Page 2 of 5
Re: My Jebao "Else" mode
Posted: Sun Jun 30, 2013 12:25 pm
Try something like this:
if (ReefAngel.DCPump.Mode==Custom)
  ReefAngel.PWM.SetActinic( ElseMode(ReefAngel.DCPump.Speed,20,true ));                     // ElseMode on sync mode, Portal Speed Setting +/- 20%
If you wanted to use the Duration parameter as well to affect the offset:
  ReefAngel.PWM.SetActinic( ElseMode(ReefAngel.DCPump.Speed,ReefAngel.DCPump.Duration,true ));                     // ElseMode on sync mode, Portal Speed Setting +/- 20%
I have Vortech MP40s so I have no need to use the DCPump class.. thats why you won't find it in my code. However the RF Pump is very similar so alot of my code that I use to bypass the stock RF function is mostly valid. The only thing we are missing is the ability to SetMode and specify which channel to write to so we could control the Sync / AntiSync modes seperately... it's an easy fix, but I haven't had time to write it.
Posted: Sun Jun 30, 2013 1:05 pm
by Sacohen
If I wanted to use either of what you have above I would need to set the DCPumps to use the internal memory with this code...
Correct?
Also the duration on the Portal is in what measurement?
Seconds, Milliseconds?
Posted: Sun Jun 30, 2013 1:38 pm
Not necessarily. You only need use memory true if you are controlling through portal.
It depends on the function being used on. But typically its seconds.
Posted: Sun Jun 30, 2013 1:40 pm
by Sacohen
Thanks Lee.
Posted: Mon Jul 15, 2013 6:45 pm
by ganjero
I cant get this work...this is my code:
    ReefAngel.FeedingModePorts = Port7Bit | Port8Bit;
    ReefAngel.WaterChangePorts = Port7Bit | Port8Bit;
    ReefAngel.WaterChangePortsE[0] = Port3Bit;
    ReefAngel.LightsOnPorts = Port1Bit | Port4Bit;
    ReefAngel.OverheatShutoffPorts = Port1Bit | Port2Bit | Port3Bit | Port5Bit;
    InternalMemory.OverheatTemp_write( 851 );
    ReefAngel.Relay.On( Box1_Port1);
    ReefAngel.StandardLights( Port1,14,0,19,0 );
    ReefAngel.StandardLights( Port2,15,0,20,0 );
    ReefAngel.StandardLights( Port3,19,55,22,0 );
    ReefAngel.StandardLights( Port4,14,0,20,15 );
    ReefAngel.StandardHeater( Port5,780,785 );
    ReefAngel.StandardFan( Port6,780,800 );
    ReefAngel.Relay.DelayedOn( Port7,60 );
    ReefAngel.StandardLights( Box1_Port5,22,0,16,0 );
  ReefAngel.PWM.SetDaylight( ElseMode(70,30,true ));                     // ElseMode on sync mode, 70 +/- 30%
     static time_t StartFeeding=0;
        StartFeeding=now(); // if we entered feeding mode, register what time it was.
      if (now()-StartFeeding > 1800 && now()-StartFeeding < 5400) // if feeding started between 1800 and 5400 seconds
        ReefAngel.PWM.SetActinic(100);
        ReefAngel.PWM.SetActinic(45);
    ReefAngel.Portal( "ganjero" );
    int x,y;
    // Parameters
    // Main Relay Box
    // Relay Expansion
    // Date and Time
      if (WaveSync)
        return NewSpeed;
        return AntiSpeed;
Posted: Mon Jul 15, 2013 7:15 pm
by cosmith71
What is the pump doing or not doing? Code looks OK, but I'm not familiar with the portal pump control so I might be missing something.
Sent from my M470BSA using Tapatalk 4 Beta
Posted: Mon Jul 15, 2013 7:18 pm
by ganjero
if I use this code (elsemode) the pump stays at 20%, if I replace the code with the reefcrest line below it works fine
 ReefAngel.PWM.SetDaylight( ReefCrestMode(70,30,true) ); // ReefCrest at 70% +/- 30% on sync mode
Posted: Mon Jul 15, 2013 7:19 pm
Try this:
} else {
    int x,y;
    // Parameters
    // Main Relay Box
    // Relay Expansion
    // Date and Time
      if (WaveSync)
        return NewSpeed;
        return AntiSpeed;
[/quote]
Posted: Mon Jul 15, 2013 7:30 pm
by cosmith71
What he said. :D I'm guessing the use memory overrides the custom?
