Walk Through to get you started with RAGen
TanksNStuff
Re: Walk Through to get you started with RAGen
Post by TanksNStuff »
Yes, I was getting errors when trying to open RAGen. I kept uninstalling / reinstalling thinking that there was an install problem. I always ran the install "as administrator" too (Vista Ultimate 64bit).
I kept trying to wipe my comp clean from all Arduino / RA software... then start fresh with installing the Arduino installer, which as I said kept increasing the COM port #.
I was able to open RAGen after running the library updater. But then I had issues with the Client Suite not working right.
Could part of the issue also be that I still reverted back to the Demo code after doing the tutorials? Not sure if that mixed with installing Dev Libs is throwing a wrench into everything.
Yeah, the Client will only work with code that was generated by RAGen and also you have to make sure to checkmark wifi on the features tab.
The Demo code is not going to work with anything :( It's just too outdated.
The reason RAGen crashes is the wrong paths and fixing is is explained in the post I previously posted.
TanksNStuff
I figured that might be part of it. I'm slowly picking all this up through trial and error. Unfortunately, there seems to be more error than trial. :lol:
Seriously though, I'm seeing what this controller is capable of and I'm getting more confidence with it as I go.
The path error will be fixed with the next release. Just have lots of other "cool" things to add to it to make it function better than ever. :)
TanksNStuff
Sounds good Curt. Will that be out in the next day or two or slightly longer? If so, I may just wait for the new release, if not, I'll do the fix that Seedlessone posted.
Longer than a day or two. The release should coincide with the next major library release which isn't quite ready to go yet. Lots of big stuff that Roberto has been working on plus a few additions by myself.
I'd suggest using the fix. It will get you going without any delay.
TanksNStuff
Roger that. Is there a post somewhere showing what new goodies are planned for this next big release?
TanksNStuff wrote:Roger that. Is there a post somewhere showing what new goodies are planned for this next big release?
No. But, I can give you a little preview....
  • Inclusion of ALL (yes, I said ALL) currently available features, in a check-able list
  • Ability to Save only the features file to update it if necessary
  • Compatibility with Arduino 1.0 (handled with a new library release, 0.9.0)
  • Change of PDE tab to be Main Relay
  • Folder locations are preset and fixed (for arduino, sketch and library folders)
  • Moved Wavemakers to default on Ports 5 & 6 respectively, as the relay box is designed for this
  • Development libraries mode is the default. Standard libraries still exist but are discouraged.
  • A "Show Installed Libraries" box to display what the library version is that RAGen finds and is using.
Ignore the PDE / INO tab, that now says Main Relay
That's what I've got so far. There might be the ability to set the number of expansion relays for the controller but no customizing the relay boxes yet. There might also be the ability to edit and create a custom menu inside the application. I've also got some other ideas too, but I don't know if they will be included or not....just depends on how much time I have available.
TanksNStuff
Wow! That is a big update/improvement list.
Did the Arduino 1.0 release delay the RAGen release? Or was some of the new features added as a result of Arduino 1.0?
If you could add the customization of the expansion relay boxes to this, there wouldn't be much more I would ask for! Big thumbs up Curt.
TanksNStuff wrote:Wow! That is a big update/improvement list.
The Arduino release made for some significant changes to the libraries. With that being said, we made other big changes at the same time since it just maid sense. With the big change to the libraries, RAGen needed updating.
Also, I had been working on some concepts of an improvement to RAGen for over 6 months. This just forced me to make the changes.
Customization to the expansion relay boxes are definitely desirable and planned but more testing is needed to make sure that my ideas will work properly. Baby steps. :)
frostyballz
Post by frostyballz »
so just recieved my RA today and was wondering, using the new ragen how do i adjust the times and settings for each port? or do i have to code that
You can either generate an internal memory file on RAGen or change it with the Client or the smart phone phone apps.
On RAGen, go to Controller->Internal Memory
frostyballz
dont have the WIFI module, so the smartphone app is out (unless i can use without WIFI) but the internal memory portion was what i needed, thanks
grafspee1217
Post by grafspee1217 »
I connected my new Reef Angel today. I downloaded the library update tool and it downloaded the latest development libraries. I generated the internal memory code and when I tried to upload it I get a compiling error.
