Clouds and display
Re: Clouds and display
I can try that. But will it do 10% to 30%. Then 30% to 10% and repeat throughout cloud duration?
Try this:
      if (NumMins(hour(),minute())>=(cloudstart+180) && NumMins(hour(),minute())<(cloudstart+cloudduration-180))
        boolean static passingcloud=false;
        boolean static passingcloudstart=now();
        if (!passingcloud && random(1000)<10)
            passingcloud=true;
        if (passingcloud)
          if ((now()-passingcloudstart)<10)
            DaylightPWMValue+=(now()-passingcloudstart)*2;
          if ((now()-passingcloudstart)>10 && (now()-passingcloudstart)<20)
            DaylightPWMValue-=(now()-passingcloudstart-10)*2;
          if ((now()-passingcloudstart)>20)
            passingcloud=false;
Place it right after the PWM override value assignment:
It's a random chance of 1% for every pass of loop and not every second.... don't increase too much or you will end up getting passing clouds all the time.
I even think 1% is too much.
It lasts for 20 seconds... 10 to go up and 10 to go down... It increases the PWM by 2 every second.
void CheckCloud()
#define Clouds_Every_X_Days 1
#define Min_Cloud_Duration 7
#define Max_Cloud_Duration 15
#define Min_Clouds_per_Day 3
#define Max_Clouds_per_Day 5
static byte cloudchance=255;
static byte cloudduration=0;
static int cloudstart=0;
static byte numclouds=0;
static byte cloudindex=0;
static int LastNumMins=0;
#ifdef forcecloudcalculation
if (cloudchance==255)
#else
#endif
cloudchance=random(100);
// If we have cloud today
if (cloudchance)
lightningchance=random(100);
if (cloudchance)
//is it time for cloud yet?
passingcloud=true;
if (passingcloud)
passingcloud=false;
else lightningstatus=0;
if (lightningstatus)
DaylightPWMValue=100;
ActinicPWMValue=100;
DaylightPWMValue=0;
ActinicPWMValue=0;
delay(1);
cloudindex++;
if (cloudindex < numclouds)
int x=0;
if (lightningchance)
int x=0;
cstart*=60;
cend*=60;
if (n>cend) return PWMStart;
Like this???
Yeah, let me know if it works :)
uploading now
Can't get it to force a cloud...weird.
#define Min_Clouds_per_Day 2
#define Max_Clouds_per_Day 4
// In this example, start could after 10:30am
#define Start_Cloud_After NumMins(10,30)
// In this example, end could before 5:30pm
#define End_Cloud_Before NumMins(17,30)
should be going..yes?
#define forcecloudcalculation is also uncommented
bummer...no room for a custom menu. I'll just watch for the next cloud and see what happens. :)
A cloud just happened...
It works but it doesn't repeat throughout the cloud duration..it only happened once?? but it worked..sort of
thoughts?
I'll get back to you after 12/03 when we open again.
Can you post your entire code?
I think the post I made with the code was missing one closing bracket.
I fixed that closing bracket originally. I'll post it
// Autogenerated file by RAGen (v1.2.2.171), (06/09/2012 20:37)
// RA_060912_2037.ino
//The following features are enabled for this File:
#define VersionMenu
#define DisplayLEDPWM
#define wifi
#define WDT
#define SIMPLE_MENU
byte ActinicPWMValue=0;
byte DaylightPWMValue=0;
  byte x = 6;
  byte y = 2;
  byte t;
  char text[7];
  ReefAngel.LCD.DrawDate(6, 2);
  ReefAngel.LCD.DrawText(0,255,3,17,"Drew Palmer's 75 Reef");
  ReefAngel.LCD.DrawText(COLOR_BLACK,255, 6, 90, "--------------------");
  ReefAngel.LCD.DrawText(COLOR_BLACK,255, 6, 126, "--------------------");
  ReefAngel.LCD.DrawText(COLOR_BLACK,255, 2, 93, "|");
  ReefAngel.LCD.DrawText(COLOR_BLACK,255, 2, 103, "|");
  ReefAngel.LCD.DrawText(COLOR_BLACK,255, 2, 113, "|");
  ReefAngel.LCD.DrawText(COLOR_BLACK,255, 2, 123, "|");
  ReefAngel.LCD.DrawText(COLOR_BLACK,255, 126, 93, "|");
  ReefAngel.LCD.DrawText(COLOR_BLACK,255, 126, 103, "|");
  ReefAngel.LCD.DrawText(COLOR_BLACK,255, 126, 113, "|");
  ReefAngel.LCD.DrawText(COLOR_BLACK,255, 126, 123, "|");
  ReefAngel.LCD.DrawText(0,255,10,30,"Display");
  ConvertNumToString(text, ReefAngel.Params.Temp[T3_PROBE], 10);
  ReefAngel.LCD.DrawText(COLOR_BLACK, 255, 10, 40, text);
  ReefAngel.LCD.DrawText(0,255,8,68,"Room");
  ReefAngel.LCD.DrawSingleMonitor(ReefAngel.Params.Temp[T2_PROBE], COLOR_BLACK, 40, 68, 10);
  ReefAngel.LCD.DrawText(0,255,70,68,"Light");
