Re: Cloud Wifi Attachment
Posted: Mon Jun 12, 2017 10:45 am
You mentioned it was working.
Is it not?
Is it not?
https://forum.reefangel.com/
It seems jeelabs has released a couple months ago an alpha version of a firmware that emulates the stk500v2 that is required to program our microcontrollersKungpaoshizi wrote:Can we expect code uploads via the device someday?
I think that's one thing I would really like... Though I have gotten to the point where my reef tank setup is simple enough I don't need to change anything... lol
//Sketch Date May 13, 2018
//Version 3.0
#include <SunLocation.h>
#define NUMBERS_8x16
#define PI 3.141593
//#include <RA_PCA9685.h>
//#define I2CPWM_PCA9685 0x40
SunLocation sl;
byte ActinicPWMValue=0;
byte DaylightPWMValue=0;
////// Memory Locations used by all formulas
#define Mem_B_AcclDay 100
// Note - 100 represents the hard coded Memory location used for this variable
// not the value for the variable.
// This variable represents the current day in Acclimation Cycle. Set this value to the same
// number of days as your AcclDuration to begin the acclimation cycle or set it to 0 to use
// your normal dimming end% values.
#define Mem_B_AcclDuration 101 // Set this value to how many days you want your acclimation cycle to take.
#define Mem_B_SlopeStart 102 // Set this to your desired starting acclimation end%.
/////// Memory Locations used by Blue Formula
#define Mem_B_AcclStartEndBlue 105 // Acclimation starting Slope end%
#define Mem_B_SlopeEndBlue 106 // slope End%
////// Memory Locations used by White Formula
#define Mem_B_AcclStartEndWhite 110 // Acclimation starting Slope end%
#define Mem_B_SlopeEndWhite 111 // Slope End%
// Define Portal Variables
#define Var_AcclDay 0 // Days Left in Coral Acclimation
//#define Var_StormMode 1 // Lightning Storm Mode: 0=Slow (For Unresponsive LED Drivers: Meanwell ELN), 1=Fast, 2=Mega
//#define Var_Wmaker 2
//#define Var_Tide 3
//#define Var_TideMode 4
//#define Var_LogATO 5
//#define Var_WCVol 6
#define Var_weekday 7 //Day of the week: 0=Sunday, 1=Monday, 2=Tuesday, 3=Wednsday, 4=Thursday, 5=Friday, 6=Saturday
void DrawCustomMain() { //5,14
char buf[16];
//byte acclDay = InternalMemory.read(Mem_B_AcclDay);
ReefAngel.LCD.DrawLargeText(COLOR_BLACK, COLOR_WHITE, 10, 4, "Paradise Reef");
// Temp and PH
ReefAngel.LCD.DrawText(COLOR_BLACK,DefaultBGColor,10,65,"Temp:");
ReefAngel.LCD.DrawText(COLOR_BLACK,DefaultBGColor,85, 65, "PH:");
ConvertNumToString(buf, ReefAngel.Params.Temp[T2_PROBE], 10);
ReefAngel.LCD.DrawText(T2TempColor, DefaultBGColor, 48, 73, buf);
ReefAngel.LCD.DrawLargeText(T1TempColor, DefaultBGColor, 10, 75, buf, Num8x16);
ReefAngel.LCD.DrawLargeText(PHColor, DefaultBGColor, 85, 75, buf, Num8x16);
ConvertNumToString(buf, ReefAngel.Params.Temp[T3_PROBE], 10);
ReefAngel.LCD.DrawText(T3TempColor, DefaultBGColor, 48, 82, buf);
//ATO
/*ReefAngel.LCD.DrawLargeText(COLOR_INDIGO,DefaultBGColor,15,40,"High",Font8x16);
ReefAngel.LCD.DrawLargeText(COLOR_INDIGO,DefaultBGColor,85,40,"Low",Font8x16);
ReefAngel.LCD.FillCircle(55,43,5,COLOR_GREEN);
} else {
ReefAngel.LCD.FillCircle(55,43,5,COLOR_RED);
ReefAngel.LCD.FillCircle(70,43,5,COLOR_GREEN);
} else {
ReefAngel.LCD.FillCircle(70,43,5,COLOR_RED);
//Salinity
strcat(text," ");
ReefAngel.LCD.DrawText(DefaultFGColor,DefaultBGColor,15,93,"Salinity:");
ReefAngel.LCD.DrawText(COLOR_NAVY,DefaultBGColor,75,93,text);
//Sunrise/Sunset Times
//ReefAngel.LCD.DrawText(0,255,5,52,"Rise:");
//ReefAngel.LCD.DrawText(0,255,38,52,(sl.GetRiseHour()));
//ReefAngel.LCD.DrawText(0,255,43,52,":");
//ReefAngel.LCD.DrawText(0,255,48,52,(sl.GetRiseMinute()));
//ReefAngel.LCD.DrawText(0,255,65,52,"Set:");
