Page 3 of 4
Re: Red Sea Max 500
Posted: Mon Dec 24, 2012 8:44 am
by modulok
I just noticed that the moonlights are still on at 10:30am. Without specifying the minute, I changed it to this: if (hour()>=22 || hour()<=9) // Turn Moonlights on/off
rimai wrote:Use this:
if (hour()>=22 || hour()<=10) // Turn Moonlights on/off
ReefAngel.PWM.SetActinic(0);
ReefAngel.PWM.SetDaylight(0);
Red Sea Max 500
Posted: Mon Dec 24, 2012 9:00 am
You could say hour()<10 also if you wanted it to read closer to your preference..either way same result.
Re: Red Sea Max 500
Posted: Mon Dec 24, 2012 12:56 pm
by modulok
Yeah, that looks better. Thanks
Re: Red Sea Max 500
Posted: Wed Dec 26, 2012 3:06 pm
by modulok
Is there a way to detect which moonphase is active? I would like to switch on my stock (non dimmable) LEDs on when the moonphase is Full Moon.
Re: Red Sea Max 500
Posted: Wed Dec 26, 2012 3:23 pm
MoonPhase() returns a value from 0 to 100.
You can do whatever you want with that value.
100 means full moon.
Re: Red Sea Max 500
Posted: Wed Dec 26, 2012 4:14 pm
by modulok
Here is my current Stock LED setup
if (hour()<11) ReefAngel.StandardLights( Box1_Port4,8,0,11,0 ); //RSMLED Morning 8a-11a
else ReefAngel.StandardLights( Box1_Port4,19,0,22,0 ); //RSMLED Evening 7p-10p
Here is the line I added.
if (MoonPhase())>=100) ReefAngel.StandardLights( Box1_Port4,22,0,8,0 ); //RSMLED on for Full Moon
My Head Unit currently says Full Moon for MoonPhaseLabel(), and 69% for ReefAngel.PWM.GetActinicValue() reading. Not sure how I address the MoonPhase() current value.
Re: Red Sea Max 500
Posted: Wed Dec 26, 2012 4:23 pm
Try this:
if (MoonPhase())>50) ReefAngel.StandardLights( Box1_Port4,22,0,8,0 ); //RSMLED on for Full Moon
Re: Red Sea Max 500
Posted: Wed Dec 26, 2012 6:38 pm
by modulok
Yeah I did try a lower value and it didn't help.
Sent from my SGH-I777 using Tapatalk 2
Re: Red Sea Max 500
Posted: Wed Dec 26, 2012 8:03 pm
It will only turn on between 10pm and 8am
Re: Red Sea Max 500
Posted: Wed Dec 26, 2012 8:28 pm
by modulok
While testing I modified the hours so it would work.
Re: Red Sea Max 500
Posted: Wed Dec 26, 2012 9:53 pm
Make sure you are not using Box1_Port4 anywhere else in the code
Re: Red Sea Max 500
Posted: Wed Dec 26, 2012 11:05 pm
by modulok
I've got the MoonPhase line working now with the other 2 lines commented out. Now the PWM is 73%, so I guess in a few nights it will be at 100%? (This will be my first full moon with the controller setup, so I am assuming that's the case.)
Well I would still like to keep the Morning and Evening schedule. Would I need an if / else if / else to have all three lines work?
if (MoonPhase()>=90) ReefAngel.StandardLights( Box1_Port4,22,0,11,0 ); //RSMLED on for Full Moon
else if (hour()<11) ReefAngel.StandardLights( Box1_Port4,8,0,11,0 ); //RSMLED Morning 8a-11a
Re: Red Sea Max 500
Posted: Thu Dec 27, 2012 9:25 am
So, you want the morning/evening schedule everyday and also moonlights when moon>90?
If so, try this:
if (hour()>=8 && hour()<11) ReefAngel.StandardLights( Box1_Port4,8,0,11,0 ); //RSMLED Morning 8a-11a
else if(hour()>=19 && hour()<22) ReefAngel.StandardLights( Box1_Port4,19,0,22,0 ); //RSMLED Evening 7p-10p
else if(hour()>=22 || hour()<8) if (MoonPhase()>=90) ReefAngel.StandardLights( Box1_Port4,22,0,11,0 ); //RSMLED on for Full Moon
Re: Red Sea Max 500
Posted: Thu Dec 27, 2012 12:43 pm
by modulok
ok, great I will test to see if its working properly tonight.
