It seems that the controller isn't quite right. All the timers and scheduling appear to be working correctly. The specified ports turn off for Feed and Water Change modes and the wavemaker function is working fine. I'm still having issues with the lights ramping up and down. They ramp up fine, but for whatever reason, won't ramp down.
The other thing that is happening is weird. When I get home from work and go to do daily maintenance, I can't get the screen to come back on either by pushing the button, or moving the joystick around. Today, when I tried it, I pushed the button, and it entered either water change or feeding mode, but the screen went black and I had to cycle the power to the controller to get it to come back on.
Here's the internal memory
// Autogenerated file by RAGen (v1.2.2.171), (04/02/2012 19:09)
// Memory_040212_1909.ino
#include <avr/pgmspace.h>
RA_NokiaLCD e;
e.Init();
e.BacklightOn();
InternalMemory.MHOnHour_write(8);
InternalMemory.MHOffHour_write(15);
InternalMemory.StdLightsOnHour_write(8);
InternalMemory.StdLightsOffHour_write(15);
InternalMemory.WM1Timer_write(200);
InternalMemory.LEDPWMDaylight_write(50);
InternalMemory.LEDPWMActinic_write(50);
InternalMemory.DP1RepeatInterval_write(0);
InternalMemory.DP2RepeatInterval_write(0);
InternalMemory.PWMSlopeStartD_write(15);
InternalMemory.PWMSlopeEndD_write(95);
InternalMemory.PWMSlopeDurationD_write(120);
InternalMemory.PWMSlopeStartA_write(15);
InternalMemory.PWMSlopeEndA_write(100);
InternalMemory.RFMode_write(0);
InternalMemory.RFSpeed_write(100);
InternalMemory.PWMSlopeStart0_write(10);
InternalMemory.PWMSlopeEnd0_write(95);
InternalMemory.PWMSlopeDuration0_write(60);
InternalMemory.PWMSlopeStart1_write(10);
InternalMemory.PWMSlopeEnd1_write(95);
InternalMemory.PWMSlopeDuration1_write(60);
InternalMemory.PWMSlopeStart2_write(10);
InternalMemory.PWMSlopeEnd2_write(95);
InternalMemory.PWMSlopeDuration2_write(60);
InternalMemory.PWMSlopeStart3_write(15);
InternalMemory.PWMSlopeEnd3_write(95);
InternalMemory.PWMSlopeDuration3_write(80);
InternalMemory.PWMSlopeStart4_write(15);
InternalMemory.PWMSlopeEnd4_write(95);
InternalMemory.PWMSlopeDuration4_write(80);
InternalMemory.PWMSlopeStart5_write(15);
InternalMemory.PWMSlopeEnd5_write(95);
InternalMemory.PWMSlopeDuration5_write(120);
// display success screen
e.DrawText(COLOR_BLACK, COLOR_WHITE, MENU_START_COL, MENU_START_ROW*5, " RA code file");
delay(5000);
//#include <Salinity.h>
Ports assignment:
Port1 - Standard ATO
Port2 - Skimmer
Port3 - Always On
Port4 - Heater
Port5 - Wavemaker 1
Port6 - Wavemaker 2
Port7 - SeaSwirl
Port8 - Return
//** Start Global Variables
#define PWMRB1 0
#define PWMRB2 1
#define PWMRB3 2
#define PWMWT1 3
#define PWMWT2 4
#define PWMHN 5
byte PWMChannel[]={
0,0,0,0,0,0};
// Globals Needed for Params on Custom Main
byte x,y;
int v;
//** End Global Variables
//** Start Custom Main Screen
//Top Banner
ReefAngel.LCD.DrawText(COLOR_BLACK, COLOR_SKYBLUE, 9, 2, " Dave's 40g Reef ");
// Display T1 Header Text
ReefAngel.LCD.DrawText(COLOR_BLACK,255,20,14,"Tank");
// Display the T1 Temp Value
char text[7];
ReefAngel.LCD.Clear(255, 4, 21, 37, 37);
ReefAngel.LCD.DrawLargeText(COLOR_BLACK, 255, 20, 24, text, Num8x16);
// Display pH Header Text
ReefAngel.LCD.DrawText(COLOR_INDIGO,255,70,14,"pH");
// Display pH Value
ReefAngel.LCD.Clear(255, 94, 21, 106, 37);
ReefAngel.LCD.DrawLargeText(COLOR_INDIGO, 255, 70, 24, text, Num8x16);