//ReefAngel.LCD.DrawText(0,255,88,52,(sl.GetSetHour()));
//ReefAngel.LCD.DrawText(0,255,100,52,":");
//ReefAngel.LCD.DrawText(0,255,105,52,(sl.GetSetMinute()));
//Moon Phase
//ReefAngel.LCD.DrawText(0,255,5,72,"Moon:");
//ReefAngel.LCD.DrawText(0,255,35,72,MoonPhaseLabel());
// Display Acclimation timer
//ReefAngel.LCD.DrawText(0,255,5,82,"Acclimation Day:");
//ReefAngel.LCD.DrawText(0,255,105,82,acclDay);
// Display LED %
//ReefAngel.LCD.DrawText(0,255,12,92, "CW:");
//ReefAngel.LCD.DrawText(197,255,32,92, ReefAngel.PWM.GetDaylightValue());
//ReefAngel.LCD.DrawText(0,255,72,92, "RB:");
//ReefAngel.LCD.DrawText(3,255,92,92, ReefAngel.PWM.GetActinicValue());
// Display Relays
ReefAngel.LCD.DrawOutletBox(12, 102, TempRelay);
ReefAngel.LCD.DrawGraph(5, 12);
/*void SeasonalTemps ()
static int heatArray[][2] = { {792,796},// default in case of error in month=0 (June)
{770,774},//January (winter)
{774,778},//February (winter)
{775,779},//March (early spring)
{779,783},//April (spring)
{785,789},//May (spring)
{792,796},//June (early summer)
{799,803},//July (summer)
{806,810},//August (summer)
{796,800},//September (early fall)
{787,791},//October (fall)
{780,784},//November (fall)
{775,779} };//December (early winter)
ReefAngel.StandardHeater( Port2,heatArray[month()][0],heatArray[month()][1]);
//ReefAngel.Use2014Screen(); // Let's use 2014 Screen
ReefAngel.AddSalinityExpansion();
// Default Salinity compensation
ReefAngel.Salinity.SetCompensation(0);
ReefAngel.FeedingModePorts = Port3Bit| Port5Bit | Port6Bit ;
ReefAngel.WaterChangePorts = Port2Bit | Port3Bit | Port5Bit | Port6Bit;
ReefAngel.LightsOnPorts = Port7Bit | Port8Bit;
ReefAngel.Relay.On( Port2 );
ReefAngel.Relay.On( Port3 );
ReefAngel.Relay.On( Port4 );
ReefAngel.Relay.On( Port5 );
ReefAngel.Relay.On( Port7 );
//sl.Init(-21.285833, 150.999722); // In decimal numbers (i.e. -18.285833, 147.699722)
//sl.SetOffset(11,0,11,0); // rise_hour, rise_seconds, set_hour, set_seconds
sl.Init(38.8447,-104.8433); // Colorado Springs,CO In decimal numbers (i.e. -18.285833, 147.699722)
sl.SetOffset(-6,0,-6,0); // rise_hour, rise_seconds, set_hour, set_seconds
randomSeed(now()/SECS_PER_DAY);
//if (InternalMemory.read(Mem_B_ResetMemory))
//init_memory();
//Temp Code for Fuge Light
//ReefAngel.StandardLights( Port5,sl.GetSetHour(),sl.GetSetMinute(),sl.GetRiseHour(),sl.GetRiseMinute() );
//ReefAngel.StandardLights( Port7,sl.GetSetHour(),sl.GetSetMinute(),sl.GetRiseHour(),sl.GetRiseMinute() );
// 15min Delay on Skimmer coming from Feeding oe Waterchange Modes
ReefAngel.Relay.DelayedOn(Port3, 10);
// Custom Variable for Portal
ReefAngel.CustomVar[Var_weekday]=weekday();
//Heater
//SeasonalTemps();
// Jebao Code
pinMode(lowATOPin,OUTPUT);
analogWrite(lowATOPin,ReefCrestMode(50,20,true)*2.55);
ReefAngel.DCPump.LowATOChannel = AntiSync ; // Jebo connected to AtoPINLow
pinMode(highATOPin,OUTPUT);
analogWrite(highATOPin,ReefCrestMode(50,20,true)*2.55);
ReefAngel.DCPump.HighATOChannel = AntiSync ; // Jebo connected to AtoPINLow
static int rmode;
byte modes[] = { Lagoon, ReefCrest, TidalSwell, Sine, Gyre, NutrientTransport, Else };
changeMode=true;
static unsigned long feeding;
if (now()-feeding<900) {
// First 15 minutes after feeding mode stops. Smart_NTM
} else if (now()-feeding<2250) { // 15 minutes plus 1 hour
// Continue NTM for the next 60 minutes (75 minutes total)
} else if (now()%SECS_PER_DAY<23400 || now()%SECS_PER_DAY>=72000) { // 6:30am / 8:00pm
// Night mode (go to 30%)
ReefAngel.DCPump.Speed=32;
//ReefAngel.DCPump.SetMode(Constant,31,45,30);
if (modes[rmode]==Else) {
ReefAngel.DCPump.Speed=ElseMode(InternalMemory.DCPumpSpeed_read(),25,true ); // ElseMode on sync mode, Portal Speed Setting +/- 25%
