I/O expansion added to wizard.
Trevenator
Re: I/O expansion added to wizard.
Post by Trevenator »
Just ordered the Multi-Channel Water Level Expansion will use that to monitor the levels of my Cal - Alk - vinegar - vodka.
I already have the single Water Level Expansion on my ato.
Would still like a float switch on my skimmer cup and be able to shut it off and send a email when its full.
Open the enclosure. It will be written in the pcb.
For your skimmer cup, use this:
ReefAngel.Relay.Set(Port1,ReefAngel.IO.GetChannel(0)); // Set port 1 according to I/O channel 0
Trevenator
rimai wrote:Open the enclosure. It will be written in the pcb.
It says reef angel plus main unit 2.1
I meant the I/O module.
Trevenator
ok its I/O Expansion 2.0
Yes, starting on 2.0 version, you can easily use any port as output too. You just need to code it so the module knows you are using as output.
You need to add this to the end of your code:
void SetIOChannel(byte channel, byte value)
    Wire.beginTransmission(I2CIO_PCF8574);
    Wire.write(value<<channel);
    Wire.endTransmission();
Then, in your code, you can set any channel on the I/O module like this:
SetIOChannel(0,1); // Set channel 0 to on
Veeresh
Post by Veeresh »
Hi Roberto
My IO Expansion module rev is 2.2
I have added the following coding
in the setup I called the following codes
// init IO port 1 to 3
// Testing phase
SetIOChannel(1,1); // Set channel 1 to on
SetIOChannel(2,1); // Set channel 2 to on
SetIOChannel(3,0); // Set channel 3 to off
SetIOChannel(4,0); // Set channel 4 to off
SetIOChannel(5,0); // Set channel 5 to off
and in the loop
if (hour()>=0 && hour()< 17 )
if ( currentMillis - previousMillis >= intervaltimer )
if (FanOffStatus == false)
FanOffStatus = true; // variable set to off the fan
previousMillis = currentMillis;
intervaltimer = 30000 ;
SetIOChannel(4,1); // Set channel 4 to on
SetIOChannel(5,0); // Set channel 5 to on
FanOffStatus = false; // variable set to on the fan
previousMillis = currentMillis ;
intervaltimer = 5000 ;
SetIOChannel(4,0); // Set channel 4 to on
SetIOChannel(5,1); // Set channel 5 to on
ReefAngel.Relay.Off( Port3 );
ReefAngel.Relay.On( Port3 );
I'm just wanted to test the IO module to in port 4 and 5 to toggle between ON and OFF stage. and I noticed that all my port are at +5V including port 4 an 5. There is no toggling in voltage in port and 4 and 5. Looks like the RA is not IO module is set to OUTPOT module. Please advise
I'll have to check when I get to the office.
Sent from my SM-G900P using Tapatalk
I'm not so sure why it is not working for you.
This is what I tested:
  if (millis()%2000<1000)
    SetIOChannel(0,1);
    SetIOChannel(0,0);
Channel 0 goes high and low every second.
