Clouds and display
- DrewPalmer04
Re: Clouds and display
Thanks!!!
- DrewPalmer04
Any progress for passing clouds that is proven working?
Been busy and seems like the rest of the week is off the chart too... sorry
- DrewPalmer04
Cool. I'll mess with it. Let me know of any updates.
Try this:
// Autogenerated file by RAGen (v1.2.2.171), (06/09/2012 20:37)
// RA_060912_2037.ino
//The following features are enabled for this File:
#define VersionMenu
#define DisplayLEDPWM
#define wifi
#define WDT
#define SIMPLE_MENU
byte ActinicPWMValue=0;
byte DaylightPWMValue=0;
byte x = 6;
byte y = 2;
byte t;
char text[7];
ReefAngel.LCD.DrawDate(6, 2);
ReefAngel.LCD.DrawText(0,255,3,17,"Drew Palmer's 75 Reef");
ReefAngel.LCD.DrawText(COLOR_BLACK,255, 6, 90, "--------------------");
ReefAngel.LCD.DrawText(COLOR_BLACK,255, 6, 126, "--------------------");
ReefAngel.LCD.DrawText(COLOR_BLACK,255, 2, 93, "|");
ReefAngel.LCD.DrawText(COLOR_BLACK,255, 2, 103, "|");
ReefAngel.LCD.DrawText(COLOR_BLACK,255, 2, 113, "|");
ReefAngel.LCD.DrawText(COLOR_BLACK,255, 2, 123, "|");
ReefAngel.LCD.DrawText(COLOR_BLACK,255, 126, 93, "|");
ReefAngel.LCD.DrawText(COLOR_BLACK,255, 126, 103, "|");
ReefAngel.LCD.DrawText(COLOR_BLACK,255, 126, 113, "|");
ReefAngel.LCD.DrawText(COLOR_BLACK,255, 126, 123, "|");
ReefAngel.LCD.DrawText(0,255,10,30,"Display");
ConvertNumToString(text, ReefAngel.Params.Temp[T3_PROBE], 10);
ReefAngel.LCD.DrawText(COLOR_BLACK, 255, 10, 40, text);
ReefAngel.LCD.DrawText(0,255,8,68,"Room");
ReefAngel.LCD.DrawSingleMonitor(ReefAngel.Params.Temp[T2_PROBE], COLOR_BLACK, 40, 68, 10);
ReefAngel.LCD.DrawText(0,255,70,68,"Light");
ReefAngel.LCD.DrawSingleMonitor(ReefAngel.Params.Temp[T1_PROBE], COLOR_BLACK, 99, 68, 10);
ReefAngel.LCD.DrawText(COLOR_BLACK, 255, 95, 40, text);
ReefAngel.LCD.DrawOutletBox(12, 77, TempRelay);
ReefAngel.LCD.DrawText(0,255,8,100, "CWLED");
ReefAngel.LCD.DrawText(COLOR_BLACK,255,15,119, ReefAngel.PWM.GetDaylightValue());
ReefAngel.LCD.DrawText(0,255,88,100, "RBLED");
ReefAngel.LCD.DrawText(COLOR_BLACK,255,95,119, ReefAngel.PWM.GetActinicValue());
ReefAngel.LCD.DrawText(0,255,48,100, "Cloud");
ReefAngel.LCD.DrawText(0,255,41,108, "Duration");
byte wc_status=0;
// 0 - Draining
// 1 - Filling up
// 2 - Finish
ReefAngel.WaterChangePorts = Port4Bit | Port6Bit | Port8Bit | Port5Bit;
ReefAngel.OverheatShutoffPorts = Port5Bit | Port6Bit | Port7Bit;
InternalMemory.OverheatTemp_write( 860 );
ReefAngel.PHMin=830; // 830=PH10.0
ReefAngel.PHMin=480; // 480=PH7.0
ReefAngel.Relay.On(Port6);
ReefAngel.Relay.On(Port5); //Heater
//ReefAngel.AddWifi();
//water change ATO
if (ReefAngel.DisplayedMenu==WATERCHANGE_MODE)
ReefAngel.LCD.DrawOutletBox(10, 100, TempRelay);
switch (wc_status)
case 0:
ReefAngel.Relay.On(1);
if (ReefAngel.LowATO.IsActive()) wc_status++;
break;
case 1:
ReefAngel.Relay.Off(1);
ReefAngel.Relay.On(3);
if (!ReefAngel.HighATO.IsActive()) wc_status++;
break;
case 2:
ReefAngel.Relay.Off(3);
wc_status=0;
ButtonPress++;
//end water change
ActinicPWMValue=PWMParabola(6,5,21,0,0,85,0);//85%
DaylightPWMValue=PWMParabola(7,5,19,0,0,80,0);//80%
CheckCloud();
//ReefAngel.StandardHeater( Port4,740,770 );
//Loop Lights & Fan
ReefAngel.StandardLights(Port7,6,30,20,30);//On LED light FAN
ReefAngel.StandardLights(Port2,19,15,6,30);//Fug Light
ReefAngel.Relay.DelayedOn( Port4,5);
ReefAngel.Relay.DelayedOn( Port8,5);
void CheckCloud()
#define Clouds_Every_X_Days 1
#define Min_Cloud_Duration 7
#define Max_Cloud_Duration 15
#define Min_Clouds_per_Day 2
#define Max_Clouds_per_Day 4
// In this example, start could after 10:30am
#define Start_Cloud_After NumMins(10,30)
// In this example, end could before 5:30pm
#define End_Cloud_Before NumMins(17,30)
#define Lightning_Change_per_Cloud 0
// Which could mean 250 minutes of clouds. We need to make sure the PWMSlope can accomodate 250 minutes of effects or unforseen resul
// could happen.
