Page 2 of 2
Re: question on dual ATO topoff switch positioning.
Posted: Sat Sep 01, 2012 2:56 pm
by 00Warpig00
Spent entire afternoon trying to get this working... Not much progress... :( nothing is doing what I expect... need food and a mental health break...
Nick
Posted: Sat Sep 01, 2012 3:29 pm
Good catch :)
Yes you are looking at the wrong flag. You need to use what you posted :)
The mask needs to be:
ReefAngel.Relay.RelayMaskOff=~Port4Bit;
Posted: Sat Sep 01, 2012 5:35 pm
by 00Warpig00
what does the ~ mean? Funny thing is I copied and pasted some code that had the tilde in it and deleted the tilde because i had no clue why it would be there. lmao
back to the madness ;)
btw Roberto I received my order with replacement and extra float switches. Thanks. Those are next on my list... Just need to be sure I'm not going to have a major water\lack of water incident over the coming 5 days.
Nick
Posted: Sat Sep 01, 2012 5:38 pm
Posted: Sat Sep 01, 2012 6:35 pm
by 00Warpig00
tested with following line
small step forward... this line DOES mask relay port 4 to off, however it also masks relay ports 1, 2, and 3 to off. How do I just mask Off the ONE bit that I want? The bit for port4?
Posted: Sat Sep 01, 2012 7:04 pm
Wow...
I learned something new today :)
You need to place it inside parenthesis:
ReefAngel.Relay.RelayMaskOff=~(Port4Bit);
Posted: Sat Sep 01, 2012 8:20 pm
by 00Warpig00
This is working PREFECT NOW! Thanks Roberto. :D
Here is my total current running config with this working for anyone that has been following along that the code might be useful for.
What it does...
My Dual ATO is set to have a very small window where neither of my two top off float switches are active. When the low switch becomes active (low water state) the MaxiJet 600 pump in my RO/DI topoff Brute starts pumping water into my sump. Because my window (the activation levels between my two ATO float switches) is very small (less than a 1/2 inch of water) my topoff pump will activate and pump more frequently for a short period of time at each activation. I have set a fairly aggressive ATO timeout of 40 seconds. During normal conditions when the ATO low switch becomes active and the pump activates it takes less than 30 seconds to pump in the required water to activate the ATO High Float switch (ATO cycle to full optimum level) this should normally NOT exceed the 40 seconds I have allotted before the ATO pump shuts off and sets the ATO timeout flag. If it DOES in fact time out and sets the timeout flag this tells me that my ATO high topoff float switch probably malfunctioned and that my sump has more water in it at this point than the "optimum" level. This could cause my skimmer to overflow so I decided if the timeout activated it might be wise to turn off my skimmer to prevent it from overflowing. I used the custom variables to make the fact that an ATO timeout has occurred visible on the portal. I also configured the portal to email me and let me know this has occurred. At this point manual intervention is required to clear the ATO timeout from the Android app and also lets me wait a while for some evaporation to occur before I use the android app to remove the mask and set my skimmer back to auto/on mode. Now while I am not home I will be notified that my ATO timed out and there will be NO MORE topoff function until I intervene. This will let me take the appropriate steps to clear the ATO timeout flag and prevent my sump's return section from evaporating and not getting topped off and running dry in the event the timeout occurs while I am away. Since it takes almost 48 hours for enough water to evap from my sump before my pump pumps dry this gives me plenty of warning that I need to do something.
