PaulTurner911 Code
Re: PaulTurner911 Code
lnevo wrote:Lol what was the issue that you couldnt set the % on the 2nd pump differently?
That was one issue, but the one that didn't get resolved is that the portal shows every option available to the RA when it is in Else Mode.
I started a new thread so we don't fill up Paul's thread with this issue,
http://forum.reefangel.com/viewtopic.php?f=12&t=4696
Paulturner911
Post by Paulturner911 »
if (rmode==Else) {
    ReefAngel.DCPump.Speed=ElseMode(InternalMemory.DCPumpSpeed_read(),25,true );    // ElseMode on sync mode, Portal Speed Setting +/- 20%
Should this call "else" when "constant" is selected?
Its constant because we want the pump set at the speed that elsemode calculates. We could also put it in Custom mode here but then you would have to call the pwm commands directly.
Paulturner911
OK, I was trying to replicate his portal issue showing EVERYTHING, since I am running pretty much the same code.
Lee, If you get a min, please glance over my code and tell me if you see any issues in the stuff I cut and pasted from Sacohens code. Like I said, it uploaded :) Ive run feedmode and all seemed well.
Ill keep an eye out for else mode and wonky portal display. Is it only the day (in my case) that random calls ELSEMODE that the portal shows this?
Where is it?
Paulturner911
lnevo wrote:Where is it?
Sorry Lee, I must have neglected to attach it. Ill plug it in later this evening.
Everything seems ok, I just took my old code and added a few things I saw in Sacohens code that seemed like it was needed for Else mode.
Just kept clicking away and reading bits and pieces of threads.
Paulturner911
This is current:
ReefAngel.FeedingModePorts = Port1Bit | Port2Bit | Port6Bit | Port7Bit | Port8Bit;
ReefAngel.WaterChangePorts = Port1Bit | Port2Bit | Port6Bit | Port7Bit | Port8Bit;
ReefAngel.LightsOnPorts = Port2Bit | Port3Bit | Port7Bit | Port8Bit;
ReefAngel.OverheatShutoffPorts = Port3Bit | Port6Bit | Port7Bit | Port8Bit;
ReefAngel.DayLights( Port1 ); // Return Pump
ReefAngel.StandardFan( Port2 ); // Canopy Fans
ReefAngel.ActinicLights( Port3 ); // Actinic LEDS
//Port4 Kalk/ATO
//Port5 Kalk Stir
ReefAngel.DayLights( Port6 );//Port 6 Skimmer
ReefAngel.DayLights( Port7 ); // MH 1
ReefAngel.DayLights( Port8 ); //MH 2
//Moonlight Phase 9pm-10am (CH4-CH5)
if ( (hour() >=10) && (hour() <21) )
ReefAngel.PWM.SetChannel( 4,(0) );
ReefAngel.PWM.SetChannel( 5,(0) );
//Over Flow Protection
ReefAngel.Relay.On(Port1);
ReefAngel.Relay.Off(Port1);
//ATO Protection
ReefAngel.Relay.On(Port4);
ReefAngel.Relay.Off(Port4);
//Kalk Dose 60sec @ 11pm-12pm (every 15min)
if (hour() >=23 || hour() < 12)
ReefAngel.Relay.Set(Port4, now()%900<60);
//Kalk Stir 12pm-1pm
if (hour() >=12 & hour() < 13)
ReefAngel.Relay.On(Port5);
ReefAngel.Relay.Off(Port5);
///// Place your custom code below here
static int rmode;
// Add Else Mode definition..
const int Else=16;
byte modes[] = { Lagoon, Else, ReefCrest, TidalSwell, ShortPulse, LongPulse, NutrientTransport };
changeMode=false;
static unsigned long feeding;
if (now()-feeding<900) {
  // First 15 minutes after feeding mode stops. Return Pump is off
  // First 15 minutes after feeding mode stops. Smart_NTM
} else if (now()-feeding<4500) { // 15 minutes plus 1 hour
  // Continue NTM for the next 60 minutes (75 minutes total)
} else if (now()%SECS_PER_DAY<30600 || now()%SECS_PER_DAY>=81000) { // 8:30am / 10:30pm
  // Night mode (go to 30%)
  ReefAngel.DCPump.Speed=30;
  if (rmode==Else) {
    ReefAngel.DCPump.Speed=ElseMode(InternalMemory.DCPumpSpeed_read(),25,true );    // ElseMode on sync mode, Portal Speed Setting +/- 25%
    ReefAngel.DCPump.Mode=modes[rmode];  // Put the mode to the random mode :)
ReefAngel.Portal( "paulturner911" );
int x,y;
// Dimming Expansion
x = 15;
y = 2;
for ( int a=0;a<6;a++ )
if ( a>2 ) x = 75;
if ( a==3 ) y = 2;
y += 10;
  static unsigned long LastChange=millis();        // Set the inital time that the last change occurred
  static int Delay = random( 500, 3000);           // Set the initial delay
  static int NewSpeed = MidPoint;                  // Set the initial speed
  static int AntiSpeed = MidPoint;                 // Set the initial anti sync speed
  if ((millis()-LastChange) > Delay)               // Check if the delay has elapsed
    Delay=random(500,5000);                        // If so, come up with a new delay
    int ChangeUp = random(Offset);                 // Amount to go up or down
    if (random(100)<50)                            // 50/50 chance of speed going up or going down
    LastChange=millis();                           // Reset the time of the last change
  if (WaveSync)
    return NewSpeed;
    return AntiSpeed;
Change this line
  if (rmode==Else) {
to
  if (modes[rmode]==Else) {
Paulturner911
Paulturner911
Current code below. I am having an issue with the 2 DC pumps, sometimes the screen on the controller shows values but the pumps arent working. Its random, maybe an issue with else mode?
