Code for Doser based on Schedule
Re: Code for Doser based on Schedule
i checked the measuring cup this morning before I left for work and after 7 doses, it was at around 10mL. This is based on 72 seconds per dose. It still have 5 doses left so that will definitely be above 15 mL. Based on that, I'm thinking everything is working correctly and evaporation probably was the culprit. I agree with you that starting with 68 seconds is best and then monitor. Will start tonight! Thanks.
Jack
This was my thread many years ago. I'm looking to do the exact same thing. When I plugged in the code:
I get an error saying expected ";" before if.
So I added it:
It complied fine. I'm curious why the error? Did something change in the background for this line to need the ";"? Will this do what I want?
//DoserAlk Schedule
if ((hour() > 10) && (hour() < 22)) { // Between 10am and 10pm we will disable Port 6
ReefAngel.Relay.Off(Port6);
So I added it:
//DoserAlk Schedule
;if ((hour() > 10) && (hour() < 22)) { // Between 10am and 10pm we will disable Port 6
Jack
It is probably missing from before the code you posted
Weird because i don't recall getting any errors and the controller functioned as ordered. But it's been a few years. Thanks!rimai wrote:It is probably missing from before the code you posted
Jack
