
ecam
Post by ecam »
Thanks for that Roberto... now here is an interesting one. I fixed the original WIFI extender.
When I attach it to the controller it transmit information under ecam but doesn't transmit when I change the forum name to ecamFT. I'm probably going to change the name on the cloud wifi...
but wanted to know if there is some code embedded in the wifi module itself that holds on to my user name.
Also even if I upload code with ecamFT in the code. the module still transmits it under ecam.
Hope this makes sense
I'm about to start working on the cloud wifi next.. hopefully we can put this thread to rest....
Again thanks for all the help
Which one are you talking about?
Regular wifi only uses information from RA.
Could wifi uses information from RA and attachment itself.
ecam
Post by ecam »
The regular WIFI... I fixed it and placed it on my second controller. the one that I named ecamFT.
this will only work if I keep the name ecam. If I change it to ecamFT it doesn't matter and will not feed any data. it will only transmit under ecam.
Either way... I can control the second controller with the old wifi... I am happy...
now I will focus on getting the cloud wifi working. Only catch with that is that I have to use the ecamFT to make that work..... So here goes nothing... Get the popcorn ready!!!!!
ecamFT
Post by ecamFT »
Okay here is the new code generated and uploaded from the web wizard. this was done as ecamFT But there is still no data being relayed to the server (still getting Connected but 0.0) and my cloud link is blinking cyan. Whats next boss
    ReefAngel.AddStandardMenu();  // Add Standard Menu
    ReefAngel.AddPHExpansion();  // pH Expansion Module
    ReefAngel.FeedingModePorts = Port1Bit | Port6Bit | Port7Bit | Port8Bit;
    ReefAngel.FeedingModePortsE[1] = Port3Bit | Port5Bit;
    ReefAngel.WaterChangePorts = Port1Bit | Port5Bit | Port6Bit | Port7Bit | Port8Bit;
    ReefAngel.WaterChangePortsE[1] = Port2Bit | Port3Bit | Port6Bit | Port7Bit;
    ReefAngel.OverheatShutoffPorts = Port4Bit | Port6Bit | Port7Bit | Port8Bit;
    ReefAngel.OverheatShutoffPortsE[1] = Port1Bit | Port2Bit | Port3Bit | Port6Bit | Port7Bit;
    ReefAngel.LightsOnPortsE[1] = Port1Bit | Port4Bit | Port8Bit;
    ReefAngel.Relay.On( Port3 );
    ReefAngel.Relay.On( Port7 );
    ReefAngel.Relay.On( Box2_Port5 );
    ReefAngel.StandardLights( Box2_Port1,13,30,21,0 );
    ReefAngel.StandardHeater( T1_PROBE,Port1,778,790 );
    ReefAngel.StandardLights( Port2,13,0,22,0 );
    ReefAngel.StandardHeater( T1_PROBE,Box2_Port2,778,0 );
    ReefAngel.Relay.DelayedOn( Box2_Port3,2 );
    ReefAngel.StandardLights( Port4,14,0,20,0 );
    ReefAngel.Relay.Set( Box2_Port4, !ReefAngel.Relay.Status( Port2 ) );
    ReefAngel.SingleATO( true,Port5,900,0 );
    ReefAngel.StandardHeater( T1_PROBE,Box2_Port6,770,0 );
    ReefAngel.CO2Control( Box2_Port7,725,720 );
    ReefAngel.StandardLights( Box2_Port8,13,30,21,30 );
    if ( ReefAngel.Relay.Status( Port6 ) ) ReefAngel.Relay.On( Port7 );
    if ( ReefAngel.Relay.Status( Port6 ) ) ReefAngel.Relay.On( Port8 );
    if ( ReefAngel.Relay.Status( Port6 ) ) ReefAngel.Relay.On( Box1_Port3 );
    if ( ReefAngel.Relay.Status( Port2 ) ) ReefAngel.Relay.Off( Box1_Port4 );
    if ( ReefAngel.HighATO.IsActive() == 1 ) ReefAngel.Relay.Off( Box1_Port3 );
    ReefAngel.CloudPortal();
// RA_STRING1=null
// RA_STRING2=null
// RA_STRING3=null
ecam
Post by ecam »
Bump
There was data right after you posted this.
http://forum.reefangel.com/status/chart ... &filter=t1
Then you did something yesterday that changed
ecamFT
Post by ecamFT »
Roberto. Can you look at the post of my code. I don't know what to do from this point.
