New APP / Portal
JoelIreland
Re: New APP / Portal
Thought so but as I am looking for a solution for everyone, it either needs to be an update for all or need to find another way around it.
Can you provide an example json that the controller would be returning?
I'll have to change the libs to include that.
It'll have to be an optional feature, because the code will increase.
- lnevo
Here's the output from my all_data_json.php
The json object has three arrays xml, mem, relays. XML contains the data straight from the r99 output. The mem contains all the memory variables extracted from /mr and the relays contains the relay information after applying masks and so forth.
For the controller output, I would suggest just outputting the r99 obviously... should look something like this, but I'm editing it manually...
{"xml":{"ID":"lnevo","T1":"802","T2":"800","T3":"793","PH":"793","R":"203","RON":"0","ROFF":"255","R1":"28","RON1":"0","ROFF1":"255","R2":"128","RON2":"0","ROFF2":"255","R3":"0","RON3":"0","ROFF3":"255","R4":"0","RON4":"0","ROFF4":"255","R5":"0","RON5":"0","ROFF5":"255","R6":"0","RON6":"0","ROFF6":"255","R7":"0","RON7":"0","ROFF7":"255","R8":"0","RON8":"0","ROFF8":"255","ATOLOW":"1","ATOHIGH":"1","EM":"130","EM1":"0","REM":"3","FLAG":"0","PWMA":"30","PWMD":"30","PWMAO":"255","PWMDO":"255","WL":"93","C0":"0","C1":"8","C2":"8","C3":"0","C4":"46","C5":"9","C6":"8","C7":"0","RFM":"11","RFS":"37","RFD":"1","RFW":"0","RFRB":"0","RFR":"0","RFG":"0","RFB":"100","RFI":"100","RFWO":"255","RFRBO":"255","RFRO":"255","RFGO":"255","RFBO":"255","RFIO":"255"},"mem":{"Mem_B_MoonSlope":30,"Mem_B_Vacation":0,"Mem_B_AutoFeed":0,"Mem_B_AutoFeedPress":2,"Mem_B_AutoFeedRepeat":8,"Mem_B_AutoFeedOffset":5,"Mem_I_WCFillTime":270,"Mem_I_Latitude":21,"Mem_I_Longitude":-73,"Mem_B_AcclRiseOffset":4,"Mem_B_AcclSetOffset":2,"Mem_B_AcclDay":0,"Mem_B_SwabbieRepeat":4,"Mem_B_SwabbieTime":1,"Mem_B_TideMin":10,"Mem_B_TideMax":15,"Mem_B_PumpOffset":50,"Mem_B_FeedingRF":1,"Mem_B_NightRF":0,"Mem_B_NightSpeed":25,"Mem_B_NightDuration":16,"Mem_B_NTMSpeed":40,"Mem_B_NTMDuration":5,"Mem_B_NTMDelay":15,"Mem_B_NTMTime":150,"Mem_I_CalDP1Vol":10,"Mem_I_CalDP1Time":430,"Mem_I_DP1Volume":20,"Mem_I_CalDP2Vol":10,"Mem_I_CalDP2Time":430,"Mem_I_DP2Volume":20,"Mem_B_LogATO":96,"Mem_B_LogPrevATO":97,"Mem_B_RateAlarm":5,"Mem_B_TideMode":8,"Mem_B_MaintGAC":5,"Mem_B_MaintGFO":20,"Mem_B_MaintCal":13,"Mem_B_MaintAlk":13,"Mem_B_MaintWC":5,"Mem_B_MaintATO":1,"Mem_B_MaintFeeding":2,"Mem_B_MaintSkimmer":5,"Mem_B_MaintSocks":5,"Mem_B_MaintWCVol":20,"Mem_I_CalDP3Vol":3,"Mem_I_CalDP3Time":270,"Mem_I_DP3Volume":0,"Mem_B_ResetMemory":0,"Mem_B_MHOnHour":15,"Mem_B_MHOnMinute":30,"Mem_B_MHOffHour":21,"Mem_B_MHOffMinute":0,"Mem_B_StdLightsOnHour":11,"Mem_B_StdLightsOnMinute":42,"Mem_B_StdLightsOffHour":19,"Mem_B_StdLightsOffMinute":38,"Mem_I_WM1Timer":10,"Mem_I_WM2Timer":15,"Mem_B_DP1Timer":35,"Mem_B_DP2Timer":35,"Mem_I_FeedingTimer":1800,"Mem_I_LCDTimer":600,"Mem_I_OverheatTemp":840,"Mem_B_LEDPWMDaylight":18,"Mem_B_LEDPWMActinic":20,"Mem_I_HeaterTempOn":798,"Mem_I_HeaterTempOff":803,"Mem_I_ChillerTempOn":815,"Mem_I_ChillerTempOff":795,"Mem_B_ATOTimeout":60,"Mem_I_PHMax":840,"Mem_I_PHMin":524,"Mem_B_MHDelay":0,"Mem_B_DP1OnHour":20,"Mem_B_DP1OnMinute":0,"Mem_B_DP2OnHour":22,"Mem_B_DP2OnMinute":30,"Mem_B_ATOHourInterval":0,"Mem_B_ATOHighHourInterval":0,"Mem_B_ATOHighTimeout":60,"Mem_I_DP1RepeatInterval":60,"Mem_I_DP2RepeatInterval":60,"Mem_I_SalMax":2550,"Mem_B_PWMSlopeStartD":0,"Mem_B_PWMSlopeEndD":30,"Mem_B_PWMSlopeDurationD":30,"Mem_B_PWMSlopeStartA":0,"Mem_B_PWMSlopeEndA":30,"Mem_B_PWMSlopeDurationA":30,"Mem_B_RFMode":11,"Mem_B_RFSpeed":50,"Mem_B_RFDuration":10,"Mem_B_PWMSlopeStart0":15,"Mem_B_PWMSlopeEnd0":100,"Mem_B_PWMSlopeDuration0":60,"Mem_B_PWMSlopeStart1":15,"Mem_B_PWMSlopeEnd1":100,"Mem_B_PWMSlopeDuration1":60,"Mem_B_PWMSlopeStart2":15,"Mem_B_PWMSlopeEnd2":100,"Mem_B_PWMSlopeDuration2":60,"Mem_B_PWMSlopeStart3":15,"Mem_B_PWMSlopeEnd3":100,"Mem_B_PWMSlopeDuration3":60,"Mem_B_PWMSlopeStart4":15,"Mem_B_PWMSlopeEnd4":100,"Mem_B_PWMSlopeDuration4":60,"Mem_B_PWMSlopeStart5":15,"Mem_B_PWMSlopeEnd5":100,"Mem_B_PWMSlopeDuration5":60,"Mem_I_ATOExtendedTimeout":30,"Mem_I_ATOHighExtendedTimeout":120,"Mem_I_ORPMin":2050,"Mem_I_ORPMax":450,"Mem_B_ActinicOffset":120,"Mem_I_CO2ControlOn":770,"Mem_I_CO2ControlOff":760,"Mem_I_PHControlOn":800,"Mem_I_PHControlOff":810,"Mem_B_AISlopeStartW":0,"Mem_B_AISlopeEndW":100,"Mem_B_AISlopeDurationW":60,"Mem_B_AISlopeStartB":0,"Mem_B_AISlopeEndB":100,"Mem_B_AISlopeDurationB":60,"Mem_B_AISlopeStartRB":0,"Mem_B_AISlopeEndRB":100,"Mem_B_AISlopeDurationRB":60,"Mem_B_RadionSlopeStartW":0,"Mem_B_RadionSlopeEndW":0,"Mem_B_RadionSlopeDurationW":60,"Mem_B_RadionSlopeStartRB":0,"Mem_B_RadionSlopeEndRB":0,"Mem_B_RadionSlopeDurationRB":60,"Mem_B_RadionSlopeStartR":0,"Mem_B_RadionSlopeEndR":0,"Mem_B_RadionSlopeDurationR":60,"Mem_B_RadionSlopeStartG":0,"Mem_B_RadionSlopeEndG":0,"Mem_B_RadionSlopeDurationG":60,"Mem_B_RadionSlopeStartB":0,"Mem_B_RadionSlopeEndB":100,"Mem_B_RadionSlopeDurationB":60,"Mem_B_RadionSlopeStartI":0,"Mem_B_RadionSlopeEndI":100,"Mem_B_RadionSlopeDurationI":60,"Mem_B_DelayedStart":5,"Mem_I_PHExpMin":500,"Mem_I_PHExpMax":2500,"Mem_I_WaterLevelMin":855,"Mem_I_WaterLevelMax":2800,"Mem_I_SalTempComp":-1,"Mem_B_WaterLevelLow":61,"Mem_B_WaterLevelHigh":63,"Mem_B_DP3Timer":0,"Mem_I_DP3RepeatInterval":60,"Mem_B_LCDID":255,"Mem_B_DCPumpMode":0,"Mem_B_DCPumpSpeed":255,"Mem_B_DCPumpDuration":255},"relays":{"rbin":"11001011","relay1val":"1","relay2val":"1","relay3val":"0","relay4val":"1