wifi attachment help
Reefology
Hi,
I recently changed my router and tried to change my ssid and passphrase on the RA+ wifi attachment with no luck. It worked flawlessly for years until I changed my router and now not sure how to proceed.
I followed the wifi setup documentation for all 3 methods and the result is always the same, IP address is 0.0.0.0;2000 and lights are flashing blue and green on the attachment.
can someone please help?
thanks
thanks
Reefology
Re: wifi attachment help
Hi Roberto, no neither ssid or passphrase have a space.
I reset WiFi attachment to factory settings and tried all 3 setup methods and still no luck. What else can I try?
Do you get any response from the module when you use the Tera term method?
Reefology
Can you post the log that you get?
Are you sure you are selecting the correct COM port?
Reefology
im definitely selecting the correct COM port.
not getting any log at all...I don't get the screen shown in step 16 of the wifi manual, screen is blank? not sure what to do?
Reefology
still blinking blue and ip is 0.0.0.0;2000
here is the log I get with WiFi utility:
Opening Serial Port...
Verifying speed at 9600 baud
Connected to serial port /dev/tty.usbserial-A402NUWP
> set u b 57600
> set s p 0
> save
> reboot
Verifying speed at 57600 baud
Removing connection to /dev/tty.usbserial-A402NUWP
< CMD
> reboot
< reboot
Wifi Attachment Connected to /dev/tty.usbserial-A402NUWP
* Please, enter a SSID
< CMD
> ls
< ls
< FL# SIZ FLAGS
< 2 86328 3 wifly-GSX-400
< 4 74920 3 web_app-GSX-106
< 7 46632 3 wps_app-GSX-131
< 9 66240 3 eap_app-GSX-101
< 11 37282 0 web_config.html
< 21 512 0 link.html
< 24 1052 10 config
< 25 88548 3 wifly-GSX-441-r1057
< 26 88548 3 wifly-GSX-441-r1057
< 27 1052 10 user
< 122 Free, Boot=26, Backup=2
< <4.41>
> load user
< load user
< AOK
< <4.41>
> save
< save
< Storing in config
< <4.41>
> save
< save
< Storing in config
< <4.41>
> set o d ReefAngelWifi
< set o d ReefAngelWifi
< AOK
< <4.41>
> set w l 5
< set w l 5
< AOK
< <4.41>
> set w s Deri
< set w s Deri
< AOK
< <4.41>
> set w p erefre
< set w p erefre
< AOK
< <4.41>
< AOK
< <4.41>
< AOK
< <4.41>
> save
< save
< Storing in config
< <4.41>
> reboot
< reboot
< CMD
> show n
< show n
< SSid=Deri
< Chan=1
< Assoc=FAIL
< Rate=12, 24Mb
< Auth=FAIL
< Mode=NONE
< DHCP=FAIL
< Boot=0
< Time=OK
< Links=0
< <4.41>
> get i
< get i
< IF=DOWN
< DHCP=ON
< IP=0.0.0.0:2000
< NM=255.255.255.0
< GW=0.0.0.0
< HOST=104.36.18.155:80
< PROTO=TCP,
< MTU=1524
< FLAGS=0x6
< TCPMODE=0x0
< BACKUP=0.0.0.0
< <4.41>
> reboot
< reboot
Found router CGN3ACSMR
> set u b 57600
> set s p 0
> save
> reboot
< CMD
> reboot
< reboot
< CMD
> ls
< ls
< FL# SIZ FLAGS
< 24 1052 10 config
< 27 1052 10 user
< <4.41>
> load user
< load user
< AOK
< <4.41>
> save
< save
< Storing in config
< <4.41>
> save
< save
< Storing in config
< <4.41>
< AOK
< <4.41>
> set w l 5
< set w l 5
< AOK
< <4.41>
> set w s Deri
< set w s Deri
< AOK
< <4.41>
> set w p erefre
< set w p erefre
< AOK
< <4.41>
< AOK
< <4.41>
< AOK
< <4.41>
> save
< save
< Storing in config
< <4.41>
> reboot
< reboot
< CMD
> show n
< show n
< SSid=Deri
< Chan=1
< Assoc=FAIL
< Rate=12, 24Mb
< Auth=FAIL
< Mode=NONE
< DHCP=FAIL
< Boot=0
< Time=OK
< Links=0
< <4.41>
> get i
< get i
< IF=DOWN
< DHCP=ON
< IP=0.0.0.0:2000
< NM=255.255.255.0
< GW=0.0.0.0
< PROTO=TCP,
< MTU=1524
< FLAGS=0x6
< TCPMODE=0x0
< BACKUP=0.0.0.0
< <4.41>
> reboot
< reboot
Can you make sure the router can do B or G, because it cannot do N.
Reefology
Sorry Roberto, I have no idea what that means or how to change it (if possible).
I received a new router from my service provider. Should I call them to have it switched?
Reefology
RESOLVED
Went into my router... -> Wireless -> Wireless Mode
wireless setting default was "802.11 g/n mixed"...switched to "802.11 g only"
Success
Many thanks Roberto!
Success
