My code - now with RAnet
Re: My code - water level ATO help needed
Does the red light turns on immediately or it turns on after 60 seconds?
bencollinz
ok, so I unplugged RA and plugged back in. no red light. ATO is on auto per portal. water level is at 55 currently, so it should be running but it's not.rimai wrote:Does the red light turns on immediately or it turns on after 60 seconds?
I turn it to on manually, it doesn't shut off when it hits 60 seconds or 58% water level. If I set it back to auto it stays off.
the portal still says water is 55% but RA says 59%
unfortunately, I couldn't reproduce the red light issue now.
It won't turn on until it reaches 52%. That's what you set it at.
It turns on at 52% and off at 58%.
So, when the level does get to 52, you have 60 seconds to pump water until it hits 58% or the timeout will happen and disable the ATO. This is a safety feature to prevent overflow. That's when the red light goes on, indicating an ATO timeout.
So, I think you are using too high of a range and too low of a timeout. Can you pump that much water in 60 seconds?
It will never shut off if you turn on manually. That's what we call override. You are forcing an on position situation no matter what the controller thinks it should be.
bencollinz
I found this is someone else's thread http://forum.reefangel.com/viewtopic.ph ... ion#p14563rimai wrote:It won't turn on until it reaches 52%. That's what you set it at.
// If water level less than 58, turn on auto top off relay; else, keep it off
if (ReefAngel.WaterLevel.GetLevel()<58) ReefAngel.Relay.On(Port7);
else ReefAngel.Relay.Off(Port7);or does it still need a timeout, just in case?
bencollinz
#define Heater 1
#define Return 2
#define Skimmer 3
#define Vortech1 5
#define Vortech2 6
#define ATO 7
byte vtechmode;
ReefAngel.FeedingModePorts = Port4Bit | Port5Bit | Port6Bit;
ReefAngel.WaterChangePorts = Port7Bit | Port4Bit | Port5Bit | Port6Bit;
ReefAngel.OverheatShutoffPorts = Port1Bit | Port2Bit | Port7Bit | Port4Bit | Port5Bit | Port6Bit;
ReefAngel.Relay.On( Port2 );
// Hardcode PH calibrations
ReefAngel.PHMin=576; // PH7.0
ReefAngel.PHMax=842; // PH10.0
ReefAngel.SalMax=3000; // 35ppt
ReefAngel.StandardHeater( Port1,796,802 );
// ReefAngel.WaterLevelATO( Port7,60,52,58 ); // 60 seconds timeout, turn on at 52% and turn off at 58%
ReefAngel.PWM.Channel2PWMParabola();
ReefAngel.PWM.Channel3PWMParabola();
ReefAngel.PWM.Channel4PWMSlope();
ReefAngel.RF.UseMemory = true;
if ( ReefAngel.LowATO.IsActive())
ReefAngel.Relay.On(Port2);
ReefAngel.Relay.Off(Port2);
if (hour() <= 8 && hour() >= 20)
ReefAngel.PWM.SetChannel( 0, MoonPhase() );
ReefAngel.RF.UseMemory=false;
vtechmode = 9;
ReefAngel.RF.UseMemory=true;
vtechmode = InternalMemory.RFMode_read();
ReefAngel.PWM.SetChannel( 0, MoonPhase(0) );
ReefAngel.Portal( "bencollinz" );
char text[7];
ReefAngel.LCD.DrawDate( 6, 2 );
ReefAngel.LCD.DrawText(COLOR_TOMATO,255, 6, 90, "--------------------");
ReefAngel.LCD.DrawText(COLOR_TOMATO,255, 6, 126, "--------------------");
ReefAngel.LCD.DrawText(COLOR_TOMATO,255, 2, 93, "|");
ReefAngel.LCD.DrawText(COLOR_TOMATO,255, 2, 103, "|");
ReefAngel.LCD.DrawText(COLOR_TOMATO,255, 2, 113, "|");
ReefAngel.LCD.DrawText(COLOR_TOMATO,255, 2, 123, "|");
ReefAngel.LCD.DrawText(COLOR_TOMATO,255, 126, 93, "|");
ReefAngel.LCD.DrawText(COLOR_TOMATO,255, 126, 103, "|");
ReefAngel.LCD.DrawText(COLOR_TOMATO,255, 126, 113, "|");
ReefAngel.LCD.DrawText(COLOR_TOMATO,255, 126, 123, "|");
ReefAngel.LCD.DrawText(0,255,10,30,"Temp");
ConvertNumToString(text, ReefAngel.Params.[T1_PROBE], 10);
ReefAngel.LCD.DrawLargeText(COLOR_INDIANRED, 255, 10, 40, text, Num8x8);
ReefAngel.LCD.DrawLargeText(COLOR_PLUM, 255, 85, 40, text, Num8x8);
ReefAngel.LCD.DrawText(0,255,43,48,"Salinity");
ConvertNumToString(text, ReefAngel.Params.Salinity, 100);
ReefAngel.LCD.DrawLargeText(COLOR_LIMEGREEN, 255, 49, 58, text, Num8x8);
ReefAngel.LCD.DrawOutletBox( 12, 77, TempRelay );
// water level
ReefAngel.LCD.DrawText(0,255,8,68,"WL:");
ReefAngel.LCD.DrawText( COLOR_CORNFLOWERBLUE, 40, 68, 10, ReefAngel.WaterLevel.GetLevel() );
}and I can't get water level to display on screen, what's wrong there?
