Page 5 of 5
Re: My Jebao "Else" mode
Posted: Mon Jun 09, 2014 7:52 pm
I think so, but I'm not sure. It really shouldn't make a difference because he had UseMemory=true and then if his memory is set to custom mode then it should do nothing while the PWM commands should have taken affect. I'm not sure.
Posted: Tue Jun 10, 2014 4:45 am
by iratefrizz
hey guys, sorry I haven't been keeping up. the pulse mode was leftover from the wizard.
how exactly do i turn it on custom?
I would like to control it via portal if someone could tell me how but if not its no different than it is now. as I do not control it via portal now.
Posted: Tue Jun 10, 2014 5:00 am
by howaboutme
iratefrizz wrote:hey guys, sorry I haven't been keeping up. the pulse mode was leftover from the wizard.
I assume you have the wifi module? Go to the portal and then internal memory and then dcpumps. Choose custom there. See what happens.
Posted: Wed Jun 11, 2014 10:19 pm
by iratefrizz
ok, I will try that tonight. I have to reste my router as I think my port forwarding has messed up. I can't acccess my
RA from phone (outside of personal network) OR from Portal website.
(Edit) finally figured out what I was messing up on port forwarding and causing issues with portal. I set the dcpump to custom.
under pumps it says 255% for duration of 255.
so there must be an issue. I will try and reload the most recent suggested code to see if that works.
Thank you again for assistance