","relay5val":"0","relay6val":"0","relay7val":"1","relay8val":"1","relay1on":"0","relay2on":"0","relay3on":"0","relay4on":"0","relay5on":"0","relay6on":"0","relay7on":"0","relay8on":"0","relay1off":"1","relay2off":"1","relay3off":"1","relay4off":"1","relay5off":"1","relay6off":"1","relay7off":"1","relay8off":"1","relay1status":"1","relay2status":"1","relay3status":"0","relay4status":"1","relay5status":"0","relay6status":"0","relay7status":"1","relay8status":"1","rbin1":"00011100","relay11val":"0","relay12val":"0","relay13val":"1","relay14val":"1","relay15val":"1","relay16val":"0","relay17val":"0","relay18val":"0","relay11on":"0","relay12on":"0","relay13on":"0","relay14on":"0","relay15on":"0","relay16on":"0","relay17on":"0","relay18on":"0","relay11off":"1","relay12off":"1","relay13off":"1","relay14off":"1","relay15off":"1","relay16off":"1","relay17off":"1","relay18off":"1","relay11status":"0","relay12status":"0","relay13status":"1","relay14status":"1","relay15status":"1","relay16status":"0","relay17status":"0","relay18status":"0","rbin2":"10000000","relay21val":"0","relay22val":"0","relay23val":"0","relay24val":"0","relay25val":"0","relay26val":"0","relay27val":"0","relay28val":"1","relay21on":"0","relay22on":"0","relay23on":"0","relay24on":"0","relay25on":"0","relay26on":"0","relay27on":"0","relay28on":"0","relay21off":"1","relay22off":"1","relay23off":"1","relay24off":"1","relay25off":"1","relay26off":"1","relay27off":"1","relay28off":"1","relay21status":"0","relay22status":"0","relay23status":"0","relay24status":"0","relay25status":"0","relay26status":"0","relay27status":"0","relay28status":"1"}}
{"xml":{"ID":"lnevo","T1":"802","T2":"800","T3":"793","PH":"793","R":"203","RON":"0","ROFF":"255","R1":"28","RON1":"0","ROFF1":"255","R2":"128","RON2":"0","ROFF2":"255","R3":"0","RON3":"0","ROFF3":"255","R4":"0","RON4":"0","ROFF4":"255","R5":"0","RON5":"0","ROFF5":"255","R6":"0","RON6":"0","ROFF6":"255","R7":"0","RON7":"0","ROFF7":"255","R8":"0","RON8":"0","ROFF8":"255","ATOLOW":"1","ATOHIGH":"1","EM":"130","EM1":"0","REM":"3","FLAG":"0","PWMA":"30","PWMD":"30","PWMAO":"255","PWMDO":"255","WL":"93","C0":"0","C1":"8","C2":"8","C3":"0","C4":"46","C5":"9","C6":"8","C7":"0","RFM":"11","RFS":"37","RFD":"1","RFW":"0","RFRB":"0","RFR":"0","RFG":"0","RFB":"100","RFI":"100","RFWO":"255","RFRBO":"255","RFRO":"255","RFGO":"255","RFBO":"255","RFIO":"255"}}
JoelIreland
So your just encoding the returned XML from the RA. The issue is cross domain, I can't even access the XML. I can use a proxy but am trying to get a direct link for local ip addresses. Your code is a perfect example of what I need though,
Sent from my iPad using Tapatalk HD
- lnevo
Yeah i think its a encode_json function. Have you looked at the e ample portal code i published?
