Re: Auto Calibrate Salinity Probe?
Posted: Sat Apr 24, 2021 1:29 pm
by howaboutme
Thanks Curt! I think I understand. I'll play with this the next few days and report back.
I hope I'm not shooting myself in the foot and defeating the purpose of monitoring salinity. I've been doing this manually and am confident in my ability to keep the tank stable in normal circumstances so I'm comfortable trying this out. We'll see. :)
Posted: Sun Apr 25, 2021 6:20 am
by howaboutme
Curt,
Can you check my code? I've adjusted the start time and run time. It compiles with no errors. I just want a 2nd eye before I load and test. Thanks!
// Set to start at 9:45am and run for 10 minutes
    #define AUTO_SAL_START_HOUR     9
    #define AUTO_SAL_START_MINUTE   45
    #define AUTO_SAL_RUN_TIME       10
    ReefAngel.AddSalinityExpansion();  // Salinity Expansion Module
    ReefAngel.FeedingModePorts = Port1Bit | Port2Bit | Port5Bit;
    ReefAngel.WaterChangePorts = Port1Bit | Port2Bit | Port5Bit | Port8Bit;
    ReefAngel.OverheatShutoffPorts = Port2Bit | Port3Bit | Port8Bit;
    // Salinity Temp Compensation
    ReefAngel.Salinity.SetCompensation(0);
    ReefAngel.Relay.On( Port3 );
    ReefAngel.Relay.On( Port4 );
        ReefAngel.CustomLabels[0]="ATO Pump";
        ReefAngel.CustomLabels[1]="Skimmer";
        ReefAngel.CustomLabels[2]="Light";
        ReefAngel.CustomLabels[3]="Nero3";
        ReefAngel.CustomLabels[4]="Return Pump";
        ReefAngel.CustomLabels[5]="Unused";
        ReefAngel.CustomLabels[6]="Unused";
        ReefAngel.CustomLabels[7]="Heater";
    ReefAngel.StandardLights( Port2 ); // putting skimmer on timer
    ReefAngel.StandardHeater( Port8 );
     // First 10 minutes after WC disable ATO for port 1
          static time_t wcTimer;
          if (ReefAngel.DisplayedMenu == WATERCHANGE_MODE) wcTimer=now();
          if (now()-wcTimer > 0 && now()-wcTimer < 600) {
          ReefAngel.Relay.Off(Port1);
          else {ReefAngel.SingleATOLow (Port1 );
    // Compute the current time
    int CurrentTime = NumMins(hour(), minute());
    // Compute the starting time for the auto salinity calibration
    int AutoSalStartTime = NumMins(AUTO_SAL_START_HOUR, AUTO_SAL_START_MINUTE);
    // Compute the ending time for the auto salinity calibration by adding in the run time
    int AutoSalEndTime = AutoSalStartTime + AUTO_SAL_RUN_TIME;
    // Check if it's time to start the auto salinity calibration
    if (  AutoSalStartTime == CurrentTime ) {
      // Switch to Salinity Calibration ONLY if we are on the main / default menu
      // Don't switch to the calibration menu if we are doing something else (water change, feeding, etc)
      if ( (ReefAngel.DisplayedMenu == DEFAULT_MENU) || (ReefAngel.DisplayedMenu == MAIN_MENU) ) {
        ReefAngel.ChangeMode = SAL_CALIBRATE_MENU;
    // Check if we are at the end of the Run Time for the auto salinity calibration
    if ( AutoSalEndTime == CurrentTime ) {
      // Simulate a button press ONLY if we are still on the Salinity Calibration menu screen
      if (ReefAngel.DisplayedMenu == SAL_CALIBRATE_MENU) {
        ButtonPress++;
    ReefAngel.Portal( "howaboutme" );
Posted: Sun Apr 25, 2021 2:26 pm
looks ok. your changing of the time looks good and it appears that you just copied my code (which is expected).
Sent from my Pixel 2 using Tapatalk
Posted: Sun Apr 25, 2021 4:03 pm
by howaboutme
Thanks yes. I was more making sure I put your codes in the right place. Will report back.
Posted: Tue Apr 27, 2021 7:04 am
by howaboutme
this morning was the first scheduled auto calibration. looks like everything went smoothly. thank you!
Posted: Fri Apr 30, 2021 5:27 pm
howaboutme wrote:this morning was the first scheduled auto calibration. looks like everything went smoothly. thank you!
awesome!
glad to hear that everything appears to be going good.
