Wave patterns
Re: Wave patterns
Picked up two RW-4's for the 40 gallon breeder which is made up mostly of soft corals and 3 rose bubble tip anemones. My order for two cables came in so I just finished connecting everything and adding some basic code from a few pages back that cycled through reef crest and nutrient export modes. Uploaded the code and saw a blast of water movement then nothing.
Probably have my code in the wrong place I'm guessing because they shot on for a second then nothing. I'll need to clean this up and label the ports on the relay box since it is getting messy. Side note - I just added the wireless adapter and it works great. Question - do I have to disconnect the wireless adapter every time I want to upload new code?
Code:
ReefAngel.AddWifi();
ReefAngel.StandardLights( Port2,9,0,21,0 );
ReefAngel.StandardLights( Port4,9,0,21,0 ); // LED fans
ReefAngel.WavemakerRandom(Port5,60,300);
// ReefAngel.WavemakerRandom(Port5,120,600);
// ReefAngel.WavemakerRandom(Port6,120,600);
// Turn Port5 on/off random cycles that lasts from 25 to 60 secs
// ReefAngel.Relay.Set(Port6,!ReefAngel.Relay.Status(Port5));
// ReefAngel.Relay.Set(Port8,!ReefAngel.Relay.Status(Port7));
// This will turn off both relays at a set time
if (hour()>=20 || hour()<10)
ReefAngel.Relay.Off(Port5); // large power head
ReefAngel.Relay.Off(Port6); // large power head
ReefAngel.Relay.Off(Port4); // LED fans
ReefAngel.Relay.On(Port7); // Small power head for night
ReefAngel.Relay.On(Port8); // Small power head for night
ReefAngel.Relay.Off(Port7);
ReefAngel.Relay.Off(Port8);
// Channel 0 (1000mA max) - 5 Neutral White
// Channel 1 (1000mA max) - 6 Royal Blue + 5 Blue
// Channel 2 (700mA max) - 12 Lime
// Channel 3 (700mA max) - 5 Violet UV + 4 Deep Red (660nm)
ReefAngel.PWM.SetChannel( 0, PWMParabola(10,0,20,0,0,65,0) );
ReefAngel.PWM.SetChannel( 1, PWMParabola(10,0,20,0,0,75,0) );
ReefAngel.PWM.SetChannel( 2, PWMParabola(10,0,20,0,0,65,0) );
ReefAngel.PWM.SetChannel( 3, PWMParabola(10,0,20,0,0,65,0) );
// Testing wave pumps
if (hour()>=16 && hour()<18)
ReefAngel.PWM.SetDaylight( NutrientTransportMode(77,90,3000,true) ); // Nutrient Transport on sync mode
ReefAngel.PWM.SetActinic( NutrientTransportMode(77,90,3000,false) ); // Nutrient Transport on anti-sync mode
else if (hour()>=18 && hour()<16)
ReefAngel.PWM.SetDaylight( ReefCrestMode(50,20,true) ); // ReefCrest at 50% + - 20 on sync mode
ReefAngel.PWM.SetActinic( ReefCrestMode(50,20,false) ); // ReefCrest at 50% + - 20 on anti-sync mode
ReefAngel.Portal( "saf1" );
ReefAngel.DDNS( "saf1-dns.myreefangel.com" ); // Your DDNS is saf1-dns.myreefangel.com
Code:
Re: Wave patterns
I'm not sure about the code, but a quick look it seems right, except it looks like you have the wave mode on ports 5 & 6 and are also using the DC Pump code.
If you don't have the Bluetooth module you will need to unplug the WiFi module every time you want to update your code.
Re: Wave patterns
Yeah, that is odd. Not really sure at this point since I have cruddy notes and they don't look that great in the sketch either
I just re-ran the wizard and it produced something that has at least one side working but not sure if this is right either so I'll need to continue to try. Also those little things can put out some water movement. I accidently had 90 percent I guess and everything was moving around way too much. Caught it and reset to 50 and everything seems pretty happy.
Originally on my power / relay box it was like this. Daylight and Actinic channels not used.
Plug 1 - skimmer (always on, off for feeding)
Plug 2 - Power supply for LED's - set time on/off
Plug 3 - NA
Plug 4 - LED heat sink fans - come on once LED's start up
Plug 5 - large power head powers on at 10 am until 8 pm
Plug 6 - large power head powers on at 10 am until 8 pm
Plug 7 - small power heads only coming on at 10 PM
Plug 8 - small power heads only coming on at 10 PM
The goal is to remove the koralia power heads and just use the RW-4's if I can get them to work together or educated is how I think they work
I am reading it as reef crest daylight is set to sync with actinic set to antisync. So at some time - not sure when, one side shuts down and the other kicks in. Sort of simulating high/low tide. I just don't see that time window or cut off.