From my end portal still says 0. I introduced the code for reef angel cloud and I'm able to upload from webwizard.
But it still not working. What's missing ?
ecamFT
Post by ecamFT »
[quote="rimai"]There was data right after you posted this.
Did this data come from cloud or regular wifi. I was messing around with the user names.
Ecam = is old wifi units. This is working no issues
EcamFT is cloud wifi now. Still no data for me from the cloud uapp
I don't have a way to tell.
It is your head unit that controls it what to send and the server just stores it.
So at some point, you programmed the head unit with the correct username.
It must be wrong now.
Make sure you are logged in with the correct username when uploading your code to your RA. The user logged in when you upload the code is the one that RA will use to send data to the server.
ecamFT
Post by ecamFT »
My WIFI unit is reporting under both ecam and ecamFT. if you notice the only thing that works is the portal.
the cloud is still all zero so i have never connected to it yet with the Cloud WIFI....
How is this possible? the 2nd controller is setup under ecam... How can it be simultaneously reporting under ecam and ecamFT?
Any thoughts... would really like to get this working. or is it not possible to have a Cloud and original WIFI unit working on different units?
Your RA is programmed wrong. It is probably programmed using the same username.
Connect your RA to the USB TTL cable and open Arduino serial monitor.
Wait 5 minutes, it should write something on it.
Paste here.
Do it for both controllers.
ecamFT
Post by ecamFT »
Okay this is my display tank RA_DT
CLOUD:PH:719
GET /status/submitp.aspx?t1=793&t2=0&t3=0&ph=719&id=ecamFT&em=72&em1=0&rem=3&bid=1&key=&ddns=&af=0&sf=0&atohigh=1&atolow=0&r=234&ron=0&roff=255&r1=149&ron1=0&roff1=255&r2=16&ron2=0&roff2=255&sal=335&phe=792
CLOUD:EM:72
CLOUD:REM:3
CLOUD:BID:1
CLOUD:R1:149
CLOUD:ROFF1:255
CLOUD:R2:16
CLOUD:ROFF2:255
CLOUD:ROFF3:255
CLOUD:ROFF4:255
CLOUD:ROFF5:255
CLOUD:ROFF6:255
CLOUD:ROFF7:255
CLOUD:ROFF8:255
CLOUD:R:234
CLOUD:ROFF:255
CLOUD:T1:793
CLOUD:PH:720
CLOUD:SAL:335
CLOUD:PHE:793
CLOUD:PH:721
CLOUD:PHE:794
CLOUD:PH:720
CLOUD:PHE:793
CLOUD:PHE:794
CLOUD:PHE:793
CLOUD:PH:721
CLOUD:PH:720
CLOUD:T1:795
CLOUD:T1:793
CLOUD:PH:721
CLOUD:PH:720
CLOUD:PH:721
CLOUD:PHE:794
CLOUD:PHE:793
CLOUD:PH:720
CLOUD:PHE:794
CLOUD:PH:721
CLOUD:PHE:793
CLOUD:PH:720
CLOUD:PH:721
CLOUD:PH:720
CLOUD:PH:721
CLOUD:PH:720
CLOUD:PH:721
CLOUD:PH:720
CLOUD:PH:721
CLOUD:PH:720
CLOUD:PH:721
CLOUD:PH:722
CLOUD:PH:721
CLOUD:PH:722
CLOUD:PH:724
CLOUD:PH:722
ecam
Post by ecam »
Here id RA_FT
GET /status/submitp.aspx?t1=788&t2=0&t3=0&ph=710&id=ecam&em=0&em1=0&rem=1&bid=1&key=&ddns=&af=0&sf=0&atohigh=0&atolow=0&r=241&ron=0&roff=255&r1=0&ron1=0&roff1=255
ecamFT is setup to be used with cloud wifi attachment and ecam is setup to be used with the standard wifi attachment.