This is what I get:
// Autogenerated file by RAGen (v1.2.1.158), (03/23/2012 20:25)
// Memory_032312_2025.ino
// This file sets the default values to the Internal Memory
#include <Globals.h>
#include <Time.h>
#include <OneWire.h>
#include <RA_NokiaLCD.h>
#include <avr/pgmspace.h>
#include <InternalEEPROM.h>
#include <Wire.h>
#include <Memory.h>
RA_NokiaLCD e;
    e.Init();
    e.BacklightOn();
    InternalMemory.MHOnHour_write(8);
    InternalMemory.MHOnMinute_write(0);
    InternalMemory.MHOffHour_write(15);
    InternalMemory.MHOffMinute_write(0);
    InternalMemory.MHDelay_write(5);
    InternalMemory.StdLightsOnHour_write(8);
    InternalMemory.StdLightsOffHour_write(15);
    InternalMemory.StdLightsOffMinute_write(0);
    InternalMemory.DP1Timer_write(10);
    InternalMemory.DP1RepeatInterval_write(60);
    InternalMemory.DP2RepeatInterval_write(60);
    InternalMemory.ATOTimeout_write(60);
    InternalMemory.ATOHighTimeout_write(60);
    InternalMemory.LEDPWMActinic_write(49);
    InternalMemory.LEDPWMDaylight_write(50);
    InternalMemory.WM1Timer_write(200);
    InternalMemory.WM2Timer_write(354);
    InternalMemory.HeaterTempOn_write(780);
    InternalMemory.HeaterTempOff_write(791);
    InternalMemory.ChillerTempOn_write(810);
    InternalMemory.ChillerTempOff_write(785);
    InternalMemory.OverheatTemp_write(850);
    InternalMemory.PHMax_write(840);
    InternalMemory.PHMin_write(550);
    InternalMemory.SalMax_write(2550);
    InternalMemory.RFMode_write(Constant);
    InternalMemory.RFSpeed_write(140);
    InternalMemory.RFDuration_write(8);
    InternalMemory.PWMSlopeStartD_write(15);
    InternalMemory.PWMSlopeEndD_write(128);
    InternalMemory.PWMSlopeDurationD_write(60);
    InternalMemory.PWMSlopeStartA_write(15);
    InternalMemory.PWMSlopeEndA_write(128);
    InternalMemory.PWMSlopeDurationA_write(60);
    // display success screen
    e.DrawText(COLOR_BLACK, COLOR_WHITE, MENU_START_COL, MENU_START_ROW*2, "Internal Memory Set");
    e.DrawText(COLOR_BLACK, COLOR_WHITE, MENU_START_COL, MENU_START_ROW*4, "Now load your");
    e.DrawText(COLOR_BLACK, COLOR_WHITE, MENU_START_COL, MENU_START_ROW*5, " RA code file");
    delay(5000);
The error I get is:
C:\Users\Adrian\Documents\Arduino\libraries\RA_NokiaLCD\RA_NokiaLCD.cpp: In member function 'void RA_NokiaLCD::DrawEEPromImage(int, int, byte, byte, int, int)':
C:\Users\Adrian\Documents\Arduino\libraries\RA_NokiaLCD\RA_NokiaLCD.cpp:1158: error: 'class TwoWire' has no member named 'write'
C:\Users\Adrian\Documents\Arduino\libraries\RA_NokiaLCD\RA_NokiaLCD.cpp:1159: error: 'class TwoWire' has no member named 'write'
C:\Users\Adrian\Documents\Arduino\libraries\RA_NokiaLCD\RA_NokiaLCD.cpp:1165: error: 'class TwoWire' has no member named 'read'
grafspee1217
Let me explain what I think I am supposed to do in case I am doing something wrong. I have an LED light that I will use to simulate a sunrise/sunset. I think I read somewhere that the preloaded code wont support this. I also have the wifi unit as well. My understanding is that I am supposed to generate the internal memory code first and upload that to the controller. The next step would be to add the wifi?
Sorry, I have to update this thread with new videos and new links :(
The new installer should come with the updated libraries and also the new Arduino.
The one you downloaded from the original post is outdated.
Thank you for bringing that up.
I'll fix it today.
But, to resolve your issue, uninstall everything you have installed and use the latest installer in the download page: http://www.reefangel.com/Download.ashx
I'm sorry for the trouble.
grafspee1217
I deleted everything on my computer and downloaded the latest installer. I generated a new ino file and tried uploading the internal memory again with the same result.
What is the version of Arduino that was used when you got the error?
grafspee1217
It's version 1.0
grafspee1217
I tried searching to see if I am using the correct version of Arduino. There were numerous older posts concerning incompatibility with 1.0 and the development libraries. These posts were from 2011 however so I suspect this is a non issue since the version I am using was downloaded with the latest installer.
Oh, you are using the correct version of Arduino...
Arduino 1.0 is the most updated one and the one that gets installed using the latest Installer.
Original post has been updated with new videos.
ejn76
Post by ejn76 »
I imagine that this must have been mentioned before but the link to download the software is wrong. It reads www_reefangel_com/Download.ashx
but should be
www_reefangel_com/Download.asxp
Snowmansnow
Post by Snowmansnow »
Does this work on iOS
Snowmansnow wrote:Does this work on iOS
you cannot run ragen or arduino with the customized ra code on ios.
Yeah, we have something better now.
It's called Reef Angel Wizard and it will run on Windows, MacOSX and linux.
SMG2383
Post by SMG2383 »
I am in China, because the freight is too much, so I made a pcb board myself, but I can’t upload the files correctly. I power the board separately with 5V, and the three jumpers have been connected. Do I need to connect the jumpers under the screen? Whether to upload the boot file
