hi! i would like to share a great roberto contribution.
since i don't like wavemaker function ( i prefer use 2 pumps alterating every 6 hours) here is a simple workaround:
roberto wrote:
Just because it says standardlight doesn't mean it should only be used for lights.
You could use it like this:
ReefAngel.StandardLights(Relay4,6,0,12,0);
if (bitRead(ReefAngel.Relay.RelayData,Relay4)==0) ReefAngel.StandardLights(Relay4,18,0,0,0);
Try it and let me know if it works.
this will power up relay4 from 6:00 am to 12:00am and from 6:00pm to 12:00pm
doing the same with another relay will alternate 2 pumps every 6 hours...
it works well!
thanks!
wave pump started by hour and minutes instead wavemaker func
Re: wave pump started by hour and minutes instead wavemaker
should that read StandardLights?
i don't understand you.. sorry...alexwbush wrote:should that read StandardLights?
There was a typo on your post. That's all.mantu wrote:i don't understand you.. sorry...
You typed StandarLights and he was saying it should've been StandardLights.
I was just trying to clear it up in case someone copied and pasted and then was wondering why it might not work.
Thanks for posting!
Thanks for posting!
alexwbush wrote:I was just trying to clear it up in case someone copied and pasted and then was wondering why it might not work.
Thanks for posting!
i'm sorry! i just edited original post!
tnx!
Lorenzo
