Need help with RA+ and wifi attachment
bece13
Post by bece13 »
I've been out of the hobby for few years and I'm trying to revive my RA+ with WiFi attachment without success.
It looks like lots of things have changed. I tried to read posts on the forum but lots of them are old and not valid anymore.
Background: I have the RA+ with the WiFi attachment (no cloud wifi), expansion hub , 1 expansion relay box and dimming expansion.
I don't have any PC's or androids. I have only Macs and iPhones. I worked in IT for many years.
This is what I did so far:
I updated the WiFi attachment using CoolTerm. I'm getting slow green blink.
I updated RA+ using Uapp v4 wizard.
I can see the RA+ in my router.
Port 2000 is open in my router and forwarded to RA+IP
Going to "http://RA+IP" I get "Reef Angel Controller Web Server"
Going to "http://RA+IP/wifi" I get a blank page.
Going to Uapp -> I see Cloud Status: Connected, Last updated: Never, Current mode: Normal
Going to Uapp -> Relay I only see Main Box (no expansion relay box) and can't do anything.
Going to Uapp -> Setting I see Controllers: bece13 cloud active, Cloud modules not found (I don't have Cloud WiFi)
What am I doing wrong?
Should I still be able to access my RA+ on "http://RA+IP/wifi" instead of getting a blank page?
Can I still access RA+ directly on my local network?
Any help will be much appreciated.
brennyn21
Re: Need help with RA+ and wifi attachment
Post by brennyn21 »
So it looks like you did everything correctly, the issue was on my end. It set you as a Cloud User, which it shouldn't have. If you delete your Controller in the Uapp and resign in you should be able to see your data now.
Sincerely, Brennyn
bece13
Post by bece13 »
Working now from my Mac. Thanks
Should I still be to acces my RA+ on my internal network without going to internet (like going to "http://RA+IP/wifi")
Do you accept multiple connections at the same time?
I tried to go from my iPhone using wireless date and trying to connect to Uapp from the forum page (logged in on forum) and asks me to add controller and when I do that it says failed login and noe I believe I have to many tries.
Am I doing something wrong?
brennyn21
Post by brennyn21 »
Yes you can log into as many different devices there is no limit. If you enter your username and password wrong to many times wrong in a row withing 5 minutes it will block you from attempting to log in for 30 minutes I believe.
You can still use your Internal IP for http commands as well, its just not supported in the web version of the Uapp. Once the IOS and Android app versions are approved you will be able to do add the internal IP of your Reef Angel and communicate directly from the Uapp.
Sincerely, Brennyn
bece13
Post by bece13 »
Thanks for your help. Much appreciated.
akom6
Post by akom6 »
I have the same problem
brennyn21
Post by brennyn21 »
Let me check, give me just a few minutes and I'll get it fixed.
Sincerely, Brennyn
akom6
Post by akom6 »
Thank you
brennyn21
Post by brennyn21 »
It should be fixed now, delete your controller from the Uapp, then readd it.
Sincerely, Brennyn
akom6
Post by akom6 »
Yes, it started working, thank you very much
bece13
Post by bece13 »
Can the Ra+ with wifi attachement be accessed directly from my internal network when there is no internet?
brennyn21
Post by brennyn21 »
Not with the current webapp version of the Uapp. The Android and iOS version it's possible but they have not been approved for the app store just yet.
Sincerely, Brennyn
darragh
Post by darragh »
I seem to be getting the exact same issues. I have done all the updates to both the wifi attachment and RA+ as directed. Port forwarding has been confirmed. Yet, I am still unable to connect.
brennyn21
Post by brennyn21 »
Can you paste your code, i don't see any data from your controller.
Sincerely, Brennyn
