Hi. I want to use the ATO as a regular. This means that I want the ATO pump to activate when the low switch is down and shut down when the low switch is up. I would like to allow the second switch (upper switch) to act as a back-up (always on until the excess water moves it up and shuts it down).
Can someone help me with this code?
thanks!
Regular ATO function
Re: Regular ATO function
Try this:
if (ReefAngel.HighATO.IsActive()) ReefAngel.SingleATOLow(Port1); else ReefAngel.Relay.Off(Port1);
- J_C
The key is connecting the high and low switches to the correct port on the RA, this info can be found in the manual
lucho
Thanks. I tried to do this but now I get "sketch too big" when it is very short. I copied the whole sketch below, maybe someone can help me:
#define DisplayImages
#define DateTimeSetup
#define VersionMenu
#define wifi
#define SIMPLE_MENU
#define ENABLE_ATO_LOGGING
prog_char id_label[] PROGMEM = "Lito";
prog_char probe1_label[] PROGMEM = "Sump";
prog_char probe2_label[] PROGMEM = "Refugium";
prog_char probe3_label[] PROGMEM = "Room";
prog_char relay1_label[] PROGMEM = "Actinic";
prog_char relay2_label[] PROGMEM = "Main%20Lights";
prog_char relay3_label[] PROGMEM = "Light%20Fans";
prog_char relay4_label[] PROGMEM = "Sump%20Lights";
prog_char relay5_label[] PROGMEM = "ATO";
prog_char relay6_label[] PROGMEM = "Heater";
prog_char relay7_label[] PROGMEM = "Skimmer";
prog_char relay8_label[] PROGMEM = "Return%20Pump";
ReefAngel.Relay.On(Port8); // Return pump
ReefAngel.Relay.On(Port7); //Skimmer
CheckWifi();
ReefAngel.StandardLights(Port1,10,0,22,30); //Actinic lights
ReefAngel.StandardLights(Port2,11,30,20,30); //Main lights
ReefAngel.StandardLights(Port3,10,30,21,0); //Lights fan
ReefAngel.StandardLights(Port4,18,0,11,0); //Sump Lights
ReefAngel.StandardHeater(Port6,788,79.2);
ReefAngel.Portal("lucho");
