Page 3 of 3
Re: Clouds and display
Posted: Sat Dec 08, 2012 6:25 pm
by DrewPalmer04
Thanks!!!
Posted: Tue Dec 11, 2012 4:27 pm
by DrewPalmer04
Any progress for passing clouds that is proven working?
Posted: Tue Dec 11, 2012 7:08 pm
Been busy and seems like the rest of the week is off the chart too... sorry :(
Posted: Tue Dec 11, 2012 7:26 pm
by DrewPalmer04
Cool. I'll mess with it. Let me know of any updates.
Posted: Sat Dec 15, 2012 12:29 pm
Try this:
// Autogenerated file by RAGen (v1.2.2.171), (06/09/2012 20:37)
// RA_060912_2037.ino
//The following features are enabled for this File:
#define VersionMenu
#define DisplayLEDPWM
#define wifi
#define WDT
#define SIMPLE_MENU
byte ActinicPWMValue=0;
byte DaylightPWMValue=0;
  byte x = 6;
  byte y = 2;
  byte t;
  char text[7];
  ReefAngel.LCD.DrawDate(6, 2);
  ReefAngel.LCD.DrawText(0,255,3,17,"Drew Palmer's 75 Reef");
  ReefAngel.LCD.DrawText(COLOR_BLACK,255, 6, 90, "--------------------");
  ReefAngel.LCD.DrawText(COLOR_BLACK,255, 6, 126, "--------------------");
  ReefAngel.LCD.DrawText(COLOR_BLACK,255, 2, 93, "|");
  ReefAngel.LCD.DrawText(COLOR_BLACK,255, 2, 103, "|");
  ReefAngel.LCD.DrawText(COLOR_BLACK,255, 2, 113, "|");
  ReefAngel.LCD.DrawText(COLOR_BLACK,255, 2, 123, "|");
  ReefAngel.LCD.DrawText(COLOR_BLACK,255, 126, 93, "|");
  ReefAngel.LCD.DrawText(COLOR_BLACK,255, 126, 103, "|");
  ReefAngel.LCD.DrawText(COLOR_BLACK,255, 126, 113, "|");
  ReefAngel.LCD.DrawText(COLOR_BLACK,255, 126, 123, "|");
  ReefAngel.LCD.DrawText(0,255,10,30,"Display");
  ConvertNumToString(text, ReefAngel.Params.Temp[T3_PROBE], 10);
  ReefAngel.LCD.DrawText(COLOR_BLACK, 255, 10, 40, text);
  ReefAngel.LCD.DrawText(0,255,8,68,"Room");
  ReefAngel.LCD.DrawSingleMonitor(ReefAngel.Params.Temp[T2_PROBE], COLOR_BLACK, 40, 68, 10);
  ReefAngel.LCD.DrawText(0,255,70,68,"Light");
  ReefAngel.LCD.DrawSingleMonitor(ReefAngel.Params.Temp[T1_PROBE], COLOR_BLACK, 99, 68, 10);
  ReefAngel.LCD.DrawText(0,255,100,30,"pH");
  ReefAngel.LCD.DrawText(COLOR_BLACK, 255, 95, 40, text);
  ReefAngel.LCD.DrawOutletBox(12, 77, TempRelay);
  ReefAngel.LCD.DrawText(0,255,8,100, "CWLED");
  ReefAngel.LCD.DrawText(COLOR_BLACK,255,15,119, ReefAngel.PWM.GetDaylightValue());
  ReefAngel.LCD.DrawText(0,255,88,100, "RBLED");
  ReefAngel.LCD.DrawText(COLOR_BLACK,255,95,119, ReefAngel.PWM.GetActinicValue());
  ReefAngel.LCD.DrawText(0,255,48,100, "Cloud");
  ReefAngel.LCD.DrawText(0,255,41,108, "Duration");
byte wc_status=0;
// 0 - Draining
// 1 - Filling up
// 2 - Finish
  ReefAngel.WaterChangePorts = Port4Bit | Port6Bit | Port8Bit | Port5Bit;
  ReefAngel.OverheatShutoffPorts = Port5Bit | Port6Bit | Port7Bit;
  InternalMemory.OverheatTemp_write( 860 );
  ReefAngel.PHMin=830; // 830=PH10.0
  ReefAngel.PHMin=480; // 480=PH7.0
  ReefAngel.Relay.On(Port6);
  ReefAngel.Relay.On(Port5); //Heater
  //ReefAngel.AddWifi();
  //water change ATO
    ReefAngel.LCD.DrawOutletBox(10, 100, TempRelay);
    switch (wc_status)
    case 0:
      ReefAngel.Relay.On(1);
      if (ReefAngel.LowATO.IsActive()) wc_status++;
      break;
    case 1:
      ReefAngel.Relay.Off(1);
      ReefAngel.Relay.On(3);
      if (!ReefAngel.HighATO.IsActive()) wc_status++;
      break;
    case 2:
      ReefAngel.Relay.Off(3);
      wc_status=0;
      ButtonPress++;
  //end water change
  // Calculate your regular sunrise/sunset PWM value
  ActinicPWMValue=PWMParabola(6,5,21,0,0,85,0);//85%
  DaylightPWMValue=PWMParabola(7,5,19,0,0,80,0);//80%
  CheckCloud();
  //ReefAngel.StandardHeater( Port4,740,770 );
  //Loop Lights & Fan
  ReefAngel.StandardLights(Port7,6,30,20,30);//On LED light FAN
  ReefAngel.StandardLights(Port2,19,15,6,30);//Fug Light
  ReefAngel.Relay.DelayedOn( Port4,5);
  ReefAngel.Relay.DelayedOn( Port8,5);
void CheckCloud()
#define Clouds_Every_X_Days 1
#define Min_Cloud_Duration 7
#define Max_Cloud_Duration 15
#define Min_Clouds_per_Day 2
#define Max_Clouds_per_Day 4
  // In this example, start could after 10:30am
#define Start_Cloud_After NumMins(10,30)
  // In this example, end could before 5:30pm
#define End_Cloud_Before NumMins(17,30)
#define Lightning_Change_per_Cloud 0
  // Which could mean 250 minutes of clouds. We need to make sure the PWMSlope can accomodate 250 minutes of effects or unforseen resul
//  could happen.
