Losing my mind
Losing my mind
I purchased a relay expansion module and figured that I would get the PDE setup so that when it gets here I can just drop the PDE in and hook it up and be off and running.
Did some digging around on here to find how to turn it on. (probably missed it) I found a few things that helped but I am still having issues when compiling. I get complaints about the ports not being defined
Any ideas?
// Autogenerated file by RAGen (v1.1.0.126), (01/29/2012 19:29)
// RA_012912_1929.pde
#define DirectTempSensor
#define wifi
#define RelayExp
#define SIMPLE_MENU
#define ENABLE_ATO_LOGGING
#define ENABLE_EXCEED_FLAGS
#include <ReefAngel_Wifi.h>
#include <ReefAngel_EEPROM.h>
#include <ReefAngel_ATO.h>
#include <ReefAngel_LED.h>
#include <ReefAngel_Relay.h>
#include <ReefAngel_PWM.h>
#include <ReefAngel_Timer.h>
#include <ReefAngel_Memory.h>
#include <avr/pgmspace.h>
// Labels for the web banner
prog_char id_label[] PROGMEM = "projectx";
prog_char probe1_label[] PROGMEM = "Water";
prog_char probe2_label[] PROGMEM = "Canopy";
prog_char probe3_label[] PROGMEM = "Not%20Used";
prog_char relay1_label[] PROGMEM = "ATO";
prog_char relay2_label[] PROGMEM = "Daylight";
prog_char relay3_label[] PROGMEM = "Return";
prog_char relay4_label[] PROGMEM = "Acintic";
prog_char relay5_label[] PROGMEM = "Skimmer";
prog_char relay6_label[] PROGMEM = "Heater";
prog_char relay7_label[] PROGMEM = "Dosing1";
prog_char relay8_label[] PROGMEM = "Dosing2";
prog_char relay11_label[] PROGMEM = "MoonLights";
prog_char relay12_label[] PROGMEM = "Sumplight";
prog_char relay13_label[] PROGMEM = "FtKorilia";
prog_char relay14_label[] PROGMEM = "BkKorilia";
prog_char relay15_label[] PROGMEM = "Actinic2";
prog_char relay16_label[] PROGMEM = "Actinic2";
prog_char relay17_label[] PROGMEM = "Not%20Used";
prog_char relay18_label[] PROGMEM = "Not%20Used";
relay3_label, relay4_label, relay5_label, relay6_label, relay7_label, relay8_label, relay11_label, relay12_label,
relay13_label, relay14_label, relay15_label, relay16_label, relay17_label, relay18_label};
// Initialize and start the web banner timer
ReefAngel.Timer[4].SetInterval(120); // set interval to 120 seconds
ReefAngel.Timer[4].Start();
ReefAngel.FeedingModePorts = B00000101;
ReefAngel.WaterChangePorts = B11010101;
ReefAngel.LightsOnPorts = B00001010;
ReefAngel.LightsOnPortsE[0] = B00001100;
ReefAngel.Relay.On(Port3);
ReefAngel.Relay.On(Port5);
ReefAngel.Relay.On(13);
ReefAngel.Relay.On(14);
// Specific functions
ReefAngel.SingleATOLow(Port1);
ReefAngel.StandardLights(11, 21, 0 7, 0);
ReefAngel.StandardLights(12, 7, 0, 20, 0);
ReefAngel.MHLights(Port4);
ReefAngel.MHLights(15);
ReefAngel.MHLights(16);
ReefAngel.StandardHeater(Port6);
ReefAngel.DosingPumpRepeat1(Port7);
ReefAngel.DosingPumpRepeat2(Port8);
// Web Banner stuff
ReefAngel.WebBanner();
Any ideas?
#define wifi
#define RelayExp
#define SIMPLE_MENU
// Web Banner stuff
Re: Losing my mind
DOH!! found it, i was missing the , in the ReefAngel.StandardLights(11, 21, 0 7, 0);
once i rechecked it and added it compiled properly
Re: Losing my mind
Instead of using 11, 12, 13, etc, you can use Box1_Port1, Box1_Port2, Box1_Port3, etc. It can make the code a little easier to read if you wanted. You don't have to, just a suggestion.
Exert from the globals.h file
#define Box0_Port1 Port1
#define Box0_Port2 Port2
#define Box0_Port3 Port3
#define Box0_Port4 Port4
#define Box0_Port5 Port5
#define Box0_Port6 Port6
#define Box0_Port7 Port7
#define Box0_Port8 Port8
#define Box1_Port1 11
#define Box1_Port2 12
#define Box1_Port3 13
#define Box1_Port4 14
#define Box1_Port5 15
#define Box1_Port6 16
#define Box1_Port7 17
#define Box1_Port8 18
Re: Losing my mind
Thanks for the tip. I actually got it all working, I have 2 problems
the 2nd set of relays is not showing on the RA screen
and
on the droid App I am not seeing the 2nd set either, any ideas?
and
Re: Losing my mind
The second relay box will require you to build your own custom screen.
http://forum.reefangel.com/viewtopic.php?f=14&t=109
Re: Losing my mind
Ok thanks, and to get the additional relays in the Droid App? and also on the Wifi screen? or will the custom menu fix all of that?
