PaulTurner911 Code
- Sacohen
- lnevo
Re: PaulTurner911 Code
Roberto could that be screwing with the portal though?
The mode should show 11 since its part of our custom mode.
This could be part of the issue...
- lnevo
Do you think it would be better to fix it on the backend? I mean if someone didn't initialize memory they would have the 255 issue we saw earlier? Either way I can fix in the INO. Steve, can you update your thread with latest version if its not already?
- Sacohen
Paulturner911
Is there anyway to test the WP pump (I trashed the controller day 1), mines not running. Gotta be a way....
It would happen ever once and a while with my current code on random, but I could power cycle and all was well. No longer the case, she unresponsive. I went to the portal and changed the mode, it reflects on the controllers screen. Ive checked all connections, the ac/dc trans for the WP, the power to Jebo adapter, adapter to the PWM, and adapter to the WP...TWICE.
But the pump isnt working.
Anyhelp in trouble shooting would be great. Thanks
sabo
Tried cleaning the pump?
Paulturner911
Yeah, I tore into it pretty good. Also, tried it with the factory controller someone let me use.
- Sacohen
Paul;
PM me your address. I'll send you a spare I have if you promise to send it back.
You don't need the PS do you? I don't have a spare for that.
That brings up a question, you're sure you're getting power out of the PS.
- lnevo
Just adding a link to Paul's most recent code, since there's about 15 pages of me and Steve troubleshooting his... lol
http://forum.reefangel.com/viewtopic.php?p=32040#p32040
Paulturner911
You SIR are a gentleman and a scholar!!!lnevo wrote:Just adding a link to Paul's most recent code, since there's about 15 pages of me and Steve troubleshooting his... lol
Just paypal'd Roberto some money for a second jeabo adapter, pumps and harness should arrive soon, patience is a virtue.
Lee, Id like to be in the same boat as Scohen running them antisync and retaining current functionality.
Sorry to beat a dead horse, but could you please run down the duration and speed setup again?!? I think I remember duration in the portal does nothing, but speed has a variance that is defined somewhere hardcoded to make the pump run from 25%-75%. Just dont remember where to define this value and what it should be.
Thank you!!
- Sacohen
Maybe Lee can add more to it, or explain it better, but this is what I have in my code of the speed variable.
ReefAngel.DCPump.Speed=ElseMode(InternalMemory.DCPumpSpeed_read(),20,true ); // ElseMode on sync mode, Portal Speed Setting +/- 20%- lnevo
Speed is Speed and Duration is Duration. You have nothing in your code that will make anything change versus what's set in the portal. No Variance that I can find. You only had one pump... so would not even mean anything to you initially...
I sent you how to activate the second pump in the anti-sync mode... You just need to define the channel and what it is going to be Sync/Anti-Sync.
Lee
Lee
Paulturner911
Got it.
You make it sound so simple.
And make me feel like an ass for asking.
There is something that we used to limit the pumps range of power, effectivly stopping the pump from running full power. For whatever reason I thought it had to do with speed and duration.
Paulturner911
// Change this to what you want your min/max based on vortech speedlnevo wrote:Speed is Speed and Duration is Duration. You have nothing in your code that will make anything change versus what's set in the portal. No Variance that I can find. You only had one pump... so would not even mean anything to you initially...
Lee
// This is for those functions that take both, but only one memory slot.
int minOffset=25;
int maxOffset=25;
This is what I was thinking....isnt this where you would define the range of the pump (in relation to portal speed)?
PORTAL SPEED=60(currently) +/-25
Pump should run 35-85?
I must not have the correct understanding (not uncommon)
Trying to refresh my noodle.
- Sacohen
We never did fix the problem.lnevo wrote:Just adding a link to Paul's most recent code, since there's about 15 pages of me and Steve troubleshooting his... lol
I think you said you were going to fix it on the back end.
I can start a new thread for that issue if you want.
- lnevo
Lol what was the issue that you couldnt set the % on the 2nd pump differently?
Paulturner911
Badass! Got everything working, just need the pump!
I also added my skimmer to the feed mode and water change so it power cycles instead of running when its not needed. Added Long Pulse to the random...atleast it didnt give me an error, so I think I did
Thanks for the help!
