Re: RANet Cloud and Lightning
Posted: Thu Feb 05, 2015 12:21 pm
rebooting reef angel controller
https://forum.reefangel.com/
# | 100% 2.44s
avrdude: verifying ...
avrdude: 7262 bytes of flash verified
avrdude: Send: Q [51] [20]
avrdude: Recv: . [14]
avrdude: Recv: . [10]
avrdude done. Thank you.Code: Select all
if (!FireInTheHole)
ReefAngel.PWM.SetChannel(1,DaylightPWMValue); // Whites are on channel 1
ReefAngel.PWM.SetChannel(2,DaylightPWMValue); // and channel 2
}Code: Select all
if (!FireInTheHole) ReefAngel.PWM.SetChannel(2,DaylightPWMValue); // Whites are on channel 2
Wire.write(0x8+(4*1)); // 0x8 is channel 0, 0x12 is channel 1, etc. I'm using channel 1.I was proposing to change it to flash only on channel 2 and see if it was an issue with the channel.cosmith71 wrote:No, that would ONLY flash on channel 2.
Was that line in the code you uploaded? If so, it's not the correct code. That line is different in the updated version.
Here's that section. It was changed to Wire.write(0x8+(4*n)).jegillis wrote: EDIT* the line of quoted code is in all three versions posted here as far as I can tell
for (int n=1; n<3; n++)
int newdata=4095;
Wire.beginTransmission(0x40); // Address of the dimming expansion module
Wire.write(0x8+(4*n)); // 0x8 is channel 0, 0x12 is channel 1, etc. I'm using channel 1.
Wire.write(newdata&0xff); // Send the data 8 bits at a time. This sends the LSB
Wire.write(newdata>>8); // This sends the MSB
Wire.endTransmission();
int randy=random(20,80); // Random number for a delay
if (randy>71) randy=((randy-70)/2)*100; // Small chance of a longer delay
delay(randy); // Wait from 20 to 69 ms, or 100-400 ms
// Flash off
int newdata=0;
Wire.beginTransmission(0x40); // Same as above
}cosmith71 wrote:Here's that section. It was changed to Wire.write(0x8+(4*n)).jegillis wrote: EDIT* the line of quoted code is in all three versions posted here as far as I can tell
for (int n=1; n<3; n++) { int newdata=4095; Wire.beginTransmission(0x40); // Address of the dimming expansion module Wire.write(0x8+(4*n)); // 0x8 is channel 0, 0x12 is channel 1, etc. I'm using channel 1. Wire.write(newdata&0xff); // Send the data 8 bits at a time. This sends the LSB Wire.write(newdata>>8); // This sends the MSB Wire.endTransmission(); } int randy=random(20,80); // Random number for a delay if (randy>71) randy=((randy-70)/2)*100; // Small chance of a longer delay delay(randy); // Wait from 20 to 69 ms, or 100-400 ms // Flash off for (int n=1; n<3; n++) { int newdata=0; Wire.beginTransmission(0x40); // Same as above Wire.write(0x8+(4*n)); Wire.write(newdata&0xff); Wire.write(newdata>>8); Wire.endTransmission(); }
Yes I am using the RANet led drivers and I just get the slow blinkcosmith71 wrote:Yes, I'm using the RANet dimming expansion with LDD drivers. Roberto can chime in, but I think the RANet LED drivers should work as well.
Do you just get the slow blink as in your video?
rimai wrote:Do they ramp up and down as they should on the slope or parabola?
#include <avr/eeprom.h>
#define BLUE_LED 9
#define WHITE_LED 10
#define BLUE_INTENSITY 255
#define WHITE_INTENSITY 255
#define RANET_MAX_SIZE 64
#define DISCONNECT_TIMEOUT 2000
#define LastFallback0 100 // Memory location for fallback storage
#define RANet_Down 0
#define RANet_OK 1
byte buffer_index;
byte buffer[128];
char buf[3];
byte bufint, bufsize;
byte RANetData[RANET_MAX_SIZE];
byte RANetCRC;
byte BlueChannel=0;
byte WhiteChannel=0;
byte RANet_Status=RANet_Down;
boolean cable_present=false;
unsigned long lastcablecheck=millis();
int newdata;
pinMode(BLUE_LED,OUTPUT);
pinMode(WHITE_LED,OUTPUT);
Serial.begin(57600);
Wire.onReceive(NULL);
Wire.onRequest(NULL);
Wire.begin();
for (int a=0;a<RANET_MAX_SIZE; a++) // Clear array
RANetData[a]=0;
Wire.beginTransmission(0x68);
Wire.write(0);
int a=Wire.endTransmission();
cable_present=(a==0);
// setup PCA9685 for data receive
// we need this to make sure it will work if connected ofter controller is booted, so we need to send it all the time.
Wire.write(0);
Wire.write(0xa1);
newdata=4095;
Wire.write(0x8+(4*0));
newdata=2048;
int a=random(5);
for (int i=0;i<a;i++)
newdata=4095;
Wire.write(0x8+(4*2));
delay(20+random(50));
newdata=0;
delay(30+random(20));
delay(random(1000));
void UpdateWhiteChannel()
WhiteChannel=sin(radians((millis()%7200)/40))*255;
BlueChannel=255-(sin(radians((millis()%7200)/40))*255);
analogWrite(WHITE_LED,WhiteChannel);
analogWrite(BLUE_LED,BlueChannel);
//00301200000000000000050000000000000000000000000047
//01301200000000000000050000000000000000000000000048
//02301200000000000000050000000000000000000000000049
//0330120000000000000005000000000000000000000000004a
#define BLUE_LED 9
#define RANet_OK 1
byte buffer_index;
byte buffer[128];
char buf[3];
byte RANetCRC;
byte BlueChannel=0;
int newdata;
Wire.begin();
RANetData[a]=0;
Wire.write(0);
Wire.write(0);
Wire.write(0xa1);
int a=random(5);
newdata=4095;
newdata=0;
