#define SIMPLE_MENU
#define DisplayLEDPWM
#include <ReefAngel_Wifi.h>
#include <ReefAngel_EEPROM.h>
#include <ReefAngel_ATO.h>
#include <ReefAngel_LED.h>
#include <ReefAngel_Relay.h>
#include <ReefAngel_PWM.h>
#include <ReefAngel_Timer.h>
#include <ReefAngel_Memory.h>
#define AutoTopOff 1
#define Actinic 2
#define Chiller 3
#define Heater 4
#define Skimmer 5
#define MetalHalide 6
#define SeaSwirl 7
#define Return 8
#define PWMRB1 0
#define PWMRB2 1
#define PWMRB3 2
#define PWMWT1 3
#define PWMWT2 4
#define PWMHN 5
byte PWMChannel[]={
0,0,0,0,0,0};
boolean ForceCloud=false;
boolean ForceLightning=false;
#include <avr/pgmspace.h>
//Create the menu entries
prog_char menu1_label[] PROGMEM= "Chow Time";
prog_char menu2_label[] PROGMEM= "h2o Change";
prog_char menu3_label[] PROGMEM= "Clear ATO Warning";
prog_char menu4_label[] PROGMEM= "Force Cloud";
prog_char menu5_label[] PROGMEM= "Force Lightning";
//Group menu entries together
menu1_label, menu2_label, menu3_label, menu4_label, menu5_label
void MenuEntry1()
ReefAngel.FeedingModeStart();
void MenuEntry2()
void MenuEntry3()
ReefAngel.ATOClear();
void MenuEntry4()
ForceCloud=true;
ReefAngel.DisplayedMenu=RETURN_MAIN_MODE;
void MenuEntry5()
ForceLightning=true;
byte x = 6;
byte y = 2;
byte t;
ReefAngel.LCD.DrawLargeText(COLOR_BLACK, COLOR_WHITE, 6, 3, "Dave's 40g Reef");
ReefAngel.LCD.DrawDate(6, 120);
ReefAngel.LCD.Clear(COLOR_BLACK, 1, 14, 131, 14);
//pingSerial();
x = 12;
y += MENU_START_ROW+1;
ReefAngel.LCD.DrawText(COLOR_BLUE, COLOR_WHITE, x, y+6, "Temp: pH:");
char text[7];
ReefAngel.LCD.Clear(DefaultBGColor, x+16, y+65, x+65, y+16);
ReefAngel.LCD.DrawLargeText(PHColor, DefaultBGColor, x+75, y+18, text);
//pingSerial();
ConvertNumToString(text, ReefAngel.Params.Temp1, 10);
y += MENU_START_ROW*2;
x = 10;
ReefAngel.LCD.Clear(DefaultBGColor,x,y,x+(16*4),y+16);
//pingSerial();
ReefAngel.LCD.DrawHugeNumbers(T1TempColor, DefaultBGColor, x, y, text);
//pingSerial();
//Start Moon Phase Display
x += (16*4) + 8;
y += MENU_START_ROW+3;
ReefAngel.LCD.DrawText(COLOR_BLACK, COLOR_WHITE, 12, 55, "Moon Phase:");
if (ReefAngel.PWM.GetActinicValue() ==0) ReefAngel.LCD.DrawText(20,255,81,55,"Off");
else if(ReefAngel.PWM.GetActinicValue() >=1 && ReefAngel.PWM.GetActinicValue() < 20) ReefAngel.LCD.DrawText(20,255,81,55,"New");
else if(ReefAngel.PWM.GetActinicValue() >=20 && ReefAngel.PWM.GetActinicValue() < 35) ReefAngel.LCD.DrawText(20,255,81,55,"Cresent");
else if(ReefAngel.PWM.GetActinicValue() >=35 && ReefAngel.PWM.GetActinicValue() < 45) ReefAngel.LCD.DrawText(20,255,81,55,"Half");
else if(ReefAngel.PWM.GetActinicValue() >=45 && ReefAngel.PWM.GetActinicValue() < 60) ReefAngel.LCD.DrawText(20,255,81,55,"Gibbous");
else if(ReefAngel.PWM.GetActinicValue() >=60 && ReefAngel.PWM.GetActinicValue() < 80) ReefAngel.LCD.DrawText(20,255,81,55,"Full");
//End Display Moon Phase Display
ReefAngel.LCD.DrawOutletBox(12, 102, TempRelay);
ReefAngel.Relay.On(Return); //Turn Return on at startup
ReefAngel.Relay.On(Skimmer); //Turn Skimmer on at startup
ReefAngel.Relay.On(SeaSwirl); //Turn SeaSwirl on at startup
ReefAngel.StandardATO(AutoTopOff,30); //Setup AutoTopOff as Auto Top-Off function with 30s timeout
ReefAngel.MHLights(MetalHalide,14,30,21,00,15); //Daylight schedule 1:00pm - 9:30pm with 15min cool down
ReefAngel.StandardLights(Actinic,13,00,21,30); //Actinic schedule 1:00pm - 9:30pm