Your coordinates are wrong.
It's printing at coordinates x=68 and y=10.
I think you what you want is this:
The code you are using does just that. It will turn on whenever the level goes below 58. There is no hysteresis.
If you want hysteresis, you need to use the previous function you were using before. The one you commented out.
ReefAngel.LCD.DrawText( COLOR_CORNFLOWERBLUE,255, 40, 68, ReefAngel.WaterLevel.GetLevel() );
- lnevo
It sounds like from what you want is to use the WaterLevelATO and just increase your timeout... or reduce the high/low difference...
I would suggest something like this.. 3 minutes instead of 1.
Another thing that will help to put the numbers in a better perspective is.. How long does it take to fill your sump from 52 to 58. That plus a few seconds is what you want your timeout to be.
The code you have everytime it drops to 57 it will turn on till 58 and sometimes the reported level varies from the sensor, so thats why you're seeing on / off / on / off
The other choice is making the numbers smaller. If you want it on at 52%, then leave than and reduce the 58 to something you can get to within 60 seconds.. Say 54%
ReefAngel.WaterLevelATO( Port7,180,52,58 ); // 180 seconds timeout, turn on at 52% and turn off at 58%
ReefAngel.WaterLevelATO( Port7,60,52,54 ); // 60 seconds timeout, turn on at 52% and turn off at 54%
bencollinz
now I get this...
#define Heater 1
#define Return 2
#define Skimmer 3
#define Vortech1 5
#define Vortech2 6
#define ATO 7
byte vtechmode;
ReefAngel.WaterLevelATO( Port7,600,55,58 ); // 60 seconds timeout, turn on at 55% and turn off at 58%
// if (ReefAngel.WaterLevel.GetLevel()<58) ReefAngel.Relay.On(Port7);
// else ReefAngel.Relay.Off(Port7);
vtechmode = 9;
char text[7];
// water level
}You do not have the required permissions to view the files attached to this post.
bencollinz
Thank you, that worked!rimai wrote:Your coordinates are wrong.
I think you what you want is this:.Code: Select all
I think you already figured out, but just for records...
Your reference to T1 was wrong....
It should be this:
It should be this:
bencollinz
yessir! everything is working so far, have to wait and see about the ATO changes.rimai wrote:I think you already figured out, but just for records...
It should be this:Code: Select all
bencollinz
Re: My code
ReefAngel.Relay.Off(Port2);- lnevo
Re: My code
Use the SingleATOLow function
SingleATOLow(Port2);
bencollinz
Re: My code
maybe I'm misunderstanding, I changed it to this:lnevo wrote:Use the SingleATOLow function
ReefAngel.SingleATOLow(Port2);-
bencollinz
Re: My code
the wires are facing up. i removedlnevo wrote:Did you change that whole section of code? It should go off when the switch is inactive. You may have the switch upside down. Which way is it facing?
ReefAngel.Relay.Off(Port2);Code: Select all
bencollinz
so i changed it back to this formatlnevo wrote:It sounds like from what you want is to use the WaterLevelATO and just increase your timeout... or reduce the high/low difference...