I hadnt touched this stuff in ages, had to do the drivers and software install again since I replaced the HD on my PC. Kinda started to sweat for a min, but it all worked out
ReefAngel.FeedingModePorts = Port1Bit | Port2Bit | Port6Bit | Port7Bit | Port8Bit;
ReefAngel.WaterChangePorts = Port1Bit | Port2Bit | Port6Bit | Port7Bit | Port8Bit;
ReefAngel.LightsOnPorts = Port2Bit | Port3Bit | Port7Bit | Port8Bit;
ReefAngel.OverheatShutoffPorts = Port3Bit | Port6Bit | Port7Bit | Port8Bit;
ReefAngel.DayLights( Port1 ); // Return Pump
ReefAngel.StandardFan( Port2 ); // Canopy Fans
ReefAngel.ActinicLights( Port3 ); // Actinic LEDS
//Port4 Kalk/ATO
//Port5 Kalk Stir
ReefAngel.DayLights( Port6 );//Port 6 Skimmer
ReefAngel.DayLights( Port7 ); // MH 1
ReefAngel.DayLights( Port8 ); //MH 2
//Moonlight Phase 9pm-10am (CH4-CH5)
if ( (hour() >=10) && (hour() <21) )
ReefAngel.PWM.SetChannel( 4,(0) );
ReefAngel.PWM.SetChannel( 5,(0) );
//Over Flow Protection
ReefAngel.Relay.On(Port1);
ReefAngel.Relay.Off(Port1);
//ATO Protection
ReefAngel.Relay.On(Port4);
ReefAngel.Relay.Off(Port4);
//Kalk Dose 60sec @ 11pm-12pm (every 15min)
if (hour() >=23 || hour() < 12)
ReefAngel.Relay.Set(Port4, now()%900<60);
//Kalk Stir 12pm-1pm
if (hour() >=12 & hour() < 13)
ReefAngel.Relay.On(Port5);
ReefAngel.Relay.Off(Port5);
///// Place your custom code below here
static int rmode;
byte modes[] = { ReefCrest, TidalSwell, ShortPulse, LongPulse, NutrientTransport };
changeMode=false;
static unsigned long feeding;
if (now()-feeding<900) {
// First 15 minutes after feeding mode stops. Return Pump is off
// First 15 minutes after feeding mode stops. Smart_NTM
} else if (now()-feeding<4500) { // 15 minutes plus 1 hour
// Continue NTM for the next 60 minutes (75 minutes total)
} else if (now()%SECS_PER_DAY<30600 || now()%SECS_PER_DAY>=81000) { // 8:30am / 10:30pm
// Night mode (go to 30%)
ReefAngel.DCPump.Speed=30;
ReefAngel.DCPump.UseMemory=true; // Will reset all values from memory-
Paulturner911
Right back at it of course...
Added else mode after hacking around with SaCohens code.
- Sacohen
That was one issue, but the one that didn't get resolved is that the portal shows every option available to the RA when it is in Else Mode.lnevo wrote:Lol what was the issue that you couldnt set the % on the 2nd pump differently?
I started a new thread so we don't fill up Paul's thread with this issue,
http://forum.reefangel.com/viewtopic.php?f=12&t=4696
Paulturner911
if (rmode==Else) {
ReefAngel.DCPump.Speed=ElseMode(InternalMemory.DCPumpSpeed_read(),25,true ); // ElseMode on sync mode, Portal Speed Setting +/- 20%
} else {- lnevo
Its constant because we want the pump set at the speed that elsemode calculates. We could also put it in Custom mode here but then you would have to call the pwm commands directly.
Paulturner911
OK, I was trying to replicate his portal issue showing EVERYTHING, since I am running pretty much the same code.
Lee, If you get a min, please glance over my code and tell me if you see any issues in the stuff I cut and pasted from Sacohens code. Like I said, it uploaded
Ive run feedmode and all seemed well.
Ill keep an eye out for else mode and wonky portal display. Is it only the day (in my case) that random calls ELSEMODE that the portal shows this?
- lnevo
Paulturner911
Sorry Lee, I must have neglected to attach it. Ill plug it in later this evening.lnevo wrote:Where is it?
Everything seems ok, I just took my old code and added a few things I saw in Sacohens code that seemed like it was needed for Else mode.
Just kept clicking away and reading bits and pieces of threads.
Paulturner911
This is current:
//Port4 Kalk/ATO
//Port5 Kalk Stir
//ATO Protection
static int rmode;
// Add Else Mode definition..
const int Else=16;
byte modes[] = { Lagoon, Else, ReefCrest, TidalSwell, ShortPulse, LongPulse, NutrientTransport };
changeMode=false;
if (rmode==Else) {
ReefAngel.DCPump.Speed=ElseMode(InternalMemory.DCPumpSpeed_read(),25,true ); // ElseMode on sync mode, Portal Speed Setting +/- 25%
ReefAngel.Portal( "paulturner911" );
int x,y;
// Dimming Expansion
x = 15;
y = 2;
for ( int a=0;a<6;a++ )
if ( a>2 ) x = 75;
if ( a==3 ) y = 2;
y += 10;
if (WaveSync)
return NewSpeed;
return AntiSpeed;
}- lnevo
Paulturner911
Current code below. I am having an issue with the 2 DC pumps, sometimes the screen on the controller shows values but the pumps arent working. Its random, maybe an issue with else mode?
How can I activate else mode to see?
//Port4 Kalk/ATO
//Port5 Kalk Stir
//ATO Protection
static int rmode;
const int Else=16;
changeMode=false;
if (modes[rmode]==Else) {
int x,y;
x = 15;
y = 2;
if ( a>2 ) x = 75;
if ( a==3 ) y = 2;
y += 10;
if (WaveSync)
return NewSpeed;
return AntiSpeed;