New code:
ReefAngel.FeedingModePorts = Port1Bit | Port5Bit | Port6Bit | Port7Bit | Port8Bit;
ReefAngel.WaterChangePorts = Port1Bit | Port5Bit | Port6Bit | Port7Bit | Port8Bit;
ReefAngel.Relay.On( Port4 );
ReefAngel.Relay.On( Port5 );
ReefAngel.StandardLights( Port2,9,0,21,0 ); // power to LED power supply
// ReefAngel.WavemakerRandom( Port5,5,90 ); // Not sure what these are for now
// ReefAngel.WavemakerRandom( Port6,5,90 ); // Not sure what these are for now
// ReefAngel.StandardLights( Port7,9,0,21,0 );
// ReefAngel.StandardLights( Port8,9,0,21,0 );
ReefAngel.DCPump.SetMode( ReefCrest,50,10 );
// ReefAngel.DCPump.ExpansionChannel[0] = None;
// ReefAngel.DCPump.ExpansionChannel[1] = None;
// ReefAngel.DCPump.ExpansionChannel[2] = None;
// ReefAngel.DCPump.ExpansionChannel[3] = None;
// ReefAngel.DCPump.ExpansionChannel[4] = None;
// ReefAngel.DCPump.ExpansionChannel[5] = None;
ReefAngel.DDNS( "saf1-dns.myreefangel.com" ); // Your DDNS is saf1-saf1-dns.myreefangel.com.myreefangel.com
Plug 3 - NA
New code:
Re: Wave patterns
That's not how ReefCrest works. ReefCrest slowly meanders between the midline (50 in your case) by +/- the offset (10 here). When the sync goes up, the antisync goes down. So they both should be on constantly, going between 40 and 60.
Re: Wave patterns
Ok, that makes sense and also what I see although I thought I saw higher than 60 on one side. I'll add a if statement to get them to swap who is anti then.cosmith71 wrote:That's not how ReefCrest works. ReefCrest slowly meanders between the midline (50 in your case) by +/- the offset (10 here). When the sync goes up, the antisync goes down. So they both should be on constantly, going between 40 and 60.
Thanks, appreciate you taking time to explain it.
Re: Wave patterns
You can use tide.IsIncoming() it might be isIncoming as your condition for swapping the channels
Re: Wave patterns
Ok, thanks. I'll see if I can find an example of that. Right now I have the standard reef crest to go to 25 when the lights go off (9 PM). Then standard power when them come on again at 9 AM. I don't know what mode actually does what so I'm just using reef crest for now but would like to get the sides to alternate.
Does it make more sense to change flow patterns or just use one?
if (hour()>=21 || hour()<9)
// Sleep mode - slow things down
ReefAngel.DCPump.SetMode( ReefCrest,25,10 );
// Normal power
// Normal power
Re: Wave patterns
Ok, found the compile error. Case sensitive
Was using uppercase T instead of lowercase t when calling tide. Not sure if this is the right way to set it up but the tide function has the if statement to set PWM sync or anti sync. Then I let my main run window use full power or reduce after lights out.
Thanks.
-scott
Thanks.
-scott
#include <Tide.h> // testing for tide control
Tide tide; // testing for tide control
ReefAngel.Relay.On( Port1 ); // skimmer
// ReefAngel.Relay.On( Port4 ); // LED Fans
ReefAngel.Relay.On( Port5 ); // RW 4 left side facing tank
ReefAngel.Relay.On( Port6 ); // RW 4 right side facing tank
ReefAngel.PWM.SetChannel( 0, PWMParabola(9,0,21,0,0,65,0) );
ReefAngel.PWM.SetChannel( 1, PWMParabola(9,0,21,0,0,75,0) );
ReefAngel.PWM.SetChannel( 2, PWMParabola(9,0,21,0,0,65,0) );
ReefAngel.PWM.SetChannel( 3, PWMParabola(9,0,21,0,0,65,0) );
// ReefAngel.DCPump.SetMode( ReefCrest,55,10 );
// ReefAngel.DCPump.DaylightChannel = Sync;
// ReefAngel.DCPump.ActinicChannel = AntiSync;
// Testing tidal function
if (tide.isIncoming()) {
else {
// Normal power
Re: Wave patterns
Thats perfect! Now if you want to use the tide mode more you can set the parameters for the tide speed to fluctuate through the day and the variation would be based on the MoonPhase() so where you are calling SetMode and giving the ReefCrest speed you could get the speed from the tide class. Also the tide class kind of has a built in night mode at least how I have it set
Re: Wave patterns
Cool, thanks for the information because that is what I'm actually looking for. I know I am only going to get "so" much out of the R4's in a 40 gallon breeder but it is more about learning how this works, the corals, and overall look. I like what they are doing with just this basic routine and imagine the rose bubble tips will love one I get some variation in there.lnevo wrote:Thats perfect! Now if you want to use the tide mode more you can set the parameters for the tide speed to fluctuate through the day and the variation would be based on the MoonPhase() so where you are calling SetMode and giving the ReefCrest speed you could get the speed from the tide class. Also the tide class kind of has a built in night mode at least how I have it set
I don't think my Hammers are enjoying it much but then again it seems they don't like their neighbors, Kenya Trees. Thanks again though - I'll take a look at this moon phase and see how the night mode works. I'm not using memory settings so I have to disconnect wife to make any changes. I've not messed with that feature yet.