I would suggest something like this.. 3 minutes instead of 1.Another thing that will help to put the numbers in a better perspective is.. How long does it take to fill your sump from 52 to 58. That plus a few seconds is what you want your timeout to be.Code: Select all
The other choice is making the numbers smaller. If you want it on at 52%, then leave than and reduce the 58 to something you can get to within 60 seconds.. Say 54%Code: Select all
ReefAngel.WaterLevelATO( Port7,60,52,54 );-
bencollinz
Re: My code
the red light was on, I chose clear ATO it started and wouldn't stop. the red light came on again, I cleared again, it still wouldn't turn off. it's now at 61% again. I had to turn off manually.rimai wrote:Are you sure it isn't timed out already?
Just to be sure, can you clear ATO?
current code:
#define Heater 1
#define Return 2
#define Skimmer 3
#define Vortech1 5
#define Vortech2 6
#define ATO 7
byte vtechmode;
// Hardcode calibrations
ReefAngel.WaterLevelATO( Port7,600,58,60 );
// ReefAngel.SingleATOLow(Port2);
vtechmode = 9;
char text[7];
for (byte Left=93; Left < 133; Left+=10)
ReefAngel.LCD.DrawText(COLOR_TOMATO,255, 2, Left, "|");
ReefAngel.LCD.DrawText(COLOR_TOMATO,255, 126, Left, "|");
ReefAngel.LCD.DrawText(0,255,18,12,"EcoSmart Vortech");
ReefAngel.LCD.Clear(255, 1, 19, 128, 29);
if (vtechmode == 0) ReefAngel.LCD.DrawLargeText(COLOR_LIMEGREEN,255,35,21,"Constant");
else if(vtechmode == 1) ReefAngel.LCD.DrawLargeText(COLOR_GOLD,255,42,21,"Lagoon");
else if (vtechmode == 2) ReefAngel.LCD.DrawLargeText(COLOR_GOLD,255,25,21,"Reef Crest");
else if (vtechmode == 3) ReefAngel.LCD.DrawLargeText(COLOR_CORNFLOWERBLUE,255,22,21,"Short Pulse");
else if (vtechmode == 4) ReefAngel.LCD.DrawLargeText(COLOR_PINK,255,25,21,"Long Pulse");
else if (vtechmode == 5) ReefAngel.LCD.DrawLargeText(COLOR_MAGENTA,255,8,21,"Nutrient Trnsp.");
else if (vtechmode == 6) ReefAngel.LCD.DrawLargeText(COLOR_MAGENTA,255,23,21,"Tidal Swell");
else if (vtechmode == 9) ReefAngel.LCD.DrawLargeText(COLOR_WHITE,0,45,21,"Night");
// water level
Re: My code
Are you sure you uploaded this code?
It says timeout is 600 seconds. Was your ATO pump on for 600 seconds before it turned the red led again?
bencollinz
Re: My code
rimai wrote:Are you sure you uploaded this code?
yes, that is the current code.
the red light comes on after 10 mins every time I 'clear ATO' from menu, regardless of the port running or not.
The port did turn itself off at the proper % finally, though.
Re: My code
So, you are getting ato timeout even when the port is supposed to be off?
You are not overriding it off, are you?
If you do, it would definitely timeout.
bencollinz
Re: My code
so, for example, right now, the red light is on. i'll 'clear ato', the water is at 56%, so the port turned on for ATO, the red light came back on ~1-2 mins, i 'clear ato' (the port still on all the while), the port shuts off at 60%.rimai wrote:So, you are getting ato timeout even when the port is supposed to be off?
it's on auto via portal or reboot, not changing to off.
bencollinz
Re: My code
and now the red light is on again. ~10 mins after I last pressed 'clear ato'
cleared it again, got it ~2 mins later
Re: My code
I think you found a bug
Can you disconnect the ATO Low float switch and see if the problem is fixed?
bencollinz
Re: My code
I unplugged that, rebooted RA, let it sit for 20 mins and now my return pump port 2 just shut off.rimai wrote:I think you found a bug
but that was also the first time i set port 2 to auto instead of on.
bencollinz
Re: My code
the ATO pump went on and off just as it should without the float switch! and no red light to clear.
Re: My code
Yeah, just what thought.
The libraries code is sharing the part of the code with the low float switch.
I'll have to update it.
Should be fixed in the next update.
In the mean time, you can use the high ato port for your return.
