Help with ORP
tkeracer619
Help with ORP
Post by tkeracer619 »
Trying to bring my ORP expansion back online. When I first plugged it in everything seemed to be working (not 0) but the probe was jacked up so I ordered a replacement. I had to go out of state and just left the jacked up probe and the ORP module operating.
Now that I am home ORP is reading 0. I assumed it was due to the probe so installed the fresh one. Still 0.
Interestingly enough the graph feature shows data, even though the display and UAPP show 0.
Searching the forum it looks like using the i2c scanner is one of the first steps. Exactly, how do I do this with the Star controller? The RA Arduino program doesn't list the Star.
Also, I have had this module a long time, I don't recall getting a BNC Terminator but it's been so long I can't tell, It was one of the first ones you ever sold... Is this something I can order or is there a specific one I need to order?
Also... Is this ORP probe good? I don't remember what they looked like but recall it looked different than the PH probe...
Thanks for any help!
tkeracer619
Re: Help with ORP
Also, if I short the BNC connector and try to calibrate it reads 0...
tkeracer619
Re: Help with ORP
Nevermind... Just like my Expansion Hub, I decided that even though there was no corrosion or visible ingress to wash the circuit board in rubbing alcohol with a toothbrush. Dried on top of a HVAC vent. Works just fine now... :?
Whatever works I guess :lol:
I need to get some ORP calibration solution. Any recommendations?
Is shorting the BNC an acceptable replacement for the terminator while calibrating?
tkeracer619
Re: Help with ORP
Well... it worked for a week. I guess I need to get a new module.
How do you use the i2c scanner with the star controller?
Is there anything that can be done to troubleshoot it?
Re: Help with ORP
The terminator is nothing more than a short on the center pin and the outer shell of the port.
You can use a paper clip.
To use the i2cscanner, you need to add this to setup() of the i2cscanner code:
  DDRH|=(1<<2); // Port PH2 output (Exp Bus Power)
  cbi(PORTH,2); // Turn on exp bus power
RA+ and RA* have the same microprocessor, so just use RA+ as board.
tkeracer619
Re: Help with ORP
Thanks, the ORP module is connected and actually working.
I put the terminator back on and its reading. I think the new probe is faulty.
