Re: Cloud and Lightning Code
Posted: Sun Aug 03, 2014 11:08 am
Yes, every second and you are right. You may need one wdt_reset outside the loop too.
https://forum.reefangel.com/
Not yet, I wanted to test it first. But I will soon.lnevo wrote:I meant the update...wasnt sure you updated the first post or not
I haven't had any issues with overrides with the new code. Even with the Mega-Storm, everything runs smooth with no resets.89delta wrote:Oh wow....just got home from work....added ur update last night but haven't checked the relay state yet for the skimmer.....but the mega storm option sounds wicked.....
Sent from my SAMSUNG-SGH-I717 using Tapatalk
byte LightningModes[] = { Slow, Fast, Mega };
void CheckCloud()
#define Clouds_Every_X_Days 1
#define Min_Cloud_Duration 7
#define Max_Cloud_Duration 10
#define Min_Clouds_per_Day 3
#define Max_Clouds_per_Day 5
// In this example, start cloud after noon
#define Start_Cloud_After NumMins(12,00)
#define End_Cloud_Before NumMins(21,00)
// Add Random Lightning modes
#define Slow 0
#define Fast 1
#define Mega 2
static byte cloudchance=255;
static byte cloudduration=0;
static int cloudstart=0;
static byte numclouds=0;
static byte cloudindex=0;
static int LastNumMins=0;
static byte lightningMode=0;
static time_t DelayCounter=millis(); // Variable for lightning timing.
static int DelayTime=random(1000); // Variable for lightning timimg.
#ifdef forcecloudcalculation
if (cloudchance==255)
#else
#endif
randomSeed(millis()); // Seed the random number generator
cloudchance=random(100);
// If we have cloud today
if (cloudchance)
lightningchance=random(100);
if (cloudchance)
//is it time for cloud yet?
// Check for lightning. When lightning occurs, it will happen for 5 seconds at the middle of a cloud.
// We will have from 1 to 4 consecutive flashes, then a random delay of up to 1000 ms before another set of flashes.
// This first line basically says: Is there supposed to be lightning? Are we within a 5 second window in the middle
// of the cloud when lightning occurs? Are we not in a delay between sets of flashes? If so, do another round of flashes.
if (chooseLightning) { lightningMode=LightningModes[random(100)%sizeof(LightningModes)]; chooseLightning=false; }
switch (lightningMode) {
case Mega:
int a=random(1,5); // Pick a number of consecutive flashes from 1 to 4.
for (int i=0; i<a; i++)
analogWrite(daylightPWMPin, 255); // Flash on
delay(20+random(50)); // Wait from 20 to 69 ms
analogWrite(daylightPWMPin, 0); // Flash off
delay(30+random(20)); // Wait from 30 to 49 ms
DelayCounter=millis(); // If we just had a round of flashes, then lets put in a longer delay
DelayTime=random(1000); // of up to a second for dramatic effect before we do another round.
break;
case Fast:
break;
case Slow:
else lightningstatus=0;
if (lightningstatus)
DaylightPWMValue=100;
DaylightPWMValue=0;
delay(1);
break;
default:
break;
} else {
cloudindex++;
if (cloudindex < numclouds)
int x=0;
if ((cloudstart/60)>=10) x=11; else x=17;
ReefAngel.CustomVar[3]=cloudstart/60; // Write the hour of the next cloud to custom variable for Portal reporting
if ((cloudstart%60)>=10) x=29; else x=35;
ReefAngel.CustomVar[4]=cloudstart%60; // Write the minute of the next cloud to custom variable for Portal reporting
ReefAngel.CustomVar[7]=(cloudduration); // Put the duration of the next cloud in a custom var for the portal
if (lightningchance)
int x=0;
if (((cloudstart+(cloudduration/2))/60)>=10) x=51; else x=57;
ReefAngel.CustomVar[5]=(cloudstart+(cloudduration/2))/60; // Write the hour of the next lightning to a custom variable for the Portal
if (((cloudstart+(cloudduration/2))%60)>=10) x=69; else x=75;
ReefAngel.LCD.DrawText(0,255,x,120,((cloudstart+(cloudduration/2))%60)); // Write the minute of the next lightning to a custom variable for the Portal
ReefAngel.CustomVar[6]=(cloudstart+(cloudduration/2))%60;
cstart*=60;
cend*=60;
if (n>cend) return PWMStart;
Ooops, fixed.lnevo wrote:Colin the instructions you provide to add mega is already implemented in your example...you say its not so i'm even more confused now....
Yup. Give me a couple of days.89delta wrote:Can we use a memory location to set the mode?
