UApp Error - Nothing to update
sbidny
Re: UApp Error - Nothing to update
Post by sbidny »
Will do...
sbidny
Post by sbidny »
BTW, do you want me to do this while I'm seeing the null value? I have updated them again from the URL, so I will need to reproduce the issue. Should be easy, but I want to check before proceeding.
sbidny
Post by sbidny »
Well, it was easy to get the null value back. Here is the string with the null value I'm seeing:
0f1e1500c2000f1e0a000f00525584035802340314140b030d03340333033ce402bf01001400161e00003c3c081e141e0a14323c14323c00800a0f643c0f643c0f643c0f643c0f643c0f643c780078000208c201000203f80220032a0300643c00643c00643c00643c00643c00643c00643c00643c00643c07f401c409000000000b0362645a3c00000032325702eb054e026c074e026c074e026c07ffffffffffffffff00ffffffffffffffffffffff
That's very odd.
C2 is not a valid hour.
The string represents the internal memory values starting at 200.
What happens when you change to a correct number and click save?
Can you post the log?
sbidny
Post by sbidny »
FYI, updating the value is now causing my controller to reboot.
sbidny
Post by sbidny »
It seems to be rebooting every time the Uapp needs to update more than one value at a time, which the time fields do automatically. If I update a single field, it works fine. If I update two independent fields or a single time field, it reboots the controller.
Were you able to see what the console log shows when you update the value?
sbidny
Post by sbidny »
See attachment.
forum.reefangel.com-1546987244699.log
Chrome Console Log
(1.51 KiB) Downloaded 713 times
According to the log, the controller did receive the memory location 204 change to 14 and it even responded with OK.
The 205 was not acknowledged though.
That's when you mentioned it rebooted and I can see that in the log too.
But I can't replicate.
This is what I get on my RA+ test controller using the cloud wifi attachment:
0f1e15000e3b151e0a000f00040484035802ee021414fd02030307030303ff3e031c02071400161e00ffff3c003c00f6090f643c0f643c05380b0f643c0f643c0f643c0f643c0f643c0f643c7800ffff0208c2011e0203f80220032a0300643c00643c00643c00643c00643c00643c00643c00643c00643c07f401c40984031405ee023c41043c0001022e0a4e026c074e026c074e026c074e026c07ffffffffffffffff1effffffffffffffffffffff
uapp.js:661 PopoverControllermemoryrawok
uapp.js:2111 PH:340
uapp.js:2111 PH:342
uapp.js:2111 PH:340
uapp.js:2111 PH:342
uapp.js:931 mb204,13
uapp.js:2111 MBOK:204
uapp.js:2373 mb205,58
uapp.js:2111 MBOK:205
uapp.js:2111 PH:340
uapp.js:2111 PH:342
sbidny
Post by sbidny »
Strangely, the same change from my phone causes the same timeout, but it does not cause the reboot.
cwoodardii
Post by cwoodardii »
Did this ever get resolved? I have the same issue.
