Hello All,
Just got my Reef Angel for my birthday on Sunday and I'm having a slight problem. After the it falls asleep for a while the unit stops responding. I went to bed last night and when i woke up this morning the green light as on but it wouldn't wake up. It also stopped controlling my cooling fan. I connected my USB cable and it came back to life. I'll post my code when I head home at lunch but was hoping somebody had a idea of what is causing this.
Thanks and excited for my angel!
Head Unit Stops responding
Re: Head Unit Stops responding
Here is my code:
ReefAngel.Relay.On(Port8); //Turn Port8 on at startup
ReefAngel.Relay.On(Port6); //Turn Port8 on at startup
ReefAngel.Relay.On(Port5); //Turn Port8 on at startup
//ReefAngel.StandardATO(Port1,60); //Setup Port1 as Auto Top-Off function with 60s timeout
ReefAngel.StandardLights(Port4,12,00,22,30); //Refugium schedule 10:30pm - 2:30pm
ReefAngel.StandardLights(Port3,12,30,22,00); //Actinic schedule 2:30pm - 10:30pm
ReefAngel.StandardFan(Port7,725,730); // Setup Chiller to turn on at 79.7F and off at 79.3F
ReefAngel.ShowInterface(); // Draws the standard graphical user interface}
ReefAngel.Portal("M@!");
I'm not 100% sure of the non standard characters on the portal function, but the server seems to be getting data and accepting it.
Let's try this first.
Change this:
To this:
Then, Open RAGen
Move to tab features
Make sure that Watchdog Timer is checked
Click Save
Upload your code again.
Change this:
Click Save
Yeah, I guess I should have thought about characters before choosing my username. Thanks, I will make those changes. The Watchdog Timer was not checked.
Fixed it, thanks! Installed it yesterday and everything is working perfect. Now I need to make things more complicated to keep me busy!