  ReefAngel.LCD.DrawSingleMonitor(ReefAngel.Params.Temp[T1_PROBE], COLOR_BLACK, 99, 68, 10);
  ReefAngel.LCD.DrawText(COLOR_BLACK, 255, 95, 40, text);
  ReefAngel.LCD.DrawOutletBox(12, 77, TempRelay);
  ReefAngel.LCD.DrawText(0,255,8,100, "CWLED");
  ReefAngel.LCD.DrawText(COLOR_BLACK,255,15,119, ReefAngel.PWM.GetDaylightValue());
  ReefAngel.LCD.DrawText(0,255,88,100, "RBLED");
  ReefAngel.LCD.DrawText(COLOR_BLACK,255,95,119, ReefAngel.PWM.GetActinicValue());
  ReefAngel.LCD.DrawText(0,255,48,100, "Cloud");
  ReefAngel.LCD.DrawText(0,255,41,108, "Duration");
byte wc_status=0;
// 0 - Draining
// 1 - Filling up
// 2 - Finish
    ReefAngel.WaterChangePorts = Port4Bit | Port6Bit | Port8Bit | Port5Bit;
    ReefAngel.OverheatShutoffPorts = Port5Bit | Port6Bit | Port7Bit;
    InternalMemory.OverheatTemp_write( 860 );
    ReefAngel.PHMin=830; // 830=PH10.0
    ReefAngel.PHMin=480; // 480=PH7.0
    ReefAngel.Relay.On(Port6);
    ReefAngel.Relay.On(Port5); //Heater
    //ReefAngel.AddWifi();
 //water change ATO
 if (ReefAngel.DisplayedMenu==WATERCHANGE_MODE)
    ReefAngel.LCD.DrawOutletBox(10, 100, TempRelay);
    switch (wc_status)
    case 0:
      ReefAngel.Relay.On(1);
      if (ReefAngel.LowATO.IsActive()) wc_status++;
      break;
    case 1:
      ReefAngel.Relay.Off(1);
      ReefAngel.Relay.On(3);
      if (!ReefAngel.HighATO.IsActive()) wc_status++;
      break;
    case 2:
      ReefAngel.Relay.Off(3);
      wc_status=0;
      ButtonPress++;
  //end water change
  ActinicPWMValue=PWMParabola(6,5,21,0,0,85,0);//85%
  DaylightPWMValue=PWMParabola(7,5,19,0,0,80,0);//80%
  CheckCloud();
    //ReefAngel.StandardHeater( Port4,740,770 );
    //Loop Lights & Fan
  ReefAngel.StandardLights(Port7,6,30,20,30);//On LED light FAN
  ReefAngel.StandardLights(Port2,19,15,6,30);//Fug Light
   ReefAngel.Relay.DelayedOn( Port4,5);
   ReefAngel.Relay.DelayedOn( Port8,5);
void CheckCloud()
#define Lightning_Change_per_Cloud 0
#else
#endif
      if (cloudchance)
  if (cloudchance)
      DaylightPWMValue=ReversePWMSlope(cloudstart,cloudstart+cloudduration,DaylightPWMValue,10,180);
            passingcloud=true;
        if (passingcloud)
            passingcloud=false;
          DaylightPWMValue=0;
          ActinicPWMValue=0;
        delay(1);
      cloudindex++;
    ReefAngel.LCD.DrawText(0,255,48,47,"Cloud");
    ReefAngel.LCD.DrawText(0,255,48,57,"00:00");
    //ReefAngel.LCD.DrawText(0,255,45,120,"L");
    //ReefAngel.LCD.DrawText(0,255,51,120,"00:00");
      int x=0;
      if ((cloudstart/60)>=10) x=48; else x=54;
      ReefAngel.LCD.DrawText(0,255,x,57,(cloudstart/60));
      if ((cloudstart%60)>=10) x=66; else x=72;
      ReefAngel.LCD.DrawText(0,255,x,57,(cloudstart%60));
    ReefAngel.LCD.DrawText(0,255,56,119,cloudduration);
      int x=0;
      ReefAngel.LCD.DrawText(0,255,x,115,((cloudstart+(cloudduration/2))/60));
      ReefAngel.LCD.DrawText(0,255,x,115,((cloudstart+(cloudduration/2))%60));
  cstart*=60;
  cend*=60;
Try replacing this:
To this:
unsigned long static passingcloudstart=now();
Thanks. Will see and post back
Cloud happened.
After replacing what you said to do. It reverted back to just going to 0 and sitting there. For the duration of the cloud. It just went back to the original code cycle.
So, is it still doing the same thing?
Yep. Same thing. Maybe it's not using the correct code you made and is just using the standard code from before? I'm also only getting one cloud a day now. Even though I have it set to up to 5 every other day. We might need to restart from the beginning?
There is also a % chance of cloud per day. What do you have it set to?
60%
The weird thing is that only one cloud happens per day and it's always at 1100 for a changing duration
This was all functioning as intended until I wanted "passing" clouds where the PWM will ramp and down in the duration. So something is up with what we changed to make passing clouds
Thoughts?
I'll have to revisit this when I get back.
No way of troubleshooting at the moment.
Back? :)
Next week :)
You're back! :) haha. Still cloud at 11am daily? Only one all day even though I've changed variables to try and get it working like it used to. Passing clouds still not working either
Yeah, back :)
Let me see if I troubleshoot.
