Automated testing
Re: Automated testing
All our expansion modules are analog and I use an analog to I2C chip, so not much different.
Cool so just a matter of cost on that probe and some math?
tngo
Post by tngo »
Yeah, the Seneye will reportedly try and do it for $200. Also the accuracy of alkalinity value will be affected by the pH and CO2 probes accuracy.
Yeah, for the price of the Seneye, it's not a terrible purchase. Just won't be able to automate anything off it or integrate it into the RA data. Maybe I'll figure out how to scrape it off the web interface and push it to a custom variable :)
If we could do the same it would be cool though :)
tngo
Post by tngo »
I checked on the probe that Roberto linked and thats about $7K. The probe from the research paper is about $720. The one I had linked is rated from 400ppm to 10000ppm which is out of our detection requirements. Average dissolved CO2 in seawater is around 350ppm. However when looking up the CO2 probe I get varying specs even though they look pretty much the same. In the following link the sensor is rated from 0-2000ppm but with an accuracy of 200ppm. The accuracy maybe reduced through longer average sampling. Not sure if it will be viable but I'll try and look some more. Absolute value of alkalinity will probably deviate a large amount, but possibly large sampling and weighing the final number by a titrated calibration value might work.
https://www.seeedstudio.com/Grove-CO2-S ... -1863.html
Tim
tngo
Post by tngo »
The following probe has better accuracy numbers.
https://www.tindie.com/products/Blueber ... sor-ee893/
tngo
Post by tngo »
Here's a website that goes through the calculations for pH, total alkalinity, CO2 and pCO2. It does it backwards from what we would want namely obtaining CO2 from total alkalinity, whereas we would want total alkalinity from CO2 and pH. They also do an iterative process to lock down a converging pH value and alkalinity which is interesting possibly allowing us to get a more stable value if implemented. There is source code on one of the tabs showing the constants that he used and how he does the calculations in code.
http://biocycle.atmos.colostate.edu/shiny/carbonate/
Tim
tngo wrote:The following probe has better accuracy numbers.
I like that this one is optical.
rrodriguess
Post by rrodriguess »
I have a planted aquarium with CO2 injection. Would love to have one of this.
Rafa
rrodriguess
Any progress on that? Maybe we could open some kind of crowdfunding to help somehow?
Nothing new, but seneye supposedly released an API on github to access the data. Opens up some good possibities :)
