New IDE v1.6.8
Re: New IDE v1.6.8
Sorry... :(
No update.
I need to find the new VM for the MacOSX
Re: New IDE v1.6.8
rimai wrote:Sorry... :(
No update.
no worries. I just wanted to ask.
Re: New IDE v1.6.8
No update.
is there something i could do to help out?
Re: New IDE v1.6.8
You can try recompiling the Arduino IDE on your OS :)
https://github.com/reefangel/Arduino
You would need to fork it, merge with the latest release from Arduino team branch. They are already on 1.8.5
Then compile.
The fix for Sierra was released around 1.6.12 and my fork is on 1.6.8
Re: New IDE v1.6.8
rimai wrote:You can try recompiling the Arduino IDE on your OS :)
Then compile.
ok. i’ll look into doing that sometime later this week. might as well let my laptop do something with the background cpu cycles when i’m using a web browser to do my office paperwork.
Re: New IDE v1.6.8
Then compile.
I've got the latest 1.8.6 compiled on my system. Now I have switched over to migrating 1.8.5 release (since 1.8.6 isn't finalized yet) into the reefangel branch and will be getting that to compile. I'm done working on it tonight, so I'll be working on it more in the next few days. I just have to make sure that the changes are maintained in your branch and that I follow along with the new changes that were made to the environment. Anyways, I should have a working build of the RA Arduino this weekend and I'll get it to you for you to test out and then package up for distribution.
Re: New IDE v1.6.8
When I try and run the wizard or restore default code for example, I see errors like this.
Exception in thread "AWT-EventQueue-0" java.lang.NoSuchMethodError: processing.app.Base.getSketchbookFolder()Ljava/io/File;
	at com.reefangel.tool.Wizard$WizardPreferences.<clinit>(Unknown Source)
	at com.reefangel.tool.Wizard.run(Unknown Source)
	at java.awt.event.InvocationEvent.dispatch(InvocationEvent.java:311)
	at java.awt.EventQueue.dispatchEventImpl(EventQueue.java:756)
	at java.awt.EventQueue.access$500(EventQueue.java:97)
	at java.awt.EventQueue$3.run(EventQueue.java:709)
	at java.awt.EventQueue$3.run(EventQueue.java:703)
	at java.security.AccessController.doPrivileged(Native Method)
	at java.security.ProtectionDomain$JavaSecurityAccessImpl.doIntersectionPrivilege(ProtectionDomain.java:76)
	at java.awt.EventQueue.dispatchEvent(EventQueue.java:726)
	at java.awt.EventDispatchThread.pumpOneEventForFilters(EventDispatchThread.java:201)
	at java.awt.EventDispatchThread.pumpEventsForFilter(EventDispatchThread.java:116)
	at java.awt.EventDispatchThread.pumpEventsForHierarchy(EventDispatchThread.java:105)
	at java.awt.EventDispatchThread.pumpEvents(EventDispatchThread.java:101)
	at java.awt.EventDispatchThread.pumpEvents(EventDispatchThread.java:93)
	at java.awt.EventDispatchThread.run(EventDispatchThread.java:82)
roberto, what did you have to do on the mac to get rid of this error? i’ve got 1.8.5 compiled and running but i get this error with the addon functions and the boards are incorrect.
i have copied the file to the applications to replace the 1.6.8 install but i still get the errors. did you have to add the addon tools to the source folders along with the boards file during the build process? i haven’t had much time to dive into it fully so i figured i would ask you since you have your build process.
Re: New IDE v1.6.8
Re: New IDE v1.6.8
rimai wrote:Try these tools folder.
https://www.dropbox.com/s/0fxyokdsm7s1m ... s.zip?dl=0
The Reef Angel Libraries version works from these tools.
The Restore Preloaded Code and the Wizard do not. This is not a problem for me since I don't use any of them, but it could/would be a problem for others.
I get the same errors when I run the tools:
Exception in thread "AWT-EventQueue-0" java.lang.NoSuchMethodError: processing.app.Sketch.getCode(I)Lprocessing/app/SketchCode;
	at java.security.ProtectionDomain$JavaSecurityAccessImpl.doIntersectionPrivilege(ProtectionDomain.java:80)
Re: New IDE v1.6.8
There might be a change on the Arduino IDE that requires the wizard and preloaded code to be recompiled too.
I have only tested on v1.6.8.
Re: New IDE v1.6.8
rimai wrote:There might be a change on the Arduino IDE that requires the wizard and preloaded code to be recompiled too.
ok. that makes sense. i do think some things changed.
