LCD screen hardware change
Re: LCD screen hardware change
By the time I figured it out, you'd have the formal version up. :mrgreen:
--C
JHP
Post by JHP »
is there a charge for the upgrade?
No, as long as you have a gen 2 screen.
I received my new LCD screen today.
From the looks of the announcements at the top of each forum library 1.0.4 is the latest, but I followed the link to the change log at the bottom of that thread and it show 1.0.5.
Is this correct or is 1.0.6 out yet?
It will be released tonight.
Great. I hope to have time to work on setting this up this weekend.
Got the new screen up and running. It is leaps and bounds better looking than my old one.
The response time seems a little slower, though.
That's the trade off, but I think it's worth it, don't you?
Yes, it's not that bad. It's very smooth and looks gorgeous compared to the gen 2.
--C
Elevatorguy1
Post by Elevatorguy1 »
Replaced mine this morning. Very nice looking!
JHP
Post by JHP »
Hi
Is this GEN 1 OR GEN 2
/Jan
Gen1.
You are good :)
dapg8gt
Post by dapg8gt »
Going to be replacing mine tomorrow it seems pretty straight forward right? Just pop out the old one and insert the new one?.. Insert code and ready to rock?.. I've gotten used to no screen lol I'm excited? Guessing the screen just pops out?
Yep, just pull and stick in the new one.
dapg8gt
Post by dapg8gt »
Cool thanks.. should have brought it to work with me lol..
Yeah it was easy. It just came out and the new one went in it's place. Just make sure the pins are lined up and it doesn't need any force. If you feel that it is hard, stop, pull it off and check everything is straight and aligned.
Mine came up fine with out having to replace the code.
OceanWolf
Post by OceanWolf »
Hi Roberto,
I think I have a Gen2. What should I do?
Onur
Onur
Yeap.
PM me for RMA.
Jbowen590
Post by Jbowen590 »
What months were the gen2 sold in?
kwolfskill
Post by kwolfskill »
Hi Roberto,
I've had my Reef Angel for a number of months now, and haven't even hooked it up yet because the tank just finally got water in it to cycle it (it has been a slow process getting to this point). Just saw this thread and opened my Reef Angel up, and looks like I have a Gen 2 screen. At the moment I can't PM you, so what should I do?
Kevin
I upgraded your account. Try now.
JDW
Post by JDW »
Please excuse my noobish inexperience, but i recently purchased an upgrade board for my RA. I am having the same issues where my screen is acting screwy. It works fine with the old RA board, but when i hook it up to the RA+ it has a single horizontal line that scrolls vertically. I found this post and it mentions that I need to insert a particular code.
"InternalMemory.LCDID_write(255);"
I am not certain where that should go in my RA Wizard program. Below is the code I am using.
#include <Globals.h>
#include <RA_Wifi.h>
#include <Wire.h>
#include <OneWire.h>
#include <Time.h>
#include <DS1307RTC.h>
#include <InternalEEPROM.h>
#include <RA_NokiaLCD.h>
#include <RA_ATO.h>
#include <RA_Joystick.h>
#include <LED.h>
#include <RA_TempSensor.h>
#include <Relay.h>
#include <RA_PWM.h>
#include <Timer.h>
#include <Memory.h>
#include <RA_Colors.h>
#include <RA_CustomColors.h>
#include <Salinity.h>
#include <RF.h>
#include <IO.h>
#include <ORP.h>
#include <AI.h>
#include <PH.h>
#include <WaterLevel.h>
#include <Humidity.h>
#include <DCPump.h>
#include <ReefAngel.h>
    ReefAngel.FeedingModePorts = Port1Bit;
    InternalMemory.OverheatTemp_write( 790 );
    ReefAngel.Relay.On( Port2 );
    ReefAngel.Relay.On( Port4 );
    ReefAngel.Relay.On( Port5 );
    ReefAngel.StandardHeater( Port3,760,770 );
    ReefAngel.SingleATO( true,Port7,60,0 );
    ReefAngel.Portal( "JDW" );
Place it right above ReefAngel.Init();
JDW
Post by JDW »
Thank you Roberto, fixed it right up
Xender
Post by Xender »
Hi Roberto !
Thanks a lot !
It works but I had to delete one line also :
Salt Water Aquarium 60*60*60
Matthewgype
Post by Matthewgype »
thanks for giving me the necessary information
JclaasSA
Post by JclaasSA »
Hi
The screen on my standard Reef Angel unit fades/distorts after a while.
I fitted my Reef Angel Plus screen to it and then the backlight comes on, but displays nothing (even after entering the code "InternalMemory.LCDID_write(255);").
I also tried to upload all the different screen generation codes to the standard Reef Angel without any luck.
The fading/distorting screen displays something on the Reef Angel Plus without changing it's code.
The reason I want the standard Reef Angel sorted out is because the Reef Angel Plus pcb is corroded by the joystick which has since stopped scrolling up/down and I am not sure if removing the joystick from the standard Reef Angel and fitting it to the pcb of the Reef Angel Plus would help.
Can someone please advise?
It seems the screen has some issues too. You may need to replace it.
