Old Wifi attachment
				Iratus
Old Wifi attachment
Hi!
I cant find anything about solid blue light, only blinking.
The attachment have been disconnected for probably 2-3 years, do i need to re program it?
Best regards
Fredrik
Best regards
Fredrik
- brennyn21
Re: Old Wifi attachment
Hi Fredrik, you will need to upload the new firmware to your wifi attachment using Tera team as well as reinstall your code using the online webwizard
Link for the wifi attachement is below unzip the folder download tera team. Change the Wifi SSID and Password in the ttl file and use Tera team to flash it.
Tera Team Download: https://github.com/TeraTermProject/tera ... rm-5.3.exe
Wifi Attachement FirmWare: forum.reefangel.com/firmware/updatewifi.zip
WebWizard: forum.reefangel.com/webwizard
Sincerely, Brennyn
				Iratus
That was a quick reply!
How many cycles dos it take for the macro to complete?
						- brennyn21
				Iratus
That did not work, i still have a constant blue light and no info in Tera Term
  It keeps restarting and this is the last popup after a cycle https://drive.google.com/file/d/1rq58mY ... sp=sharing
						- brennyn21
- brennyn21
What does the output show in the terminal? Also if you have a space in your Wifi SSID make sure you put a $ in place of the space. For example, if your SSID is called "My Wifi" then it would be "My$Wifi"
							Sincerely, Brennyn
				Iratus
Output, where? I have no spaces in SSID
And this is what i get after one cycle when done, https://drive.google.com/file/d/15B2Gzc ... sp=sharing
Web wizard cant find the attachment.
- brennyn21
You are using a usb-ttl cable correct? Once you click okay if should show output in the Tera Team Terminal. Can you send picture of your wifi attachment? I'll take a picture of the process later today.  Once you click okay it should run through the process and then the start Wifly Module configuration will show again. Just ignore this as you only need to run it once. Then using the webwizard you need to upload code to your Reef Angel Controller Make sure you use chrome or edge and download the plugin first.
							Sincerely, Brennyn
				Iratus
Now i cen see something in Tera Term window https://drive.google.com/file/d/1xQomQB ... sp=sharing
https://drive.google.com/file/d/1Rommts ... sp=sharing
- brennyn21
- In Tera Term, go to 'Setup' -> 'Serial port'.
- Choose 57600 baud.
- Then, go back to 'Control' -> 'Macro' and reopen the .ttl file.
Sincerely, Brennyn
				Iratus
I have done that without results
						- brennyn21
Very odd, I will send you a PM maybe its a hardware failure of the wifi attachment.
							Sincerely, Brennyn
