Cloud/moon and strom for newbie
Hello to all I am a French who has recently acquired a reef angel and I have a hard program it was and I would like some help.
I would like to integrate the effects of clouds and storms and a moon phase in my angel reef program knowing that an extension pwm drivers 3 and 6 for blue LEDs and 3 for white.
Here are my current program:
ReefAngel.SetTemperatureUnit(1); // set to Celsius Temperature
ReefAngel.FeedingModePorts = Port4Bit | Port5Bit | Port6Bit;
ReefAngel.WaterChangePorts = Port1Bit | Port3Bit | Port4Bit | Port5Bit | Port6Bit;
ReefAngel.Relay.On(Port3);
ReefAngel.Relay.On(Port4);
ReefAngel.Relay.On(Port8);
ReefAngel.TempProbe=T1_PROBE;
ReefAngel.StandardHeater(Port1);
ReefAngel.StandardFan(Port2);
ReefAngel.Wavemaker1(Port5);
ReefAngel.Wavemaker2(Port6);
ReefAngel.StandardLights(Port7);
// PWMSlope based on Internal Memory values for Standard Lights
ReefAngel.PWM.SetChannel(0,PWMSlope(10,0,20,15,15,100,60,15));
ReefAngel.PWM.SetChannel(1,PWMSlope(10,05,20,20,15,100,60,15));
ReefAngel.PWM.SetChannel(2,PWMSlope(10,10,20,25,15,100,60,15));
ReefAngel.PWM.SetChannel(3,PWMSlope(10,10,20,00,15,100,60,15));
ReefAngel.PWM.SetChannel(4,PWMSlope(10,15,20,10,15,100,60,15));
ReefAngel.PWM.SetChannel(5,PWMSlope(10,20,20,15,15,100,60,15));
Thank you in advance for your help.
The rest of the program is right for me
ps sorry translated with google.
jerome.
jerome.
Re: Cloud/moon and strom for newbie
What do you mean with this?jezem wrote:extension pwm drivers 3 and 6 for blue LEDs and 3 for white.
Can you elaborate a little more?
I made as precise as I have an pwm extension for parameter.
and with this extension I of drivers led driver 6 .3 drivers white LED and 3 for the blue led to separate fact from the chain
chain: 0.1 and 2 for the blue LED
chain: 3.4 and 5 LED for white LED
jerome
jerome
I do not have wifi.
I have nothing on the standard PWM
Try this:
byte PWMChannel[]={
0,0,0,0,0,0};
byte x,y;
PWMChannel[0]=PWMSlope(10,0,20,15,15,100,60,15);
PWMChannel[1]=PWMSlope(10,05,20,20,15,100,60,15);
PWMChannel[2]=PWMSlope(10,10,20,25,15,100,60,15);
PWMChannel[3]=PWMSlope(10,10,20,00,15,100,60,15);
PWMChannel[4]=PWMSlope(10,15,20,10,15,100,60,15);
PWMChannel[5]=PWMSlope(10,20,20,15,15,100,60,15);
CheckCloud();
for (int a=0;a<6;a++)
ReefAngel.PWM.SetChannel(a,PWMChannel[a]);
void CheckCloud()
#define Clouds_Every_X_Days 1
#define Min_Cloud_Duration 7
#define Max_Cloud_Duration 15
#define Min_Clouds_per_Day 3
#define Max_Clouds_per_Day 5
#define Start_Cloud_After NumMins(11,0)
#define End_Cloud_Before NumMins(19,0)
// Channels used by the actinic LEDs on the PWM Expansion module
// These channels will not be dimmed when the cloud effect is triggered
// Number is a binary form. B001100 means channel 2 and 3 are used for actinics
#define Actinic_Channels B000111
// Channels used by the daylight LEDs on the PWM Expansion module
// These channels will be used for the spike when lightning effect is triggered
// Number is a binary form. B000011 means channel 0 and 1 are used for daylights
#define Daylight_Channels B111000
static byte cloudchance=255;
static byte cloudduration=0;
static int cloudstart=0;
static byte numclouds=0;
static byte cloudindex=0;
static int LastNumMins=0;
#ifdef forcecloudcalculation
if (cloudchance==255)
#else
#endif
cloudchance=random(100);
// If we have cloud today
if (cloudchance)
lightningchance=random(100);
if (cloudchance)
//is it time for cloud yet?
// let's go through all channels to pick which ones will be dimmed
if (bitRead(Actinic_Channels,a)==0)
// this will slope down the channel from the current PWM to 0 within 3minutes.
// then it will stay at 0 for the duration of the cycle
// and finally slope up from 0 to PWM value within 3 minutes
// it is basically an inversed slope
PWMChannel[a]=ReversePWMSlope(cloudstart,cloudstart+cloudduration,PWMChannel[a],0,180);
for (int b=0;b<6;b++)
if (bitRead(Daylight_Channels,b)==1)
else lightningstatus=0;
if (lightningstatus) PWMChannel[b]=100;
else PWMChannel[b]=0;
//delay(10);
PWMChannel[b]=20;
cloudindex++;
if (cloudindex < numclouds)
int x=0;
if ((cloudstart/60)>=10) x=11; else x=17;
if ((cloudstart%60)>=10) x=29; else x=35;
if (lightningchance)
int x=0;
if (((cloudstart+(cloudduration/2))/60)>=10) x=51; else x=57;
if (((cloudstart+(cloudduration/2))%60)>=10) x=69; else x=75;
ReefAngel.LCD.DrawText(0,255,x,120,((cloudstart+(cloudduration/2))%60));
cstart*=60;
cend*=60;
if (n>cend) return PWMStart;
thank you very much i try this .
It works great still some adjustment to do.
it may be several lightning, in the same cloud if so what parameter should settle it.
thank you again to your team as soon as possible I post a video.
jerome
jerome
Hello everyone quick question what parameter should be changed to have more flash of light during the cloud?
I explain when there is a cloud there is a single flash.
jerome thank you in advance.
This :
And then this:
if (lightningstatus) PWMChannel=100;
else PWMChannel=0;
//delay(10);
You can put a higher value for the "if (random(100)<20)" like "if (random(100)<80)"
So it has 80% chances to happen.
At least that's how i'll do it.....
And then this:
else PWMChannel=0;
//delay(10);
ok i try this thank you
I just tried to make the light is more intense but there is a single flash
the lightning appears only once?
if not for the rest great.
jerome
jerome
Ok, so i just read the complete and i'm a bit rusty.....but you have to play with 2 varables
Lightning_Change_per_Cloud and LightningChance.
So to increase the chances of a lighting set it at 100 so there is always at least 1 per storm (it's in the code already).
And to increase the number of lightings you have to tweak the Lightning_Change_per_Cloud.
But i'm not sure....
There is only one strike per cloud, but you can increase how long it lasts.
Change 5 to whatever many seconds you would like the strikes to last.
thank you very much.
jerome
jerome
