Page 2 of 2
Re: Dim LEDs with PWM expansion and alternate wavemaker
Posted: Wed Feb 15, 2012 3:01 pm
if you enable wifi athentication, none of the available apps will work.
If you enable the date/time feature, it will use up a lot of memory.
Posted: Wed Feb 15, 2012 3:08 pm
I can compile with the folowing features:
wifi
wdt
custom menu
pwm expansion
version menu
display led pwm
Posted: Wed Feb 15, 2012 5:57 pm
by Aricml
So will the Wifi not work because of the custom code or is there another reason that Wifi will not work? And I can forgo the clouds as long as it's still possible to have alternating wavemakers, and the sunrise/sunset of the LED's, hopefully with ability to set times for actinics (channels 2 and 3) seperate from daylight (channels 0 and 1). Thank you so much for the help!
Posted: Wed Feb 15, 2012 6:16 pm
Yes, wifi is in the feature list I typed above
Posted: Wed Feb 15, 2012 6:30 pm
Posted: Wed Feb 15, 2012 6:32 pm
by Aricml
Oh thank you, I would love to have that code if you could please!
Posted: Wed Feb 15, 2012 6:44 pm
Aricml wrote:Oh thank you, I would love to have that code if you could please!
This is the fixed up internal memory file:
#include <avr/pgmspace.h>
RA_NokiaLCD e;
    e.Init();
    e.BacklightOn();
    InternalMemory.MHOnHour_write(15);
    InternalMemory.MHOnMinute_write(30);
    InternalMemory.MHOffHour_write(21);
    InternalMemory.MHDelay_write(7);
    InternalMemory.StdLightsOnHour_write(14);
    InternalMemory.StdLightsOffHour_write(21);
    InternalMemory.StdLightsOffMinute_write(30);
    InternalMemory.DP1Timer_write(4);
    InternalMemory.DP2Timer_write(4);
    InternalMemory.LEDPWMActinic_write(20);
    InternalMemory.LEDPWMDaylight_write(20);
    InternalMemory.WM1Timer_write(10);
    InternalMemory.WM2Timer_write(15);
    InternalMemory.HeaterTempOn_write(766);
    InternalMemory.HeaterTempOff_write(770);
    InternalMemory.ChillerTempOn_write(774);
    InternalMemory.ChillerTempOff_write(770);
    InternalMemory.PHMax_write(830);
    InternalMemory.PHMin_write(540);
    InternalMemory.RFMode_write(Constant);
    InternalMemory.RFSpeed_write(140);
    InternalMemory.RFDuration_write(8);
    InternalMemory.PWMSlopeStartD_write(15);
    InternalMemory.PWMSlopeEndD_write(100);
    InternalMemory.PWMSlopeDurationD_write(60);
    InternalMemory.PWMSlopeStartA_write(15);
    InternalMemory.PWMSlopeEndA_write(100);
	// display success screen
    e.DrawText(COLOR_BLACK, COLOR_WHITE, MENU_START_COL, MENU_START_ROW*5, "   RA code file");
    delay(5000);
If you are going to be updating your generated memory file, just replace all the existing lines that contain "e.FUNCTION"
Posted: Wed Feb 15, 2012 6:57 pm
by Aricml
Thanks binder, and rimai, if you could compile that code I would really appreciate it.
