So its been 4-5 years since I was in the hobby.
New computer so my old RA sketch is still loaded onto it. Unfortunately I read on the forum I cant download the sketch from my RA. Not the point of this post but wanted to give the backstory.
Whenever I try and upload I get an error. The drivers appear to be installed correctly (com3 and com4 show up in the menu).
Each time I go to upload the RA blinks a few times but then my old sketch appears and I get an error (see below). Is the programmer wrong? I am simply trying to reset to the factory program. Uploading the example, using the wizard, and using the restore preloaded code all give an error.
Copyright (c) 2000-2005 Brian Dean
Using Port : \\.\COM4
Using Programmer : stk500v2
Overriding Baud Rate : 115200
avrdude: Recv:
avrdude done. Thank you.
Reef Angel + Not Connecting
• Page 1 of 1
It seems the head unit or the programming cable are bad
Thanks, I will try a new cable first.
With respect to the head unit, the ability to upload is entirely separate from the functionality working correctly? The RA works perfect with the current sketch I did 5 years ago. If it is the head unit, what options do I have? Could I send it in to get looked at? Thanks again for the help. |
Yes, you can send it to be looked at.
PM me for RMA Roberto.
• Page 1 of 1
