iOS Reef Angel Uapp deprecated?
acabano
Re: iOS Reef Angel Uapp deprecated?
Post by acabano »
thank you Roberto!
acabano
Post by acabano »
looks like Uapp is still down on my setup.
Are you using the web based UApp?
https://forum.reefangel.com/UApp/
acabano
Post by acabano »
yes i am, cloud status: disconnected
Do you have the cloud wifi attachment?
If not, you can't use the cloud server.
Make sure to not enter the cloud username and password when creating the profile. Enter only the ip address and port
acabano
Post by acabano »
web base Uapp.JPG (54.21 KiB) Viewed 3284 times
I have a RA star board, with ip address and port, still no luck with web based UApp.
Ahh. Ok.
Does it say cloud connected on the screen of your RA*?
With RA*, you should create a profile with both ip address and port left blank and just enter your forum username and password. They are both case sensitive.
acabano
Post by acabano »
sorry my controller is RA with ATMega328P
Reef Angel Controller
Technical Data
ATMega328P microcontroller running at 16MHz
32K Flash memory for coding
128x128 Color LCD screen
64K EEprom memory (2 banks of 32K)
Real time clock
Battery backup for clock settings
Thumb joystick with center select push-button
PH monitoring
3 temperature probe ports
2 float switch ports
Serial TTL port
You can't use the cloud server then.
Create a new profile and make sure to enter only the ip address and port. Don't enter username nor password.