  // In our example, we have 510 minutes between Start_Cloud_After and End_Cloud_Before, so double the 250 minutes (or 500 minutes) can
//  fit in that 510 minutes window.
#define cloudrampduration  10
  static byte cloudchance=255;
  static long cloudduration=0;
  static long cloudstart=0;
  static byte numclouds=0;
  static byte cloudindex=0;
  static int LastNumMins=0;
#ifdef forcecloudcalculation
  if (cloudchance==255)
#else
#endif
      cloudchance=random(100);
      // If we have cloud today
      if (cloudchance)
        lightningchance=random(100);
  if (cloudchance)
    //is it time for cloud yet?
      DaylightPWMValue=ReversePWMSlope(cloudstart,cloudstart+cloudduration,DaylightPWMValue,10,cloudrampduration);
      if (elapsedSecsToday(now())>=((cloudstart*60)+10) && elapsedSecsToday(now())<((cloudstart*60)+(cloudduration*60)-10))
        boolean static passingcloud=false;
        unsigned long static passingcloudstart=millis();
        if (!passingcloud && random(10000)<10)
          passingcloud=true;
        if (passingcloud)
          unsigned long d;
          unsigned long mpassingcloudstart=millis()-passingcloudstart;
          if (mpassingcloudstart<9000)
            d=10+(mpassingcloudstart/100);
          if (mpassingcloudstart>9000 && mpassingcloudstart<18000)
            d=100-((mpassingcloudstart-9000)/100);
          if (mpassingcloudstart>18000)
            d=10;
            passingcloud=false;
          DaylightPWMValue=d;
          else lightningstatus=0;
          if (lightningstatus)
            DaylightPWMValue=100;
            ActinicPWMValue=100;
            DaylightPWMValue=0;
            ActinicPWMValue=0;
          delay(1);
        cloudindex++;
        if (cloudindex < numclouds)
    ReefAngel.LCD.DrawText(0,255,48,47,"Cloud");
    ReefAngel.LCD.DrawText(0,255,48,57,"00:00");
    //ReefAngel.LCD.DrawText(0,255,45,120,"L");
    //ReefAngel.LCD.DrawText(0,255,51,120,"00:00");
      int x=0;
      if ((cloudstart/60)>=10) x=48;
      else x=54;
      ReefAngel.LCD.DrawText(0,255,x,57,(cloudstart/60));
      if ((cloudstart%60)>=10) x=66;
      else x=72;
      ReefAngel.LCD.DrawText(0,255,x,57,(cloudstart%60));
    ReefAngel.LCD.DrawText(0,255,56,119,cloudduration);
    if (lightningchance)
      int x=0;
      if (((cloudstart+(cloudduration/2))/60)>=10) x=51;
      else x=57;
      ReefAngel.LCD.DrawText(0,255,x,115,((cloudstart+(cloudduration/2))/60));
      if (((cloudstart+(cloudduration/2))%60)>=10) x=69;
      else x=75;
      ReefAngel.LCD.DrawText(0,255,x,115,((cloudstart+(cloudduration/2))%60));
  cstart*=60;
  cend*=60;
  if (n>cend) return PWMStart;
Posted: Sun Dec 16, 2012 9:55 am
by DrewPalmer04
Thanks!!! I'll try it today!
Posted: Wed Dec 26, 2012 11:22 am
by DrewPalmer04
Works great. How do I increase the ramp time. It makes passing clouds but very slowly.
Posted: Wed Dec 26, 2012 11:26 am
This is the piece that increases and decreases the %:
            d=10;
            passingcloud=false;
It does 9 seconds ramp up and 9 seconds ramp down
Posted: Wed Dec 26, 2012 11:34 am
by DrewPalmer04
That's perfect but the frequency of when It ramps 9 secs up and down is very spread out.
Posted: Wed Dec 26, 2012 12:12 pm
This is what calculates it:
Posted: Wed Dec 26, 2012 12:15 pm
by DrewPalmer04
Sweet. Thanks!