Re: Wave patterns
The tide mode speeds adjust based on moon phase. You dont need to do anything separate
Re: Wave patterns
And no explicit nite mode just the way the timing works.
Re: Wave patterns
Ok, thanks lnevo.
I'm going pretty slow with this one since the RW-4's can put out a lot of movement in the 40 gallon breeder. The fish for the most part have been around 4 years or so but I recently added a pair of baby clown fish and a blenny which are young / small.
This is a really cool library. I'm really glad I picked up the cables and power heads for the reef angel. It is a lot of fun and educational to boot. I don't remember the last time I was reading up on tidal movement and moon phase.
Re: Wave patterns
I ran a few different patterns the last couple of days and I have to say I like the tidal swell mode the best so far. Short pulse was interesting and I could actually see a wave on the top of the surface. I think I'll try tidal swell for the whole day and let it go to reef crest mode at night. While it is working not 100% sure I'm calling it correctly - the tide swell that is.
I am using the tide function / routine to set the daylight and actinic channels sync and then just calling tidal swell and passing in 80% power with 20 being the offset between the two. I am assuming that is correct anyway and will let the sides change accordingly. Or do I leave duration to off or 0 and let the tide routine handle which side to ramp up, what time, and its own duration.
ReefAngel.PWM.SetChannel( 1, PWMParabola(9,0,21,0,0,90,0) );
ReefAngel.PWM.SetChannel( 2, PWMParabola(9,0,21,0,0,55,0) );
else {
// Full power to run during the day with lights on
// Start at 9 AM run through 9 PM
ReefAngel.DCPump.SetMode( TidalSwell,80,20 );
Re: Wave patterns
Ok, wondering if I could get some more help if possible. I thought I figured it out but I'm starting to think I am misunderstanding something basic. I am trying to use the tide function and have the basic routine as:
else {
Then later in the custom code area I'm checking time to either slow it down or fall into the normal reef crest mode. My question is do I need the night time mode if the lunar/moon slows it down? If so, what is the minimum speed it drops to or do I need to set it somewhere. Same question applies to any settings to tide if I only want one high and low tide through out the day. I think I read somewhere in another post here that it would do both twice?
I am calling the reefcrest mode like:
ReefAngel.DCPump.SetMode( ReefCrest,50,30 );
What I am trying to avoid is blasting the center of the tank when both power heads are on rather than one doing most of the work most of the day like incoming tide or outgoing. I'm doing something wrong or misunderstand how to have one side run higher power for longer than the other.
Thanks - if this is covered somewhere just direct me. I'm missing something basic
else {
Re: Wave patterns
dose any one know if you can add a random pattern to this old code
Sine
Contribution of Discocarp
viewtopic.php?f=2&t=2386&p=18240
PulseMinSpeed - % for minimal speed
PulseMaxSpeed - % for maximum speed
PulseDuration - Duration (seconds) in which the entire sine wave will take to complete.
PulseSync - true if you want to sync pumps to same cycle. one false and one true if you want to anti-sync pumps.
CODE: SELECT ALL
byte SineMode(byte PulseMinSpeed, byte PulseMaxSpeed, int PulseDuration, boolean PulseSync) {
double x,y;
x=double(now()%(PulseDuration));
x/=PulseDuration;
x*=2.0*PI;
if (!PulseSync) x+=PI; // shift the sine wave for the right pump
y=sin(x);// y is now between -1 and 1
y+=1.0; // y is now between 0 and 2
y/=2.0; // y is now between 0 and 1
// now compute the tunze speed
y*=double(PulseMaxSpeed-PulseMinSpeed);
y+=double(PulseMinSpeed);
y+=0.5; // for proper rounding
// y is now between PulseMinSpeed and PulseMaxSpeed, constrain for safety
return constrain(byte(y),30,100);
Sine
CODE: SELECT ALL
double x,y;
x/=PulseDuration;
x*=2.0*PI;