ReefAngel.StandardHeater(Heater,788,792); // Setup Heater to turn on at 78.8F and off at 79.2F
ReefAngel.StandardFan(Chiller,797,80); // Setup Chiller to turn on at 81.1F and off at 79.7F
if (hour()>=21 || hour()<10)
ReefAngel.PWM.SetActinic(0);
//************************************************************ Start of PWM Expansion Code for Slope
PWMChannel[PWMRB2]=PWMSlope(9,30,21,30,0,90,60,PWMChannel[PWMRB2]); //Royal Blue - Right Bank
PWMChannel[PWMRB3]=PWMSlope(9,45,21,45,0,90,60,PWMChannel[PWMRB3]); //Royal Blue - Middle Bank
PWMChannel[PWMRB1]=PWMSlope(10,00,22,00,0,90,60,PWMChannel[PWMRB1]); //Royal Blue - Left Bank
PWMChannel[PWMWT2]=PWMSlope(11,00,21,00,0,90,90,PWMChannel[PWMWT2]); //XP-E Cool Whites - Left Side
PWMChannel[PWMWT1]=PWMSlope(11,30,21,30,0,90,90,PWMChannel[PWMWT1]); //XP-E Cool Whites - Right Side
PWMChannel[PWMHN]=PWMSlope(12,00,20,00,0,90,120,PWMChannel[PWMHN]); //XP-G Cool Whites - Left Side
if (hour()>=21 || hour()<12)
ReefAngel.PWM.SetDaylight(0);
ReefAngel.PWM.SetDaylight(PWMSlope(12,30,20,30,0,90,120,ReefAngel.PWM.GetDaylightValue())); //XP-G Cool Whites - Right Side
CheckCloud();
for (int a=0;a<6;a++)
ReefAngel.PWM.Expansion(a,int(2.55*PWMChannel[a]));
//************************************************************* End of PWM Expansion Code for Slope
ReefAngel.ShowInterface(); //Draw the Standard Interface
void CheckCloud()
#define Clouds_Every_X_Days 1
#define Min_Cloud_Duration 7
#define Max_Cloud_Duration 15
#define Min_Clouds_per_Day 3
#define Max_Clouds_per_Day 5
// Channels used by the actinic LEDs on the PWM Expansion module
// These channels will not be dimmed when the cloud effect is triggered
// Number is a binary form. B001100 means channel 2 and 3 are used for actinics
#define Actinic_Channels B000111
// Channels used by the daylight LEDs on the PWM Expansion module
// These channels will be used for the spike when lightning effect is triggered
// Number is a binary form. B000011 means channel 0 and 1 are used for daylights
#define Daylight_Channels B111000
static byte cloudchance=255;
static byte cloudduration=0;
static int cloudstart=0;
static byte numclouds=0;
static byte cloudindex=0;
static int LastNumMins=0;
#ifdef forcecloudcalculation
if (cloudchance==255)
#else
#endif
cloudchance=random(100);
// If we have cloud today
if (cloudchance)
lightningchance=random(100);
if (ForceCloud)
ForceCloud=false;
cloudchance=1;
cloudduration=10;
// lightningchance=1;
cloudstart=NumMins(hour(),minute())+1;
if (ForceLightning)
cloudchance=1;
cloudduration=10;
lightningchance=1;
if (cloudchance)
//is it time for cloud yet?
// let's go through all channels to pick which ones will be dimmed
if (bitRead(Actinic_Channels,a)==0)
// this will slope down the channel from the current PWM to 0 within 3minutes.
// then it will stay at 0 for the duration of the cycle
// and finally slope up from 0 to PWM value within 3 minutes
// it is basically an inversed slope
PWMChannel[a]=ReversePWMSlope(cloudstart,cloudstart+cloudduration,PWMChannel[a],0,180);
for (int b=0;b<6;b++)
if (bitRead(Daylight_Channels,b)==1)
else lightningstatus=0;
if (lightningstatus) PWMChannel[b]=100;
else PWMChannel[b]=0;
//delay(10);
PWMChannel[b]=20;
cloudindex++;
if (cloudindex < numclouds)
int x=0;
if (lightningchance)
int x=0;
cstart*=60;
cend*=60;
if (n>cend) return PWMStart;