Re: New IDE v1.6.8
Well, there's more that has changed with 1.8.5 (the version that I'm using for a High Sierra build).
It's proving to be a cumbersome (and frustrating) task.
Re: New IDE v1.6.8
Any additional work done on this? I hit a roadblock and haven't gotten past it.
Re: New IDE v1.6.8
Didn't got around doing that yet. :(
Re: New IDE v1.6.8
rimai wrote:Didn't got around doing that yet. :(
no problem. I know you are busy. I just wanted to check up on it.
Re: New IDE v1.6.8
Can you explain a little more of what the problem you are having?
Re: New IDE v1.6.8
rimai wrote:Can you explain a little more of what the problem you are having?
There were some issues with including the correct libraries and dealing with the additional tools. I think there was also an issue with compilations with the latest libraries. I don't recall about the exact compilation problem because i was more focused on the main errors.
here's the additional errors that I had saved. I'll have to double check because I haven't looked at it for a while.
Verify the Libraries check function call.
Invalid libraries:
Invalid library found in /Users/binder/Projects/ra-arduino/build/macosx/work/Arduino.app/Contents/Java/hardware/arduino/avr/libraries/WiFi: /Users/binder/Projects/ra-arduino/build/macosx/work/Arduino.app/Contents/Java/hardware/arduino/avr/libraries/WiFi
Invalid library found in /Users/binder/Projects/ra-arduino/build/macosx/work/Arduino.app/Contents/Java/hardware/arduino/avr/libraries/Ethernet: /Users/binder/Projects/ra-arduino/build/macosx/work/Arduino.app/Contents/Java/hardware/arduino/avr/libraries/Ethernet
Launching "Restore pre-loaded code":
at com.reefangel.tool.RestorePreloaded.run(Unknown Source)
i know that they changed things but I just haven't had the mindset to dive in to how it works...like you already had.
Re: New IDE v1.6.8
when running the wizard, this is the output:
Running the restore preloaded code gives this:
Then compiling against the current dev libraries yields this:
Archiving built core (caching) in: /var/folders/3h/m3xyqrbj57vf3kmyrzy3zn900000gp/T/arduino_cache_671070/core/core_arduino_avr_RAStar_c41a4462a748f55bf51d70a30288e42f.a
Multiple libraries were found for "Ethernet.h"
 Used: /Users/binder/ownCloud/Documents/Arduino/libraries/Ethernet
 Not used: /Users/binder/Projects/ra-arduino/build/macosx/work/Arduino.app/Contents/Java/libraries/Ethernet
libraries/ReefAngel/ReefAngel.cpp.o (symbol from plugin): In function `ReefAngelClass::DisplayMenuHeading()':
(.text+0x0): multiple definition of `__vector_9'
libraries/SoftwareSerial/SoftwareSerial.cpp.o (symbol from plugin):(.text+0x0): first defined here
/Users/binder/Projects/ra-arduino/build/macosx/work/Arduino.app/Contents/Java/hardware/tools/avr/bin/../lib/gcc/avr/4.9.2/../../../../avr/bin/ld: Disabling relaxation: it will not work with multiple definitions
collect2: error: ld returned 1 exit status
exit status 1
Error compiling for board Reef Angel Star Controller.
i know some of these errors are probably simple ones but i'm not that familiar with the ide changes you have made before to get things to compile.
i am definitely willing to work at this more but i need guidance and assistance. :?
Re: New IDE v1.6.8
I don't think you need to run the Restore Preloaded code, right? :)
I never had problem compiling code though.
I'll double check.
Re: New IDE v1.6.8
rimai wrote:I don't think you need to run the Restore Preloaded code, right? :)
you never know. ;-)
I'll double check.
I think the issue lies with extra libraries that are included by default but we don't typically need them. I think I vaguely recall from years past that we had to remove a specific library due to it including something we didn't need...or multiple definitions...or something like that. I'm not positive though.
Re: New IDE v1.6.8
I'll double check.
Ok, here's a follow up. I've got it able to compile code now. The issue was the SoftwareSerial problem from a while ago. I had to track down the old changes and then locate the problem and comment out lines in the source files.
One problem with macOS is you cannot simply replace those built-in files by replacing them in a folder on the hard drive after installation (like we have done in the past on a windows machine). I have to fix the files and then re-build the entire app because they get added to the entire package and compiled/linked in.
I'm progressing along now....just gotta make sure I have the correct bootloader files for the RAStar and others in order to get it to compile and build properly.
Slow progress, but progress.