Re: Red Sea Max 500
Posted: Fri Dec 28, 2012 12:47 pm
by modulok
I changed the MoonPhase amount to 76 and tested it...Seemed to work last night and it's off today.
I am a bit confused though. This morning was the full moon, wouldn't the MoonPhase be 100 at that time?
Edit:
I just tested the overheat function. It worked, ports turned off like they should. But when the temperature went below the overheat temp the ports were not reactivated. Is the manual clear overheat our only option? Or is there a function to reactivate the ports?
Re: Red Sea Max 500
Posted: Fri Dec 28, 2012 10:11 pm
by modulok
Ok now moon phase is 72%. So yesterday was the first at 76%.
Re: Red Sea Max 500
Posted: Sat Dec 29, 2012 8:57 pm
by modulok
Are there any negative effects to splicing two dimmable moon lights together? I think one more would give me better coverage.
Red Sea Max 500
Posted: Sat Dec 29, 2012 11:17 pm
I dont think the pwm ports have enough power to drive more than one moonlight module. Roberto can elaborate, but i think you'll need the dimming module to use more.
Re: Red Sea Max 500
Posted: Sun Dec 30, 2012 8:58 am
by modulok
And nothing can be done with the two PWM ports on the 2nd relay? There isn't a way to set those to moonphase too?
Re: Red Sea Max 500
Posted: Sun Dec 30, 2012 10:22 am
Correct.... Only one RA dimmable moonlight can be plugged into the dimming port without some sort of booster.
The 2nd relay box is non-controllable and non-dimmable.
I'm designing a dimmable moonlight module, where you will be able to connect up to 4 dimmable moonlighs and use just a single port. Not yet prototyped... I'm waiting on the PCBs to get here and test it.
Re: Red Sea Max 500
Posted: Sun Dec 30, 2012 10:30 am
by modulok
How come only the main relay can be controlled and dimmed?
Why can't they be addressed in some way? Just doesn't make sense to me that they are rendered useless (except at 100% brightness).
Re: Red Sea Max 500
Posted: Sun Dec 30, 2012 10:35 am
PWM is controlled by the head unit and not by the relay box.
The signals pass through the svga cable to the main relay box, but do not travel through the expansion bus.
The expansion bus is a 4 wire cable (USB), which can only carry VCC, GND, SDA and SCL signals to the expansion modules.
If you wish more dimming channels, there is the dimming expansion module that would give you an additional 6 channels.
Re: Red Sea Max 500
Posted: Sun Dec 30, 2012 10:39 am
Each dimmable channel booster is capable of driving 40mA.
The spec of the dimmable moonlight is 25mA at 12VDC, but shouldn't be that much at a lower 10VDC of the dimming channel.
Putting 2 in each channel would probably max out that channel. You may still be able to drive 2 in each channel though, but that I never tried and you would need to test and make sure you don't drive more than 40mA or you will burn up the booster.
Re: Red Sea Max 500
Posted: Sun Dec 30, 2012 2:17 pm
by modulok
Thanks for the detailed info on the PWM.
Re: Red Sea Max 500
Posted: Tue Jan 01, 2013 11:45 am
by modulok
The RSM moonlights were not shutting off. I had to add an = to the last hour value and it seems to have worked.
Also what about this?
modulok wrote:I just tested the overheat function. It worked, ports turned off like they should. But when the temperature went below the overheat temp the ports were not reactivated. Is the manual clear overheat our only option? Or is there a function to reactivate the ports?
Re: Red Sea Max 500
Posted: Tue Jan 01, 2013 12:05 pm
Overheat and ATO are 2 flags that requires attention from the user....
I would not want it to turn itself back on after an overheat situation.
You shouldn't have an overheat unless there is something wrong and if there is something wrong, wouldn't you want to personally see what is wrong?
You can reset them with the android app or web browser though.
Red Sea Max 500
Posted: Tue Jan 01, 2013 12:17 pm
Whats the method to clear from browser?
Re: Red Sea Max 500
Posted: Tue Jan 01, 2013 1:46 pm
lnevo wrote:Whats the method to clear from browser?
ATO Clear:
Overheat Clear:
Red Sea Max 500
Posted: Tue Jan 01, 2013 1:47 pm
Cool then i can remove my mem trigger based method
Re: Red Sea Max 500
Posted: Tue Jan 01, 2013 4:54 pm
lnevo wrote:Cool then i can remove my mem trigger based method
Awesome. The android app can clear it for you if you want. It's under the Commands page.