} else {
} else {
////////// Variables used for all channels
// What day in the acclimation cycle it is
byte acclDuration = InternalMemory.read(Mem_B_AcclDuration);
// Acclimation Duration in days
byte startPercent = InternalMemory.read(Mem_B_SlopeStart);
// Normal start% being used by all 3 channels
////////// Blue Channel Variables
byte acclStartEndBlue = InternalMemory.read(Mem_B_AcclStartEndBlue);
// Starting End% for Acclimation cycle
float acclendPercentBlue = InternalMemory.read(Mem_B_SlopeEndBlue);
// Your target Blue end% once acclimation is complete
////////// Blue Channel Formula
float acclPercentPerDayBlue = (acclendPercentBlue - acclStartEndBlue) / acclDuration;
// How much your Blue end% rises per acclimation day
float acclFactorBlue = acclDay * acclPercentPerDayBlue;
// endPercentBlue will be offset by this much. If acclDay = 0 then this value will be 0
byte endPercentBlue = acclendPercentBlue - acclFactorBlue;
// Your final Blue end% for the day
////////// White Channel Variables
byte acclStartEndWhite = InternalMemory.read(Mem_B_AcclStartEndWhite);
float acclEndPercentWhite = InternalMemory.read(Mem_B_SlopeEndWhite);
// Your target White end% once acclimation is complete
////////// White Channel Formula
float acclPercentPerDayWhite= (acclEndPercentWhite - acclStartEndWhite) / acclDuration;
// How much your White end% rises per acclimation day
float acclFactorWhite = acclDay * acclPercentPerDayWhite;
// endPercentWhite will be offset by this much. If acclDay = 0 then this value will be 0
byte endPercentWhite = acclEndPercentWhite - acclFactorWhite;
ReefAngel.CustomVar[Var_AcclDay]=acclDay;
// At the end of the day, we need to decrement the acclimation counter.
static boolean acclCounterReady=false; // We need a boolean so we only do this once per day
if (now()%SECS_PER_DAY!=0) acclCounterReady=true; // If it's not midnight we'll get the boolean ready
if (now()%SECS_PER_DAY==0 && acclCounterReady && acclDay>0) { // It's midnight, our bool is true and acclDay is more than 0
acclDay--; // Reduce the counter
acclCounterReady=false; // Reset the boolean flag
InternalMemory.write(Mem_B_AcclDay,acclDay); // Update memory
// handle updating sunrise and sunset values
sl.CheckAndUpdate();
//ReefAngel.Portal( "89delta","collin1123" );
//ReefAngel.DDNS( "bc29" ); // Your DDNS is 89delta-bc29.myreefangel.com
ReefAngel.CloudPortal();
ActinicPWMValue=PWMSlope(sl.GetRiseHour(),sl.GetRiseMinute(),sl.GetSetHour(),sl.GetSetMinute(),startPercent,endPercentBlue,120,(MoonPhase()/3));
DaylightPWMValue=PWMSlope(sl.GetRiseHour(),sl.GetRiseMinute(),sl.GetSetHour(),sl.GetSetMinute(),startPercent,endPercentWhite,120,DaylightPWMValue);
CheckCloud();
// RA_STRING1=U2FsdGVkX19/CQXYxFHutorfRImY8TNubevs+8+6Sjw=
// RA_STRING2=U2FsdGVkX1+7EBoxpKZdEtYXEBfHD+fIe5qrAeDKTa8=
// RA_STRING3=Gundel
void CheckCloud()
#define Clouds_Every_X_Days 1
#define Cloud_Chance_per_Day 50
#define Min_Cloud_Duration 6
#define Max_Cloud_Duration 15
#define Min_Clouds_per_Day 3
#define Max_Clouds_per_Day 10
#define Start_Cloud_After NumMins(7,30)
#define End_Cloud_Before NumMins(20,00)
#define Lightning_Change_per_Cloud 55
// Add Random Lightning modes
#define Slow 0 // 5 seconds of slow lightning in the middle of a cloud for ELN style (slow response) drivers
#define Fast 1 // 5 seconds of fast lightning in the middle of a cloud for LDD style (fast response) drivers
#define Mega 2 // Lightning throughout the cloud, higher chance as it gets darker
#define Mega2 3 // Like Mega, but with more lightning
// Example: { Slow, Fast, Mega, Mega2 } to randomize all four modes.
