Page 2 of 2
Re: DC return pumps
Posted: Wed Nov 23, 2016 3:04 pm
There are something not correct in your code.
You are using channel 2 for the pump control:
PWMValue=OperatingPWM;
if (ReefAngel.WaterLevel.GetLevel(2)<Level-4)
override=true;
lastmillis=millis();
PWMValue+=2;
if (ReefAngel.WaterLevel.GetLevel(2)>Level+2)
override=true;
PWMValue-=4;
And then the same channel for overfow control:
if (ReefAngel.WaterLevel.GetLevel(2)>89) //Overflow
ReefAngel.Relay.Off(Port1);
ReefAngel.Relay.On(Port1);
So effectively, your first code does nothing.
The second code supersedes and then you will only get port1 off when level is greater than 89.
Re: DC return pumps
Posted: Wed Nov 23, 2016 4:01 pm
by Ismaclst
OK, I see now. That code shuts the return off if my overflow is greater than 89 so it won't overflow if my drain is plugged. What can I do if I want to keep that and still toggle port one when my sump level is too high for too long? Do I need to use a float switch in the sump instead of using the standpipe or is there something that can be changed in the code to allow me to use both codes simultaneously?
Re: DC return pumps
Posted: Thu Nov 24, 2016 1:21 am
If the sump level is at 82 and your code is set to 89, it will never turn off.
Change 89 to something smaller.
Re: DC return pumps
Posted: Thu Nov 24, 2016 2:08 am
by Ismaclst
I guess I'm still confused. The sump level was only at 82 because I submerged the standpipe to test the code. It's supposed to turn off the return when the level is 50 or higher for at least 16 minutes. Normal levels for the sump are around 30. The 89 is the max level of my overflow so it shuts off the return to keep it from overflowing the tank if there is blockage. Channel 2 is for my overflow and channel 4 is my sump.
Re: DC return pumps
Posted: Thu Nov 24, 2016 9:59 am
Your code doesn't even use channel 4.
Re: DC return pumps
Posted: Thu Nov 24, 2016 9:02 pm
by Ismaclst
if (ReefAngel.WaterLevel.GetLevel(4) < 50) levelHigh=now();
if (now()-levelHigh > 16*SECS_PER_MIN && !pumpBool) {
pumpBool=true;
pumpOff=now();
Re: DC return pumps
Posted: Fri Nov 25, 2016 9:40 am
Sorry, I was looking at the code you posted before.
Try this:
#include <Tide.h>
#define Level 76
#define MinPWM 45
#define OperatingPWM 68
long nummillis=5000;
byte PWMValue=0;
unsigned long lastmillis=millis();
boolean override=false;
static unsigned long levelHigh;
static unsigned long pumpOff;
static boolean pumpBool;
ReefAngel.DDNS("Damien");
ReefAngel.AddMultiChannelWaterLevelExpansion(); // Multi-Channel Water Level Expanion Module
ReefAngel.WaterChangePorts = Port1Bit | Port2Bit | Port3Bit | Port4Bit | Port6Bit | Port7Bit | Port8Bit;
ReefAngel.LightsOnPorts = Port5Bit;
InternalMemory.WaterLevelMax_write(1800);
ReefAngel.StandardHeater( Port3,780,785 );
ReefAngel.WaterLevelATO(4,Port4,240,28,31);
ReefAngel.Relay.Set(Port8, (now()%(6*SECS_PER_HOUR))<(30*SECS_PER_MIN));
override=true;
PWMValue+=2;
override=true;
PWMValue-=4;
if (millis()-lastmillis>nummillis && override)
override=false;
if (!override) PWMValue=OperatingPWM;
if (ReefAngel.WaterLevel.GetLevel(2)>Level+10) PWMValue=MinPWM;
PWMValue=constrain(PWMValue,MinPWM,100);
ReefAngel.PWM.SetActinic(PWMValue);
pumpBool=true;
pumpOff=now();
if (now()-pumpOff < 15*SECS_PER_MIN) {
} else {
pumpBool=false;
if (ReefAngel.WaterLevel.GetLevel(1)<5) //Disable the port until overriden manually
ReefAngel.Relay.Override(Port8,0); //Saltwater Reservoir
if (ReefAngel.WaterLevel.GetLevel(1)>80) // Set port back to auto
ReefAngel.Relay.Override(Port8,2);
if (ReefAngel.WaterLevel.GetLevel(3)>87) //ATO Reservoir
ReefAngel.Relay.Off(Port5);
if (ReefAngel.WaterLevel.GetLevel(3)<1)
ReefAngel.Relay.On(Port5);
ReefAngel.Portal( "Ismaclst" );
Re: DC return pumps
Posted: Fri Nov 25, 2016 11:20 am
by Ismaclst
Thanks, Roberto. It works but just need to change 15 minutes to 15 seconds. How do you code this?
Re: DC return pumps
Posted: Fri Nov 25, 2016 12:52 pm
16*SECS_PER_MIN is equal to 16 * 60 seconds, which means 16 minutes.
If you want 16 seconds, just remove the SECS_PER_MIN, which will be just 16 seconds.
