Page 2 of 2
Re: RA cam
Posted: Wed Nov 21, 2012 2:46 pm
by binder
rimai wrote:Does anyone know how to place a component to a webpage to watch your stream?
Is it camera specific?
It probably is camera specific. On my IP camera, you have to grab the stream by looking at the pages it generates. That's how dave displays my ip camera on my network inside his Client Suite.
I created a test page that just embedded the default /wifi page and my camera stream. It worked pretty good for me.
RA cam
Posted: Wed Nov 21, 2012 3:12 pm
Mine either you need the app, java, or active-x. The last two are in an html and finally if none of the above, i can url to a live static image. But i'm sure each has it's own. The best strategy for support would be to give a url to embed and whatever works for each camera can be used.
RA cam
Posted: Wed Nov 21, 2012 7:19 pm
Here's the pics with/without the fisheye lens.
Before:
After:
I'm using the mount that jsclownfish posted and the lens was $20. It really makes a huge difference. One thing though...the lens comes with a magnetic ring with adhesive to hold the lens to the camera. The weight of the lens was causing the ring to shift, so I ended up using some frag glue to secure it to the camera.
Re: RA cam
Posted: Wed Nov 21, 2012 9:15 pm
by jsclownfish
Thanks for the update on the lens. That's pretty cool. I'll have to give it a try.
-Jon
Re: RA cam
Posted: Thu Nov 22, 2012 3:44 am
Yeah, that's really sweet!!!
I'm gonna try it too :)
Thanks for sharing!!!
Re: RA cam
Posted: Sat Mar 09, 2013 6:23 pm
by Redadeath
i have easy n camera and i usually ask to choose activex - java -or app and to sed as default
what king of os does the client suite use
Re: RA cam
Posted: Sun Mar 10, 2013 9:09 am
by binder
Redadeath wrote:i have easy n camera and i usually ask to choose activex - java -or app and to sed as default
the client suite is written for windows.
Re: RA cam
Posted: Sun Mar 24, 2013 12:39 pm
by rossbryant1956
the dlink allows you to just call the outside IP address and the port you previously setup forwarding on (like we did with 2000 for the RA.) Try hitting mine at 69.250.225.122:3462
if it asks for a id and password use "guest" and "fishtanks"
LMK if this works
I am still working with the X10 cameras to get them up from a browser
RA cam
Posted: Sun Mar 24, 2013 12:43 pm
Its working...but it didn't prompt for authentication....
Re: RA cam
Posted: Wed Aug 27, 2014 8:32 pm
by sherman
lnevo wrote:http://www.easte.net:8080
Username is fishcam / No password
I sign in. Only show black screen. Why? Is it the cam is off
Re: RA cam
Posted: Thu Aug 28, 2014 4:16 am
Night time :)
Re: RA cam
Posted: Fri Oct 31, 2014 6:37 am
by Ron Starc
IP Camera Viewer for the pc is a excellent free software to view your IP and USB cameras. The interface is intuitive and it works well with every model of IP & USB camera.
