Re: Analog Dimming & MOONPHASE ?
Posted: Fri Jun 01, 2012 6:03 am
Will this do the trick? I was getting an error. So I added a time-out value
InternalMemory.OverheatTemp_write( 860 );
ReefAngel.Relay.On(Port3);
ReefAngel.Relay.On(Port4);
ReefAngel.Relay.On(Port7);
ReefAngel.Relay.On(Port8);
ReefAngel.StandardLights( Port1,19,0,6,30 );
ReefAngel.StandardHeater( Port4,740,770 );
ReefAngel.StandardLights( Port7,6,0,20,0 );
ReefAngel.StandardLights( Port8,7,0,19,0 );
ReefAngel.Wavemaker1(Port5);
ReefAngel.Wavemaker2(Port6);
ReefAngel.PWM.SetDaylight( PWMParabola(7,5,19,0,0,85,0) );
ReefAngel.PWM.SetActinic( PWMParabola(6,5,21,0,0,85,0) );
ReefAngel.SingleATOHigh(60);
pinMode(lowATOPin,OUTPUT);
analogWrite(lowATOPin,(int)MoonPhase()*2.55);
// This sends all the data to the portal
// Do not add any custom code that changes any relay status after this line
// The only code after this line should be the ShowInterface function
ReefAngel.Portal("DrewPalmer04", ********");
