// Autogenerated file by RAGen (v1.1.0.127), (01/30/2012 08:34)
// RA_013012_0834.pde
#define DisplayImages
#define DateTimeSetup
#define SIMPLE_MENU
#include <ReefAngel_Wifi.h>
#include <ReefAngel_EEPROM.h>
#include <ReefAngel_ATO.h>
#include <ReefAngel_LED.h>
#include <ReefAngel_Relay.h>
#include <ReefAngel_PWM.h>
#include <ReefAngel_Timer.h>
#include <ReefAngel_Memory.h>
ReefAngel.FeedingModePorts = B00110000;
ReefAngel.WaterChangePorts = B00001111;
ReefAngel.OverheatShutoffPorts = B01000000;
ReefAngel.LightsOnPorts = B10000000;
ReefAngel.Relay.On(Port2);
ReefAngel.Relay.On(Port3);
ReefAngel.Relay.On(Port4);
// Specific functions
ReefAngel.StandardATO(Port1,400);
ReefAngel.Wavemaker1(Port5);
ReefAngel.Wavemaker2(Port6);
ReefAngel.StandardLights(Port8);
Binary sketch size: 29892 bytes (of a 32256 byte maximum)
C:\Program Files\Reef Angel Controller\hardware/tools/avr/bin/avrdude -CC:\Program Files\Reef Angel Controller\hardware/tools/avr/etc/avrdude.conf -v -v -v -v -patmega328p -cstk500v1 -P\\.\COM3 -b115200 -D -Uflash:w:C:\Users\Ashley\AppData\Local\Temp\build5314242479731047581.tmp\sketch_feb05a.cpp.hex:i
avrdude: Version 5.4-arduino, compiled on Oct 11 2007 at 19:12:32
Using Port : \\.\COM3
Using Programmer : stk500v1
Overriding Baud Rate : 115200
avrdude: ser_open(): setting dtr
avrdude: Send: 0 [30] [20]
avrdude: Recv:
avrdude: stk500_getsync(): not in sync: resp=0x00
avrdude: Send: Q [51] [20]
avrdude: Recv:
avrdude: stk500_disable(): protocol error, expect=0x14, resp=0x51
avrdude done. Thank you.
What am I doing wrong?