Re: Losing my mind
The additional relay on the Android app will have to wait.
Curt is working on the app to show the extra relays. I'm anxiously waiting for that update too
Re: Losing my mind
The wifi screen only shows the 1st relay as well. Additional relay support just hasn't been added in everywhere yet. It's being planned and worked on (like Roberto said).
Re: Losing my mind
Ah ok, as long as I know that I am good with it. I can see the 2nd relay box in the client as well as the web banner so as long as there is some viability I am good. Thanks for the fast replies,
Re: Losing my mind
Ok, so I have a new development.
when I put my RA into feeding mode it turns off my 2 acinctic channels (1-5 and 1-6) not the 2 pump channels (1-3 and 1-4)
when the Actinics are to come on one of them does the other doesn't, I swapped the 2 power cords between the outlets and the problem stays with the outlet.
here are the bits of my PDE That I have setup for feeding and for the additional lights.
any ideas?
ReefAngel.FeedingModePortsE[0] = B00110000;
ReefAngel.WaterChangePortsE[0] = B00110000;
ReefAngel.Relay.On(17);
ReefAngel.Relay.On(18);
ReefAngel.StandardLights(11, 21, 0, 7, 0);
ReefAngel.StandardLights(12, 7, 0, 21, 0);
any ideas?
Re: Losing my mind
The binary number starts from the right to left. Confusing I know, but that's the way it is.
So, this leads me to believe that all your assignments are probably reversed too.
Re: Losing my mind
Actually it makes sense, I will update my PDE when i get home tonight
thanks
thanks
Re: Losing my mind
Thanks that did it i reversed all of the expansion module relay ports that I had manually done and now when I do feeding mode the proper channels turn off.
one issue i have is ports 3 and 6 on the relay expansion do not turn on properly unless i power cycle the relay expansion, they show on in the client tool and on my banner. Is this a problem with the expansion or my code?
Re: Losing my mind
Port 3 is supposed to be on all the time, right?
Are you saying that the port turns on and then turn off by itself?
Re: Losing my mind
Correct that port should be on at all times. It seems that it does shut off on its own, i am having the same problem with port 6 too, if i power cycle the entire relay box it seems to bring them back on
Re: Losing my mind
Can you swap your svga cables between main relay box and expansion box to see if it makes any difference?
Re: Losing my mind
Yea, I will do that tomorrow night when I get home. I might have a few of them laying around here from old monitors if that is the problem
Re: Losing my mind
I meant the main relay box and the expansion one.
You may not have luck with the ones you had from old monitors unless they have all 15 wires inside.
Most svga cables don't carry all 15 wires inside to save money.
Re: Losing my mind
I haven't forgot about this, just been slammed with work. It does appear that port 3 is working but port 6 still in order for it to come on I have to power cycle the relay box and then it comes on. I did check to make sure that none of the pins were bent and they were ok.
Re: Losing my mind
#define wifi
#define RelayExp
#define SIMPLE_MENU
prog_char relay17_label[] PROGMEM = "Chiller";
prog_char relay18_label[] PROGMEM = "Phosban";
ReefAngel.FeedingModePortsE[0] = B00001100;
ReefAngel.WaterChangePortsE[0] = B00001100;
ReefAngel.LightsOnPortsE[0] = B00110011;
ReefAngel.StandardLights(11, 21, 0, 10, 0);
// Web Banner stuff
Re: Losing my mind
I don't see anything wrong with the code.
Does the screen on the controller show 13 and 16 green?
Re: Losing my mind
I dont have the screen programmed for the expansion, but the client does show both ports are on. If I pull the power cord out of the expansion, not the main relay box, when i plug it back in the relays will turn on
Re: Losing my mind
Have you tried swapping the cables or swapping the relay boxes?
It seems definitely some hardware issue.
I just wanted to confirm that.
If you swap the relay box and the main relay box starts giving you problems then we know for sure it is the box. Can you do that?
Re: Losing my mind
I can do that, let it run for a few days and see if i start getting odd results
Re: Losing my mind
Swapped the cable, should know tomorrow if it makes a difference or not.
Re: Losing my mind
The swapping of the cable had no impact, I will swap the boxes now and see what happens in the morning
Re: Losing my mind
Ok, finally had some time to do the box swap, the problem follows the box. tried to swap the cable etc, same result,