Here is my total code
byte buzzer=0;
byte overheatflag=0;
byte atoflag=0;
byte iochannel0flag=0;
byte iochannel1flag=0;
byte iochannel2flag=0;
byte iochannel3flag=0;
byte iochannel4flag=0;
byte iochannel5flag=0;
    ReefAngel.WaterChangePorts = Port3Bit | Port4Bit;
    ReefAngel.LightsOnPortsE[0] = Port1Bit | Port2Bit;
    ReefAngel.OverheatShutoffPorts = Port4Bit | Port5Bit | Port6Bit;
    ReefAngel.Relay.On( Port3 );
    ReefAngel.CustomVar[0]=0;
    ReefAngel.CustomVar[7]=255;
    ReefAngel.StandardFan( Port1,790,820 );
    ReefAngel.StandardATO( Port2,40 );
    ReefAngel.Relay.DelayedOn( Port4,5 );
    ReefAngel.WavemakerRandom( Port5,30,100 );
    ReefAngel.StandardHeater( Port6,750,760 );
    ReefAngel.StandardLights( Box1_Port1,13,0,23,0 );
    ReefAngel.StandardLights( Box1_Port2,13,0,23,0 );
    ReefAngel.StandardHeater( Box1_Port3,750,760 );
    ReefAngel.StandardHeater( Box1_Port4,750,760 );
    ReefAngel.PWM.SetChannel( 0, PWMParabola(14,0,23,59,1,100,1) );
    ReefAngel.PWM.SetChannel( 1, PWMParabola(14,0,23,59,1,100,1) );
    ReefAngel.PWM.SetChannel( 3, PWMSlope(2,0,7,30,0,50,0,0) );
    ReefAngel.PWM.SetChannel( 4, PWMSlope(0,0,14,0,0,50,0,0) );
 //   iochannel0flag = ReefAngel.IO.GetChannel( 0 );
    iochannel1flag = ReefAngel.IO.GetChannel( 1 );
    iochannel2flag = ReefAngel.IO.GetChannel( 2 );
    iochannel3flag = ReefAngel.IO.GetChannel( 3 );
    iochannel4flag = ReefAngel.IO.GetChannel( 4 );
    iochannel5flag = ReefAngel.IO.GetChannel( 5 );
    buzzer = overheatflag + atoflag + iochannel0flag + iochannel1flag + iochannel2flag + iochannel3flag + iochannel4flag + iochannel5flag;
    if ( buzzer >= 1 ) buzzer = 100;
    ReefAngel.PWM.SetActinic( buzzer );
    ReefAngel.CustomVar[0]=InternalMemory.read(ATO_Exceed_Flag);
    if ( ReefAngel.CustomVar[0]== 1 )
    ReefAngel.Portal( "00Warpig00" );
    int x,y;
    // Dimming Expansion
    x = 15;
    y = 2;
    for ( int a=0;a<6;a++ )
      if ( a>2 ) x = 75;
      if ( a==3 ) y = 2;
      y += 10;
    // I/O Expansion
    byte bkcolor;
    x = 14;
    y = 34;
      ReefAngel.LCD.DrawCircleOutline( x+(a*20),y,4,COLOR_MEDIUMORCHID );
      if ( ReefAngel.IO.GetChannel(a) ) bkcolor=COLOR_WHITE; else bkcolor=COLOR_GRAY;
      ReefAngel.LCD.FillCircle( x+(a*20),y,2,bkcolor );
    // Parameters
    ReefAngel.LCD.DrawMonitor( 15, 44, ReefAngel.Params,
    ReefAngel.LCD.DrawMonitor( 15, 44, ReefAngel.Params );
    // Salinity
    ReefAngel.LCD.DrawText( COLOR_DARKKHAKI,DefaultBGColor,15,76, "SAL:" );
    ReefAngel.LCD.DrawText( COLOR_DARKKHAKI,DefaultBGColor,39,76, ReefAngel.Params.Salinity );
    // Main Relay Box
    ReefAngel.LCD.DrawOutletBox( 12, 90, TempRelay );
    // Relay Expansion
    ReefAngel.LCD.DrawOutletBox( 12, 104, TempRelay );
    // Date and Time
and here is just what I added to make this work
and added to my loop
Hope this helps anyone looking to do something similar
Nick
Posted: Sat Sep 01, 2012 8:23 pm
Cool!!
Posted: Fri Sep 14, 2012 11:00 am
by phrusher
rimai wrote:Yes :)
In about 2 weeks they should be popping up :twisted:
Sooo.... I's been about two weeks now :) Any news?
Posted: Fri Sep 14, 2012 4:04 pm
Cases are still not here.
I got a tracking number that says it should be here next Wed :)
Posted: Fri Sep 14, 2012 10:19 pm
by phrusher
Great! :-)