//Start Moon Phase Display
ReefAngel.LCD.DrawText(COLOR_BLACK, COLOR_WHITE, 12, 45, "Moon Phase:");
if (ReefAngel.PWM.GetActinicValue() ==0) ReefAngel.LCD.DrawText(20,255,81,45,"Off");
else if(ReefAngel.PWM.GetActinicValue() >=1 && ReefAngel.PWM.GetActinicValue() < 20) ReefAngel.LCD.DrawText(20,255,81,45,"New");
else if(ReefAngel.PWM.GetActinicValue() >=20 && ReefAngel.PWM.GetActinicValue() < 35) ReefAngel.LCD.DrawText(20,255,81,45,"Cresent");
else if(ReefAngel.PWM.GetActinicValue() >=35 && ReefAngel.PWM.GetActinicValue() < 45) ReefAngel.LCD.DrawText(20,255,81,45,"Half");
else if(ReefAngel.PWM.GetActinicValue() >=45 && ReefAngel.PWM.GetActinicValue() < 60) ReefAngel.LCD.DrawText(20,255,81,45,"Gibbous");
else if(ReefAngel.PWM.GetActinicValue() >=60 && ReefAngel.PWM.GetActinicValue() < 80) ReefAngel.LCD.DrawText(20,255,81,45,"Full");
//End Display Moon Phase Display
// Display Main Relay Box
ReefAngel.LCD.DrawOutletBox(13, 108, TempRelay);
//Draw Date & Time
void DrawCustomGraph() // Not Used
//** End Custom Main
ReefAngel.Init();
ReefAngel.FeedingModePorts = Port2Bit | Port5Bit | Port6Bit | Port8Bit; // Turn off Ports 2,5,6,8 when feeding mode is activated
ReefAngel.WaterChangePorts = Port2Bit | Port4Bit | Port8Bit; // Turn off Ports 2,4,8 when water change mode is activated
ReefAngel.Relay.On(Port2); // Turn on Skimmer
ReefAngel.Relay.On(Port3); // Turn on Always On port
ReefAngel.Relay.On(Port7); // Turn on SeaSwirl
ReefAngel.Relay.On(Port8); // Turn on return
ReefAngel.StandardATO(Port1, 60); // ATO with 60 seconds timeout
ReefAngel.StandardHeater(Port4,770,780); //Standard heater comes on at 77 degrees and off at 78 degrees
ReefAngel.WavemakerRandom1(Port5,15,60);//Turn on/off Wavemaker 1 random cycles from 15 to 60 seconds
ReefAngel.WavemakerRandom2(Port6,15,60);//Turn on/off Wavemaker 1 random cycles from 15 to 60 seconds
//** Moonphase Code Start Here
if (hour ()>=21 || hour ()<10)
ReefAngel.PWM.SetActinic(0);
//** Moonphase Code Ends Here
//** Daylight PWM Channel Code Starts Here
if (hour()>=21 || hour()<12)
ReefAngel.PWM.SetDaylight(0);
//ReefAngel.PWM.SetDaylight(PWMSlope(12,00,20,30,13,95,120,13)); //XP-G Cool Whites - Right Side
ReefAngel.PWM.SetDaylight(PWMParabola(12,00,20,30,15,95,15));
//** Daylight PWM Channel Code Ends Here
//** PWM Expansion Module Code Starts Here
//PWMChannel[PWMRB2]=PWMSlope(9,30,21,20,10,95,60,PWMChannel[PWMRB2]); //Royal Blue - Left Bank
PWMChannel[PWMRB2]=PWMParabola(9,30,21,20,28,95,28);
//PWMChannel[PWMRB3]=PWMSlope(9,50,21,40,10,95,60,PWMChannel[PWMRB3]); //Royal Blue - Middle Bank
PWMChannel[PWMRB3]=PWMParabola(9,50,21,40,28,95,28);
//PWMChannel[PWMRB1]=PWMSlope(10,10,22,00,10,95,60,PWMChannel[PWMRB1]); //Royal Blue - Right Bank
PWMChannel[PWMRB1]=PWMParabola(10,10,22,00,11,95,11);
//PWMChannel[PWMWT2]=PWMSlope(11,00,21,00,10,95,80,PWMChannel[PWMWT2]); //XP-E Cool Whites - Left Side
PWMChannel[PWMWT2]=PWMParabola(11,00,21,00,18,95,18);
//PWMChannel[PWMWT1]=PWMSlope(11,10,21,30,10,95,80,PWMChannel[PWMWT1]); //XP-E Cool Whites - Right Side
PWMChannel[PWMWT1]=PWMParabola(11,10,21,30,18,95,18);
//PWMChannel[PWMHN]=PWMSlope(12,00,20,00,10,95,120,PWMChannel[PWMHN]); //XP-G Cool Whites - Left Side
PWMChannel[PWMHN]=PWMParabola(12,00,20,00,12,95,12);
for (int a=0;a<6;a++)
ReefAngel.PWM.SetChannel(a,PWMChannel[a]);
//** PWM Expansion Module Code Ends Here
ReefAngel.ShowInterface(); //Draw the Standard Interface
Dave
