Page 2 of 3
Re: Wifi attachment commands
Posted: Sun Nov 03, 2013 9:54 am
Thanks!!.
Let me see if it works if I add to the JS.
Posted: Sun Nov 03, 2013 10:01 am
It was already there... It didn't have the min, max and user define, but was there. I added the other ones. Check if it scales now.
On my android, it scales on height, not on width.
Posted: Sun Nov 03, 2013 11:07 am
No change...
I am getting a lot of unable to refresh data and I know everything is working. My other software is loading data ok...
Posted: Sun Nov 03, 2013 11:13 am
Actually it may be worse now.... I cant scale it all now on safari. Not sure what it was like before. I was using chrome in previous tests. Also data loading fine in safari so maybe a chrome issue..
Posted: Sun Nov 03, 2013 11:23 am
Chrome is not scaling now either
...maybe it was cached..
Posted: Sun Nov 03, 2013 12:18 pm
I think it is because of user-scalable=0 that you posted.
I reverted back.
Posted: Sun Nov 03, 2013 12:54 pm
I'll have to see if i can make a dev copy of your js file and see what i can do...
Posted: Sun Nov 03, 2013 2:10 pm
This is what I got:
Viewport argument value "device-width;" for key "width" is invalid, and has been ignored. Note that ';' is not a separator in viewport values. The list should be comma-separated.
My original code had comma and when you posted yours, I changed to semi-colon.
So, I updated once again back with a comma. Can you see if it does it now?
Posted: Sun Nov 03, 2013 2:50 pm
Perfect in safari. Still have issues with Chrome. It doesnt get any data and doesn't default to the right width. Safari is perfect.
Posted: Fri Dec 20, 2013 8:56 am
14-Radion - Blue Channel
15-Radion - Green Channel
These are reversed in practice... When I set the po14,0 it changed the RFG and when I set po15,0 it changed RFB.
A bit off topic but the reason for this discovery... something is changing my RFB and RFI to 100 and I can't figure it out. I have nothing in my code that references the Radion's at all, except that I'm using the Custom mode for the Vortech... I did have 100 in Mem_B_RadionRadionSlopeEndB and Mem_B_RadionRadionSlopeEndI but I corrected that. Then I overrode the channels to 0 and put back to default and it went right back to 100. It's happened a few times and not sure what's triggering it. Any thoughts?
Posted: Fri Dec 20, 2013 9:24 am
Thanks!!
What you are getting is the intended result. It was a mistake on that post. I corrected it.
It has to be something within your code.
It is not the override as you can see it in here:
http://forum.reefangel.com/status/chart ... filter=rfb
Can you open a new thread?
Posted: Fri Dec 20, 2013 9:42 am
I'll start a new thread... just the typo was noticed when I tried to see if the override would help reset it.
Posted: Mon Dec 23, 2013 9:34 pm
what is the usage of the /cal command? can it be used to trigger the calibration modes?
Posted: Tue Dec 24, 2013 3:10 pm
Yes, I updated the OP
Posted: Tue Dec 24, 2013 3:31 pm
rimai wrote:Yes, I updated the OP
awesome. thanks
Posted: Thu Apr 10, 2014 1:45 pm
There is no way to read/write a dword (i.e. InternalMemory.read_dword() / InternalMemory.write_dword() )
Need to ad a /md
Posted: Thu Apr 10, 2014 2:02 pm
Can you add a ticket on github?
Sent from my SPH-L710 using Tapatalk
Posted: Thu Apr 10, 2014 2:18 pm
Yeah, I'll add this and need to add HighATOChannel to DCPump
Posted: Fri Jun 13, 2014 2:55 am
by Hamid2
Posted: Fri Jun 13, 2014 8:43 pm
If you want to know what the schema looks like, then you need to view the code. It's located in the RA_Wifi/RA_Wifi.cpp file. Here's a link to the github location of the file:
https://github.com/reefangel/Libraries/ ... A_Wifi.cpp
Around line 300, there will be a line that says "case REQ_R_STATUS:"
That section shows the the XML code that is generated by those 2 commands.
Posted: Wed Sep 10, 2014 7:55 am
Any way to add a command to clear a bus lock flag? If it's possible I'll open an issue.
Posted: Wed Sep 10, 2014 8:08 am
No, it clears automatically when the problem is resolved
Posted: Sat Jun 25, 2016 9:24 pm
by soyrex
I could be missing something obvious.. but when I call the waterchange mode from the wifi... how do I take the RA out of WC mode? Do I make the same call again to toggle it?
Posted: Sat Jun 25, 2016 9:54 pm
/bp for button press
Posted: Tue Jun 28, 2016 12:41 am
by soyrex
Of course looking at this now - it makes perfect sense. I'm going to blame being tired.
Do you know if there's a way to check if WC or Feed mode are already active?
Posted: Tue Jun 28, 2016 8:47 am
Yes. The SF flag is an 8 bit representation of different modes.
At the moment, we only use the first 3 bits.
// Status Flag Bits
#define LightsOnFlag 0
#define FeedingFlag 1
#define WaterChangeFlag 2
