Custom Menu Generator
- lnevo
- Sacohen
Re: Custom Menu Generator
Here you go.
a#include <ReefAngel_Features.h>
#include <avr/pgmspace.h>
prog_char menu2_label[] PROGMEM = "Accilmate";
prog_char menu3_label[] PROGMEM = "Lights On";
prog_char menu4_label[] PROGMEM = "Lights Off";
prog_char menu5_label[] PROGMEM = "Calibrate PH";
prog_char menu6_label[] PROGMEM = "Calibrate Water Level";
prog_char menu7_label[] PROGMEM = "Clear ATO ";
prog_char menu8_label[] PROGMEM = "Clear Overheat";
menu0_label, menu1_label, menu2_label, menu3_label, menu4_label, menu5_label, menu6_label, menu7_label, menu8_label };
void MenuEntry1()
ReefAngel.DisplayMenuEntry("Item 1");ReefAngel.FeedingModeStart();
void MenuEntry2()
ReefAngel.DisplayMenuEntry("Item 2");ReefAngel.WaterChangeModeStart();
void MenuEntry3()
ReefAngel.DisplayMenuEntry("Item 3");ReefAngel.Relay.Override(Port6, ~bitRead(ReefAngel.Relay.RelayMaskOff, Port6Bit)*2);
void MenuEntry4()
ReefAngel.DisplayMenuEntry("Item 4");ReefAngel.Relay.RelayMaskOn = ReefAngel.LightsOnPorts;
#ifdef RelayExp
ReefAngel.Relay.RelayMaskOnE[i] = ReefAngel.LightsOnPortsE[i];
#endif // RelayExp
ReefAngel.Relay.Write();
void MenuEntry5()
ReefAngel.DisplayMenuEntry("Item 5");ReefAngel.Relay.RelayMaskOn = 0;
#ifdef RelayExp
ReefAngel.Relay.RelayMaskOnE[i] = 0;
#endif // RelayExp
void MenuEntry6()
ReefAngel.DisplayMenuEntry("Item 6");ReefAngel.SetupCalibratePH();
void MenuEntry7()
ReefAngel.DisplayMenuEntry("Item 7");{
ReefAngel.SetupCalibrateWaterLevel();
void MenuEntry8()
ReefAngel.DisplayMenuEntry("Item 8");ReefAngel.ATOClear();
void MenuEntry9()
ReefAngel.DisplayMenuEntry("Item 9");ReefAngel.OverheatClear();
unsigned long ATOUpdate=0;
// Initialize the menu
ReefAngel.WaterChangePorts = Port4Bit | Port6Bit;
ReefAngel.Relay.On( Port4 );
ReefAngel.StandardLights( Port1,12,0,22,0 );
ReefAngel.StandardLights( Port2,13,0,21,0 );
ReefAngel.Relay.Set( Port3, !ReefAngel.Relay.Status( Port1 ) );
ReefAngel.StandardLights( Port7,13,0,21,0 );
ReefAngel.Relay.Set(Port5,(now()-3600)%21600<1200); // Runs for 1200s every 21600 seconds
ReefAngel.Relay.Set(Port8,((now()-3600)-1200)%21600<1200); // Runs for 1200s every 21600 seconds with 1200s offset
ReefAngel.WaterLevelATO(Port6,720,30,30); // Enable ATO the ATO
if (ReefAngel.Relay.Status(Port5)) // Check to see if port 5 is on and update time is empty
ATOUpdate = now(); // If so, set the update time to now
if (now() - ATOUpdate < 120) // If it hasnt been 120 seconds turn off the port
ReefAngel.WaterLevelATO(Port6,720,0,1);
ReefAngel.PWM.SetActinic(MyCustomWave(50));
if( ReefAngel.DisplayedMenu==FEEDING_MODE ) ReefAngel.PWM.SetActinic(0);
if( ReefAngel.DisplayedMenu==WATERCHANGE_MODE ) ReefAngel.PWM.SetActinic(0);
if (hour()<12 || hour()>=22) ReefAngel.PWM.SetActinic(30);
ReefAngel.Portal( "Sacohen","Seth0310" );
int x,y;
// Water Level
byte MyCustomWave(byte maxspeed)
static byte randomspeed=0;
if (now()%11<5)
return randomspeed;
else if (now()%11>=5 && now()%11<10)
return maxspeed;
randomspeed=random(35,maxspeed);
return 0;
Try this:
void MenuEntry4()
ReefAngel.LightsOn();
void MenuEntry5()
ReefAngel.LightsOff();
- Sacohen
Tried that Roberto and same thing. Nothing happened.
It's showing your ports are on. Nothing is going to happen when ports are on. LightsOn() would override on and LightsOff() just cancels the override. It doesn't actually override it off.
So, if your lights are already on, overriding it on would do nothing.
- Sacohen
Ok. Sorry. I thought it would over ride then to turn off if they were on too.
They are working properly.
The other code I had probably worked too.