// { Mega2 } for just Mega2. { Mega, Mega, Fast} for Mega and Fast, with twice the chance of Mega.
byte LightningModes[] = { Fast, Mega, Mega2 };
//ReefAngel.CustomVar[Var_StormMode]=lightningMode;
static byte cloudchance=255;
static byte cloudduration=0;
static int cloudstart=0;
static byte numclouds=0;
static byte cloudindex=0;
static int LastNumMins=0;
static byte lightningMode=0;
#ifdef forcecloudcalculation
if (cloudchance==255)
#else
#endif
cloudchance=random(100);
// If we have cloud today
if (cloudchance)
lightningchance=random(100);
if (cloudchance)
//is it time for cloud yet?
if (chooseLightning) { lightningMode=LightningModes[random(100)%sizeof(LightningModes)]; chooseLightning=false; }
switch (lightningMode) {
case Mega:
// Lightning chance from beginning of cloud through the end. Chance increases with darkness of cloud.
int a=random(1,5); // Pick a number of consecutive flashes from 1 to 4.
for (int i=0; i<a; i++)
analogWrite(daylightPWMPin,random(DaylightPWMValue*2.55,255)); // Flash on
int randy=random(20,80); // Random number for a delay
if (randy>71) randy=((randy-70)/2)*100; // Small chance of a longer delay
delay(randy); // Wait from 20 to 69 ms, or 100-400 ms
analogWrite(daylightPWMPin,DaylightPWMValue*2.55); // Flash off
delay(random(30,50)); // Wait from 30 to 49 ms
wdt_reset();
break;
case Mega2:
// Higher lightning chance from beginning of cloud through the end. Chance increases with darkness of cloud.
if (lightningchance && random(ReversePWMSlope(cloudstart,cloudstart+cloudduration,100,0,180))<2 && (millis()-DelayCounter)>DelayTime)
wdt_reset();
break;
case Fast:
wdt_reset();
break;
case Slow:
// Slow lightning for 5 seconds in the middle of the cloud. Suitable for slower ELN style drivers
else lightningstatus=0;
if (lightningstatus)
DaylightPWMValue=100;
DaylightPWMValue=0;
delay(1);
break;
default:
break;
} else {
cloudindex++;
if (cloudindex < numclouds)
//ReefAngel.LCD.Clear(255,0,62,132,132);
//ReefAngel.LCD.DrawText(0,255,5,62,"C");
//ReefAngel.LCD.DrawText(0,255,11,62,"00:00");
//ReefAngel.LCD.DrawText(0,255,45,62,"L");
//ReefAngel.LCD.DrawText(0,255,51,62,"00:00");
int x=0;
//ReefAngel.LCD.DrawText(0,255,x,62,(cloudstart/60));
//ReefAngel.LCD.DrawText(0,255,x,62,(cloudstart%60));
//ReefAngel.LCD.DrawText(0,255,90,62,cloudduration);
if (lightningchance)
int x=0;
//ReefAngel.LCD.DrawText(0,255,x,62,((cloudstart+(cloudduration/2))/60));
//ReefAngel.LCD.DrawText(0,255,x,62,((cloudstart+(cloudduration/2))%60));
cstart*=60;
cend*=60;
if (n>cend) return PWMStart;
