#define DisplayImages
#define DateTimeSetup
#define VersionMenu
#define DisplayLEDPWM
#define RemoveAllLights
#define SIMPLE_MENU
#define CUSTOM_MENU
#define PWMEXPANSION
#define CUSTOM_MAIN
#define COLORS_PDE
#define FONT_8x16
#define AutoTopOff 1
#define Daylight 2
#define Actinic 3
#define StandardLight 4
#define Moonlight 5
#define Heater 6
#define Skimmer 7
#define Return 8
#include <avr/pgmspace.h>
prog_char menu6_label[] PROGMEM = "Date / Time";
prog_char menu7_label[] PROGMEM = "Version";
prog_char menu8_label[] PROGMEM = "Turn ON Skimmer";
prog_char menu9_label[] PROGMEM = "Turn Off Skimmer";
menu4_label, menu5_label, menu6_label,
menu7_label, menu8_label, menu9_label
void MenuEntry1()
ReefAngel.FeedingModeStart();
void MenuEntry2()
void MenuEntry3()
ReefAngel.ATOClear();
void MenuEntry4()
ReefAngel.OverheatClear();
void MenuEntry5()
ReefAngel.SetupCalibratePH();
void MenuEntry6()
ReefAngel.SetupDateTime();
void MenuEntry7()
ReefAngel.DisplayVersion();
void MenuEntry8()
ReefAngel.Relay.On(Port7);
ReefAngel.Relay.Write();
void MenuEntry9()
ReefAngel.Relay.Off(Port7);
ReefAngel.LCD.DrawMonitor(15, 60, ReefAngel.Params,
ReefAngel.LCD.DrawMonitor(15, 60, ReefAngel.Params);
ReefAngel.WaterChangePorts = Port6Bit | Port7Bit | Port8Bit;
ReefAngel.Relay.On(Port8);
// Specific functions
ReefAngel.StandardATO(Port1,5);
ReefAngel.StandardLights(Port2,13,30,22,0);
ReefAngel.StandardLights(Port3,13,30,22,0);
ReefAngel.StandardLights(Port4,15,0,21,30);
ReefAngel.StandardLights(Port5,21,30,9,0);
ReefAngel.StandardHeater(Port6,885,840);
ReefAngel.PWM.SetActinic(PWMSlope(13,30,22,0,30,60,60,20));
ReefAngel.PWM.SetDaylight(PWMSlope(13,30,22,0,20,50,60,20));