// In our example, we have 510 minutes between Start_Cloud_After and End_Cloud_Before, so double the 250 minutes (or 500 minutes) can
// fit in that 510 minutes window.
#define cloudrampduration 10
static byte cloudchance=255;
static long cloudduration=0;
static long cloudstart=0;
static byte numclouds=0;
static byte cloudindex=0;
static int LastNumMins=0;
#ifdef forcecloudcalculation
if (cloudchance==255)
#else
#endif
cloudchance=random(100);
// If we have cloud today
if (cloudchance)
lightningchance=random(100);
if (cloudchance)
//is it time for cloud yet?
DaylightPWMValue=ReversePWMSlope(cloudstart,cloudstart+cloudduration,DaylightPWMValue,10,cloudrampduration);
if (elapsedSecsToday(now())>=((cloudstart*60)+10) && elapsedSecsToday(now())<((cloudstart*60)+(cloudduration*60)-10))
boolean static passingcloud=false;
unsigned long static passingcloudstart=millis();
if (!passingcloud && random(10000)<10)
passingcloud=true;
if (passingcloud)
unsigned long d;
unsigned long mpassingcloudstart=millis()-passingcloudstart;
if (mpassingcloudstart<9000)
d=10+(mpassingcloudstart/100);
if (mpassingcloudstart>9000 && mpassingcloudstart<18000)
d=100-((mpassingcloudstart-9000)/100);
if (mpassingcloudstart>18000)
d=10;
passingcloud=false;
DaylightPWMValue=d;
else lightningstatus=0;
if (lightningstatus)
DaylightPWMValue=100;
ActinicPWMValue=100;
DaylightPWMValue=0;
ActinicPWMValue=0;
delay(1);
cloudindex++;
if (cloudindex < numclouds)
ReefAngel.LCD.DrawText(0,255,48,47,"Cloud");
ReefAngel.LCD.DrawText(0,255,48,57,"00:00");
//ReefAngel.LCD.DrawText(0,255,45,120,"L");
//ReefAngel.LCD.DrawText(0,255,51,120,"00:00");
int x=0;
if ((cloudstart/60)>=10) x=48;
else x=54;
ReefAngel.LCD.DrawText(0,255,x,57,(cloudstart/60));
if ((cloudstart%60)>=10) x=66;
else x=72;
ReefAngel.LCD.DrawText(0,255,x,57,(cloudstart%60));
ReefAngel.LCD.DrawText(0,255,56,119,cloudduration);
if (lightningchance)
int x=0;
else x=57;
ReefAngel.LCD.DrawText(0,255,x,115,((cloudstart+(cloudduration/2))/60));
else x=75;
ReefAngel.LCD.DrawText(0,255,x,115,((cloudstart+(cloudduration/2))%60));
cstart*=60;
cend*=60;
if (n>cend) return PWMStart;
- DrewPalmer04
Thanks!!! I'll try it today!
- DrewPalmer04
Works great. How do I increase the ramp time. It makes passing clouds but very slowly.
This is the piece that increases and decreases the %:
It does 9 seconds ramp up and 9 seconds ramp down
d=10;
passingcloud=false;
- DrewPalmer04
That's perfect but the frequency of when It ramps 9 secs up and down is very spread out.
This is what calculates it:
- DrewPalmer04
Sweet. Thanks!
