Page 3 of 3
				Re: Preloaded code and change...
				Posted: Wed Mar 06, 2013 3:18 pm
				by baroutas
				I check the driver with AA 1,5 V and 9V batteries and again the same voltage to the led (11,7) V.
				Posted: Wed Mar 06, 2013 3:58 pm
				The voltage won't change.
It needs to be at about what you are seeing or it would go below the forward voltage and you wouldn't have enough voltage to power the LEDs.
What needs to change is the current. As you apply more or less voltage on the dimming input, the average current increases or decreases making it go brighter or darker.
Most people use only one string or 2 max. You are the first one doing it with several strings.
I would suggest you contact the manufacturer of the driver and check with them.
				Posted: Thu Mar 07, 2013 6:22 am
				by baroutas
				I send mail to the Mean Well. We will see..... Thanks!!
				Posted: Sun Mar 10, 2013 12:07 pm
				by baroutas
				Roberto! Today i use controller testter code in my RA and my led dimming normal (sun rise)! BUT... with Wizard code doesn't work why? Is that a bug?
				Posted: Sun Mar 10, 2013 2:35 pm
				Can you post your code?
				Posted: Mon Mar 11, 2013 5:55 am
				by baroutas
    ReefAngel.WaterChangePorts = Port1Bit | Port2Bit | Port7Bit | Port8Bit;
    ReefAngel.OverheatShutoffPorts = Port1Bit;
    InternalMemory.OverheatTemp_write( 350 );
    ReefAngel.Relay.On( Port7 );
    ReefAngel.StandardHeater( Port1,278,280 );
    ReefAngel.StandardFan( Port2,300,310 );
    ReefAngel.StandardLights( Port3,13,50,22,0 );
    ReefAngel.StandardLights( Port4,15,30,19,0 );
    ReefAngel.DosingPumpRepeat( Port5,0,1240,10 );
    ReefAngel.StandardLights( Port6,20,30,23,59 );
    ReefAngel.PWM.SetDaylight( PWMSlope(14,0,21,0,0,100,2,0) );
    ReefAngel.PWM.SetActinic( PWMParabola(20,0,23,59,0,100,0) );
    ReefAngel.Portal( "xxxxxx" );
				Posted: Mon Mar 11, 2013 8:49 am
				This line is telling the controller to go from 0 to 100 in 2 minutes.
Try a longer period like 60 minutes:
ReefAngel.PWM.SetDaylight( PWMSlope(14,0,21,0,0,100,60,0) );
				Posted: Mon Mar 11, 2013 9:48 pm
				by baroutas
				Οκ i try it!
				Posted: Sun Mar 17, 2013 12:06 pm
				by baroutas
				Ιf I by dimming expansion module i will need and dimmable led driver, or the module work like led driver?
				Posted: Sun Mar 17, 2013 12:14 pm
				The ports on the dimming module are just like ap and dp on the relay box...yes you'll need a driver still.
				Posted: Thu Apr 25, 2013 7:38 am
				by baroutas
				Hi again! If  my diming port output voltage are 1-10V (during the port operation) then my RA is analog signal?
And if is 10V (during the port operation) stabilization then my RA is PWM?
				Posted: Thu Apr 25, 2013 7:42 am
				by baroutas
				And something else. Τhe PWM led driver work with analog signal and the opposite??
				Posted: Thu Apr 25, 2013 8:15 am
				http://www.reefangel.com/Product_PWMvsAnalog.aspx
When measured with a standard multimeter, you can't tell which signal you have.
They both show the same voltage. You need a scope to see the signal.
The drivers will work with another signal, but you won't get a very good dimming linearity. It's best to use the correct one.
				Posted: Thu Apr 25, 2013 8:26 am
				by baroutas
				Ok! I understand!!!!Thanks
