I just got my new RA star and wanted to try a few custom things. I went through the RA star wizard, read through the forum and had a go at the following custom commands.
1. turn off skimmer port if ATO high is active. I want the skimmer off if the water level rises too high - the float switch will be oriented with the wires up/coming out of the top.
2. control port 2 based on temps from T1_PROBE AND T2_PROBE
3. control port 8 based on temps from T3_PROBE
I am wondering if I have missed overriding anything from running the wizard.
Also, do I need to add anything to the code if I am going to connect this to a Netgear EX3700 wifi extender via ethernet cable?
I would really appreciate it if someone can look over the code for me.
Thanks in advance!
Michael.
#include <RA_TS.h>
#include <RA_TouchLCD.h>
#include <RA_TFT.h>
#include <RA_TS.h>
#include <Font.h>
#include <RA_Wiznet5100.h>
#include <SD.h>
#include <SPI.h>
#include <Ethernet.h>
#include <EthernetDHCP.h>
#include <PubSubClient.h>
#include <RA_CustomLabels.h>
#include <SoftwareSerial.h>
ReefAngel.Star();
ReefAngel.AddPHExpansion(); // pH Expansion Module
ReefAngel.FeedingModePortsE[0] = Port1Bit | Port4Bit;
ReefAngel.WaterChangePortsE[0] = Port1Bit | Port4Bit;
ReefAngel.WaterChangePortsE[1] = 0;
ReefAngel.OverheatShutoffPortsE[0] = Port2Bit | Port5Bit | Port6Bit;
InternalMemory.OverheatTemp_write( 275 );
ReefAngel.StandardHeater1( Box1_Port2 );
ReefAngel.StandardFan1( Box1_Port3 );
ReefAngel.Relay.DelayedOn( Box1_Port4 );
ReefAngel.StandardLights( Box1_Port5 );
ReefAngel.StandardLights( Box1_Port6 );
ReefAngel.StandardLights( Box1_Port7 );
ReefAngel.StandardHeater1( Box1_Port8 );
boolean buzzer=false;
if ( ReefAngel.isOverheat() ) buzzer=true;
ReefAngel.Relay.Set(Box1_Port4,!ReefAngel.HighATO.IsActive());
if ReefAngel.Params.Temp[T1_PROBE]<249)) && ReefAngel.Params.Temp[T2_PROBE]<249)) ReefAngel.Relay.On( Box1_Port2 );
if ReefAngel.Params.Temp[T1_PROBE]<253)) && ReefAngel.Params.Temp[T2_PROBE]<253)) ReefAngel.Relay.Off( Box1_Port2 );
if ReefAngel.Params.Temp[T3_PROBE]<249)) ReefAngel.Relay.On( Box1_Port8 );
if ReefAngel.Params.Temp[T3_PROBE]<253)) ReefAngel.Relay.Off( Box1_Port8 );
ReefAngel.Network.Cloud();
// RA_STRING1=U2FsdGVkX18dgbkr0enPhNXrgGcSxpffYBHcyfq7FfY=
// RA_STRING2=null
// RA_STRING3=null
// RA_LABEL LABEL_PORT27=Port 27
// RA_LABEL LABEL_PORT16=LightFrag
// RA_LABEL LABEL_ACTINIC2=Actinic 2
// RA_LABEL LABEL_PORT26=Port 26
// RA_LABEL LABEL_PORT15=LightFrag
// RA_LABEL LABEL_PORT24=Port 24
// RA_LABEL LABEL_PORT28=Port 28
// RA_LABEL LABEL_PORT23=Port 23
// RA_LABEL LABEL_PORT14=Skimmer
// RA_LABEL LABEL_PORT13=Fan
// RA_LABEL LABEL_PORT18=HeatFrag
// RA_LABEL LABEL_PORT22=Port 22
// RA_LABEL LABEL_PORT11=Return
// RA_LABEL LABEL_PORT25=Port 25
// RA_LABEL LABEL_DAYLIGHT2=Daylight 2
// RA_LABEL LABEL_PORT17=LightQT
// RA_LABEL LABEL_PORT21=Port 21
// RA_LABEL LABEL_PORT12=HeatSump