JoelIreland
Sure did. Thanks for that.
So looks like I'll put live with only proxy access not direct until we come up with a direct JSON solution.
AquaO
Good job!!!
I'm very happy to see this post!!!
i'm not sure if its to late...
But, have iPhone 4 iOS 7 and my Reef Angel app not working with the new iOS
I will be very happy to test the NEW app
Thank
Thank
Osaka 40g with 55g sump
Radion, 2X Tunze 6045, Swc-160 mini cone
Jmustapha
Thank you [PERSON RAISING BOTH HANDS IN CELEBRATION]
fatman
Android phone, android tablet, mac computer, windows computer, linux computer and an iPhone 5 for my son. Yes, I'm confused every time I boot something up.
Let me know if I can help.
chapboogie
I would love to see a widget for android. Something that has my parameters on the home screen
Sent from my SCH-I535 using Tapatalk 4
tpriscu
Hi Guys,
Just curious if any headway has been made with this?
Upgraded my phone to ios7 before i knew there was a problem with the reef angel app and kicking myself in the butt now..
acabano
Hello, just upgraded my 4s to 5s. not knowing there is a compatibility issue with iOs7, looking forward for this New APP/ Portal development, thanks for the hard work/effort.
- mikedizon
Me too cant wait. The more iphone apps maker the better. The more options the better for us. As long as it being updated.
- lnevo
Our iphone developer is lost and missing. I'll pay a fee if someone can find him
- Contact:
I started working on ios programming over the weekend. I'm getting a better understanding of it. hopefully i can have a new app created by the end of the week. yes, i said new app because the existing one is a big ball of duct tape and lots of extras that are most likely not needed. so some functionality may go away initially just to get the basics working again.
and yes, it would be built for ios7 and later only.
and yes, it will still be free... or maybe 99 cents.... not certain yet.
it will be iPhone only initially (or run in compatible mode on ipad).
Sent from my Nexus 7
poolman
Great news thanks Kurt, and I dont thing anyone will have a problem paying 99cents for an APP that works.
Cheers
Bryan
Cheers
Bryan
acabano
Hi Curt, thanks for the update, Looking forward. if you need a tester, i have a 4s with iOS7
Im still waiting for my 5s in preorder.
Arnee.
Arnee.
- Contact:
cool. I'm getting closer for the initial release. i don't have an iPhone but I have an ipad mini and ipad 3. like I said, I'm targeting iPhones first and then work from there. I will need feedback on the overall look and functionality of it.acabano wrote:Hi Curt, thanks for the update, Looking forward. if you need a tester, i have a 4s with iOS7
Arnee.
JoelIreland
Hey guys sorry for delay, had a couple of bugs to iron out but will be live wednesday.
davaraj
That is wonderful news.JoelIreland wrote:Hey guys sorry for delay, had a couple of bugs to iron out but will be live wednesday.
tpriscu
That is very good news. Looking forward to seeing it!
ryanmell
any news on the updated app release date?
- mikedizon
Can't wait! More iphone apps for me to use. I collected many iphone / ipad apps
And Supported paying for the really nice ones.
apps.
Can you check if this is good for you?
http://98.248.54.136:2000/json
It's in the latest dev branch.
- lnevo
Looks good to me, but I haven't tried to read it yet through ajax. I'll have to throw some code together later. Very cool though.
JoelIreland
Hey Roberto where do i find the JSON branch you added?
Use http://ipaddress:2000/json
You must have the RA+ to get json data output.
It won't fit in the standard RA
JoelIreland
Great that helps. Can we get it to return JSON when relays are switched etc? Thanks
Also it needs to have xml headers removed, the benefit of json is we can control the RA as a local device using its ip address. XML wont allow cross domain but JSON will. But jquery still detects it as XML.
- lnevo
You'd have to add the functionality similar to /r for /json shouldnt be that hard but keep in mind that rules out the ability to support standard ra.
Why not just take the xml and do a json encode?
JoelIreland
Because if you want to retrieve results direct from module via browser and javascript, it wont allow you to take xml from another domain hence why json would be allot better not just for web but mobile as well as has become the more popular format for developers.