How can I activate else mode to see?
//Port4 Kalk/ATO
//Port5 Kalk Stir
//ATO Protection
static int rmode;
const int Else=16;
changeMode=false;
int x,y;
x = 15;
y = 2;
if ( a>2 ) x = 75;
if ( a==3 ) y = 2;
y += 10;
  if (WaveSync)
    return NewSpeed;
    return AntiSpeed;
Remove everything else from the list of options except else mode and then that will be the one that it chooses.
Paulturner911
I'm not sure how to.
No way to call it from a memory location manually?
Ok, I think I understand.
Change this...
To this...
byte modes[] = { Else };
Paulturner911
Could someone refresh my memory on how to have Relay 6 run constant, unless Im in feed mode?
I didnt realize it but when I added the skimmer it runs on the same schedule as my MH lamps. I would like it to be on all of the time unless its in feed mode.
Any help is greatly apprerciated.
Thank you
You need 2 things....
This in // Ports toggled in Feeding Mode
And then in // Ports that are always on
If you want to delay the start after feeding mode by 10 min so your main pump gets up to speed and your water leve gets back to normal you can add this in the loop section...
ReefAngel.Relay.DelayedOn( Port6,10 );
Paulturner911
Great! Thank you
Paulturner911
I HAVE PICKED UP A NEW TANK!!!
Im wondering if I should just run the wizard and start over, but cut and paste some "custom lines" ??? Please advise which would be easier.
Ditching a few things -
MH (port7&8)
FANS (port2)
ACTINIC (port3)
I have a few things that Id like to add-
3 Ecoray112DX whites/red (port7) Actinics (port8)
Chiller (port2) Should function similar to the fan settings? * NEEDS TO SHUT DOWN IN FEED/WATERCHANGE MODES
Skimmer (port3) ** Id like it off for 2 hours after feedmode activation
ANY AND ALL INPUT IS WELCOMED AND VERY APPRECIATED
I would keep what you have and go in and manually cut out what you don't want.
Then use the wizard to create the code you want to add and paste it in to your existing code.
Paulturner911
Ill give it a try!! thanks
Paulturner911
I decided to keep my code and change a few relays and make it work for the most part. I have the following questions:
Chiller will now be on port 2. It has a 2 deg variance, if I want the tank at 78 i would set this to 80?
ReefAngel.LCD.DrawOutletBox( 12, 80, TempRelay );
Wouldnt it then turn the chiller off when it goes to 79?
Skimmer is on port 6- Does shut off in feedmode , but I would like this to have a 2 hour delay after feed mode. How would i code this?
Thanks guys!
No that code is for screen drawing. Post your code and I'll be able to help
Paulturner911
ReefAngel.FeedingModePorts = Port1Bit | Port2Bit | Port6Bit | Port7Bit ;
ReefAngel.WaterChangePorts = Port1Bit | Port2Bit | Port6Bit | Port7Bit ;
ReefAngel.LightsOnPorts =  Port3Bit | Port7Bit ;
ReefAngel.OverheatShutoffPorts = Port1Bit | Port3Bit | Port6Bit | Port7Bit ;
//Port 2 Chiller
//Port4 Kalk/ATO
//Port5 Kalk Stir
ReefAngel.DayLights( Port6 );// Skimmer
ReefAngel.DayLights( Port7 ); // White LEDS
//Port8 Empty
//ATO Protection
ReefAngel.Relay.Set(Port4, now()%900<65);
static int rmode;
const int Else=16;
byte modes[] = { Else, Lagoon, Else, ReefCrest, ShortPulse, LongPulse, NutrientTransport };
changeMode=false;
int x,y;
x = 15;
y = 2;
if ( a>2 ) x = 75;
if ( a==3 ) y = 2;
y += 10;
  if (WaveSync)
    return NewSpeed;
    return AntiSpeed;
Paulturner911
I've noticed that the skimmer (port6) is functioning like the old mh ports 7/8 as far as off and on schedule.
Is like this to run 24/7 unless water change or feed mode has been activated.
Port 6 is included in Feeding, Water Change and Overheating off.
You also have it as Always on.
The one line of code that refers to Port 6 that I see has no time associated to it.
it just this...
Paulturner911
Port 6 definatly does not run 24/7
It does shut off for WC and feed mode correct.
I would like it to stay off for 2 hours after either.
What should it read? It's currently shitting down with the "daylight" LEDs.
Thank you
I think it has to do with this ReefAngel.DayLights( Port6 );// Skimmer
Just remove this line ReefAngel.DayLights( Port6 );// Skimmer and it should stay on all the time except Feeding, Water Change and Overheat because of this...
You can probably remove i the Port6Bit from the Overheat as well, you don't need to turn off the skimmer during an overheat situation.
He wanted a delay so use DelayedOn instead of On and put 120 as the second argument for 2 hours.
Paulturner911
ReefAngel.Relay.DelayedOn( Port6 );120;
will this work?
ReefAngel.Relay.DelayedOn(Port6, 120);