We can say that these 2 are programmed good with this log since they are sending the correct username.
Just make sure you connect the correct attachment on the proper RA head unit.
The ecam unit, should be sending data to portal. Is it the unit you sent back? If it is, I'm afraid it is the corrosion on that unit.
The ecamFT unit should also connect to the portal, which it is.
This log shows it has been sending data just fine: http://forum.reefangel.com/status/chart ... &filter=ph
So, if you are not getting data on uapp, you may have messed up the settings when setting up the unit.
Let's check.
You will need to open the unit.
Connect the cloud wifi attachment with the USB cable to the computer. Not the USB-TTL cable.
Use a micro usb on the side of the unit.
Open serial using the COM port for this cloud wifi attachment.
You should see a bunch of scrambled up data:
GDÚQ…@@HdI•÷LÑ»ëCP@æïTWZµ•FÄTÖ…é`\‰dHŠ`H…Öj¡VpJ…ØõëdJÄÚã…ÌTQÕ÷ß…HµZÄfû`\‹A±`H`HÄ^¥…
This is normal.
Press and hold the "debug" button on the top left corner.
Now press the "reset master" button on the top right corner.
It should print some stuff.
Paste here.
ecamFT
Post by ecamFT »
GDÚQ…@@HdI•÷LÑ»ëCP@æïTWZµ…ÆÄT
you must hold the debug while pressing the master reset, then you can release both
ecamFT
Post by ecamFT »
opened up the serial on Com3 on arduino.... the cloud is attached to computer via mini usb.....
it keeps spittng out the same giberish
It should and then you press debug and master reset and it should print something else.
ecamFT
Post by ecamFT »
When i first open it... it does nothing.......
when i do what you told me to d..... it spits out that first line.... and every sunbsequent press repeats the same line
not decoded at all
Are you holding the debug button down?
ecamFT
Post by ecamFT »
yes.... nothing generates until i press the master reset
so i hold debug... then press master rest (while holding debug) then release and comes up with this stuff... and then keeps repeating
Keep holding debug down, press and release the master reset then release debug.
ecamFT
Post by ecamFT »
GDÚQ…@@HdI•÷LÑ»ëCP@æïTWZµ…FÄT
same thing
ecamFT
Post by ecamFT »
dont know if this matter the light is a solid green color, once i hold debug and then hit reset.....
solid green means it is factory resetting. You must have triggered the factory reset by mistake.
You have to wait a few minutes until it finishes.
It will not do anything until it completes that.
There is no point on checking debug now. Factory reset wiped out whatever you had in there.
When it completes, it will turn into flashing blue.
You will need to set it up again with your phone at that point.
ecamFT
Post by ecamFT »
Error inside Serial.serialEvent()
java.io.IOException: Bad file descriptor in nativeavailable
	at gnu.io.RXTXPort.nativeavailable(Native Method)
	at gnu.io.RXTXPort$SerialInputStream.available(RXTXPort.java:1596)
	at processing.app.Serial.serialEvent(Serial.java:258)
	at gnu.io.RXTXPort.sendEvent(RXTXPort.java:772)
	at gnu.io.RXTXPort.eventLoop(Native Method)
	at gnu.io.RXTXPort$MonitorThread.run(RXTXPort.java:1641)
ecamFT
Post by ecamFT »
roberto
when i connect to reef angel... it starts blink CYAN.....
when i connect it to computer it goes between green and CYAN
when i do your steps.... it goes to solid green... the debug and master reset combo is leaving solid green when i plugged into usb