Posted: Mon Jul 15, 2013 7:49 pm
by ganjero
Did not work,
what do these two lines do?
} else {
Posted: Tue Jul 16, 2013 2:53 am
It tells the ReefAngel class to not use memory which would use the speed and duration (mode is already custom) not to reset from memory.
I relooked at the code i dont see any issues. Where are you seeing the speed stuck at? Are you looking at the PWM value or the pump settings?
Posted: Tue Jul 16, 2013 4:31 pm
by ganjero
The controller screen shows 20, portal shows 20 and doesn't show the the pump settings. I must have something wrong but cant see it.
Also it the pumps runs really slow and the it stops
I appreciate the help
        //Feeedin mode length
        ReefAngel.Timer[FEEDING_TIMER].SetInterval(300);
    } else {
        int x,y;
        // Parameters
        // Main Relay Box
        // Relay Expansion
        // Date and Time
          if (WaveSync)
            return NewSpeed;
            return AntiSpeed;
Posted: Wed Jul 17, 2013 6:59 am
by cosmith71
Are you using the portal to change modes?
Posted: Wed Jul 17, 2013 9:03 am
by ganjero
cosmith71 wrote:Are you using the portal to change modes?
No, should I? I really just want to run your elsemode on one pump connected to the daylight channel.
Posted: Wed Jul 17, 2013 9:49 am
by cosmith71
Easy! Take out all this:
    } else {
And use this instead:
Posted: Wed Jul 17, 2013 2:50 pm
by ganjero
It's working now.
Thanks a lot
Posted: Wed Jul 17, 2013 2:57 pm
by ganjero
What is this line telling the controller?
Posted: Thu Jul 18, 2013 11:44 am
by cosmith71
I believe it reads the mode set by the portal. I don't use the portal for pump control so I'm not for certain.
Posted: Thu Jul 18, 2013 1:59 pm
Exactly what it does. The Custom option was added as a drop down selection in the portal so that users could define their own mode which was what you were doing. I have a feeling if you never changed that it was not set to Custom and your mode was not getting triggered.
Posted: Thu Jul 18, 2013 5:44 pm
by ganjero
Where does the drop down in portal would show?
What do you mean if never changed it? where do I change it?
Posted: Thu Jul 18, 2013 6:14 pm
In the portal under Internal Memory there is a section called DC Pumps
Posted: Thu Jul 18, 2013 6:23 pm
by Sacohen
ganjero wrote:Where does the drop down in portal would show?
1st part: Go to Internal Memory and then the last tab is DC Pump. Under there is a drop down for the different modes and Custom is in there
I don't know the answer to the 2nd part.
Posted: Fri Jul 19, 2013 5:58 am
by ganjero
Found it, what does the duration in portal determine? aren't the duration(s) determined by the mode in the sketch?
Thanks a lot
Posted: Fri Jul 19, 2013 7:50 am
Some of the modes like ShortPulse / LongPulse and Nutrient Transport use Duration to set the pulse duration of the wave. You can fine-tune things with that field. I use that field in my custom modes for similar purposes.
Posted: Fri Jul 19, 2013 8:21 am
by ganjero
lnevo wrote:Some of the modes like ShortPulse / LongPulse and Nutrient Transport use Duration to set the pulse duration of the wave. You can fine-tune things with that field. I use that field in my custom modes for similar purposes.
That's great to know, that would make it so much easier to tune a wave....
So if I'm using reefcrest or this else mode that duration will not affect anything and be overlooked?
Posted: Fri Jul 19, 2013 10:50 am
Yes
Posted: Thu Aug 08, 2013 10:42 am
by Sacohen
Is anyone running this mode on Anti-Sync with 2 Jebao's?
I was going to put a 2nd pump in my tank and set up on this mode in Anti sync with my first pump, but it doesn't seem that there is enough time between cycles for the 2nd pump to kick in.
Posted: Fri Aug 09, 2013 8:09 am
by cjrudy
My second pump just came in today and I was wondering the same thing.
Posted: Fri Aug 09, 2013 8:17 am
by cjrudy
Can the portal set anti sync modes ?
Posted: Fri Aug 09, 2013 9:08 am
It does the anti-sync for the mode chosen. When you setup your code you can choose which pump is on sync and which would be anti.
If you want two different modes you'll need to create a custom mode.
