Reviving an older issue.
I've been paying more attention to wave flow with a couple of anemone's in the tank and I noticed it isn't cycling as I expected. I have two powerheads at the ends of the tank that cycle back and forth with gradual lulls in between at night ('slowing the waves'). I also have two smaller powerheads that mix things up a bit once and hour durng the day with a flow from back to front. When I try to use the code to slow the waves down at night sometimes the cycle that returns the next day isn't alternating, but cycling on and off together. I'm guessing this has to do with the toggle function and maybe where the powerheads left off. So if they were both off at the end of the night cycle, then they both cycle together instead of alternating when the normal day runs. Any ideas how to fix it? Here is my abbreviated code. that covers the wavemaker stuff...
/* Main ReefAngelPlus controller with communication for sound,
auxillary monitor, I/O expansion, and extra relaybox, send master time,
flow, buzzer, overflow and reservoir alarms on the I/O
The following features are enabled for this File:
#define DisplayImages
#define SetupExtras
#define DateTimeSetup
#define VersionMenu
#define DisplayLEDPWM
#define wifi
#define RelayExp
#define WDT
#define CUSTOM_MENU
#define CUSTOM_MENU_ENTRIES 9
#define CUSTOM_MAIN
#define COLORS_PDE
#define FONT_8x8
#define NUMBERS_8x8
#define CUSTOM_VARIABLES
#include <avr/pgmspace.h>
// Custom Menu Code
//Timer and trigger to keep wavemaker timing correct after setting date/time
int t=ReefAngel.Timer[1].Trigger-now();
if (t>=0)
ReefAngel.LCD.Clear(255,23,73,53,83);
ReefAngel.LCD.DrawText(0, DefaultBGColor,23,73,t);
if (t>300) ReefAngel.Timer[1].ForceTrigger();
//wavemakers extra
ReefAngel.LCD.DrawText(DPColor,DefaultBGColor, 64, 63,"WV:");
if (bitRead(ReefAngel.Relay.RelayDataE[0],Port5-1)==1) ReefAngel.LCD.DrawText(APColor,DefaultBGColor, 82, 63,"v "); //port 5 on
else if (bitRead(ReefAngel.Relay.RelayDataE[0],Port6-1)==1) ReefAngel.LCD.DrawText(APColor,DefaultBGColor, 82, 63," v"); //port 6 on
else ReefAngel.LCD.DrawText(APColor,DefaultBGColor, 82, 63," O "); //port5 and port 6 off, wavemaker delay
int u=ReefAngel.Timer[2].Trigger-now();
if (u>=0)
ReefAngel.LCD.Clear(255,82,73,112,83);
if (bitRead(ReefAngel.Relay.RelayDataE[0],Port5-1)==1 || bitRead(ReefAngel.Relay.RelayDataE[0],Port6-1)==1)
ReefAngel.LCD.DrawText(0, DefaultBGColor,82,73,u);
if (u>300) ReefAngel.Timer[2].ForceTrigger();
ReefAngel.Init(); //Initialize controller and start web banner timer
// Set the ports that get toggled on & off during the following modes
// To enable a port to be toggled, place a 1 in the appropriate position
// Uncomment and update as needed
// Port 87654321
ReefAngel.FeedingModePorts = B00110000;
ReefAngel.FeedingModePortsE[1] = B00110100;
ReefAngel.WaterChangePorts = B10110000;
ReefAngel.WaterChangePortsE[1] = B11111111;
ReefAngel.Relay.On(Port7); //main pump
ReefAngel.Relay.On(Box1_Port1); //chiller
ReefAngel.Relay.On(Box1_Port2); //chiller pump
ReefAngel.Relay.On(Box1_Port4); //phosban pumpo
// Top smaller pumps once an hour for 5 minutes
ReefAngel.Relay.On(Box1_Port5);
ReefAngel.Timer[2].SetInterval(30);
ReefAngel.Timer[2].Start();
//Side to side Wavemaker Pumps
ReefAngel.Relay.On(Port5);
ReefAngel.Timer[1].SetInterval(200);
ReefAngel.Timer[1].Start();
// Specific functions
//1st Heater at 78.8, 2nd Heater at 77.0, MH on at 10AM off at 8PM, Actinics on at 9AM off at 9PM, Fan kicks on at 82.0
ReefAngel.StandardHeater(Port1,788,792);
ReefAngel.StandardHeater(Port2,770,792);
ReefAngel.MHLights(Port3,10,0,20,0,5);
ReefAngel.StandardLights(Port4,9,0,21,0);
ReefAngel.StandardFan(Port8,792,820);
ReefAngel.DosingPumpRepeat(Box1_Port7,0,60,4); // Dose for 4 seconds every 60 minutes with 0 minutes offset
ReefAngel.DosingPumpRepeat(Box1_Port8,5,60,4); // Dose for 4 seconds every 60 minutes with 5 minutes offset
// Wavemaker Code with night option
if (ReefAngel.Timer[1].IsTriggered() )
if ((hour() >= 21) || (hour() <= 8)) //from 9p-Midnight
{ //PWMSlope(byte startHour, byte startMinute, byte endHour, byte endMinute, byte startPWM,
// byte endPWM, byte Duration, byte oldValue)
wmpulse=PWMSlope(21,0,8,0,5,30,179,30);
if (wmdelay)
ReefAngel.Timer[1].SetInterval(wmpulse); // WM delay function from 30-170 sec.
ReefAngel.Relay.Off(Port5);
ReefAngel.Relay.Off(Port6);
if (wmport==Port5) wmport=Port6; else wmport=Port5;
wmdelay=false;
ReefAngel.Timer[1].SetInterval(200-wmpulse); // WM bursts timing from 170-30 sec.
ReefAngel.Relay.On(wmport);
wmdelay=true;
//8a-10p normal wave settings
//extra small powerheads to increase circulation once an hour
//for 5 min during the day
if (hour()>=8 && hour()<=21)
if (minute()<5)
if (ReefAngel.Timer[2].IsTriggered())
ReefAngel.Relay.Toggle(Box1_Port5);
ReefAngel.Relay.Toggle(Box1_Port6);
ReefAngel.Relay.Off(Box1_Port5);
ReefAngel.Relay.Off(Box1_Port6);
ReefAngel.Portal("jsclownfish");
