Re: My code
Posted: Wed May 01, 2013 5:02 pm
Thank you both. Will try it out.
https://forum.reefangel.com/
oh. cool. didn't know that. I'm on 1.03, haven't updated for awhile...it will still do that?rimai wrote:it does it automatically.
yes it does, just tried it out. very cool!bencollinz wrote:oh. cool. didn't know that. I'm on 1.03, haven't updated for awhile...it will still do that?rimai wrote:it does it automatically.
wow, your code is insane! I tried to pick through it to figure out NTM mode after exiting feeding mode for a set amount of time and just got entirely lost. is there an easier way?lnevo wrote:The only reason I suggest this route is that I like to see my drivers blinking in feeding modeYou could certainly set it in code, but then you lose the nice light show
static unsigned long feeding;
if (ReefAngel.DisplayedMenu==FEEDING_MODE) {
feeding=now();
if (now()-feeding > 1 && now()-feeding < 3600) { // 1 second after feeding mode until 60 minutes after feeding mode.
... // Run your smart_ntm here.
void_loop(){
if (hour() >=8 && hour() < 22)
if (ReefAngel.RF.Mode==Night) ReefAngel.RF.SetMode(Feeding_Stop,0,0);
ReefAngel.RF.UseMemory=true;
feeding=now();
ReefAngel.RF.SetMode(vtMode,vtSpeed,vtDuration);
ReefAngel.Relay.Off(Port8);
ReefAngel.RF.UseMemory=false;
ReefAngel.Relay.On(Port8);
ReefAngel.Portal( "bencollinz" );
}ok, but I want it to function as follows...lnevo wrote:Actually it looks like you got it. The only thing you need to add is to set UseMemory false if you are doing SetMode like that. Otherwise it looks good.
Don't forget to declare the feeding variable...the static unsigned long feeding; statement. It can be inside the loop function, as long as its before the test.
Good work!
void_loop(){
feeding=now();
}testing it now. thank you so so so so much for helping me!lnevo wrote:Yeah exactly.
#include <SoftwareSerial.h>
#define Heater 1
#define Return 2
#define HeaterTk2 3
#define Skimmer 4
#define Vortech1 5
#define Vortech2 6
#define ATO 7
#define Sump Light 8
byte vtechmode, vtSpeed, vtDuration;
ReefAngel.FeedingModePorts = Port2Bit;
// ReefAngel.FeedingModePortsE[0] = 0;
// ReefAngel.WaterChangePorts = Port7Bit | Port4Bit | Port5Bit | Port6Bit;
// ReefAngel.WaterChangePortsE[0] = 0;
// ReefAngel.LightsOnPorts = 0;
// ReefAngel.LightsOnPortsE[0] = 0;
// ReefAngel.OverheatShutoffPortsE[0] = 0;
ReefAngel.AddRANet();
ReefAngel.Relay.On( Port2 );
ReefAngel.Relay.On( Port3 );
ReefAngel.Relay.On( Port4 );
// Hardcode calibrations
ReefAngel.PHMin=576; // PH7.0
ReefAngel.PHMax=842; // PH10.0
ReefAngel.SalMax=3300; // 35ppt
vtechmode=InternalMemory.RFMode_read();
vtSpeed=InternalMemory.RFSpeed_read();
vtDuration=InternalMemory.RFDuration_read();
ReefAngel.StandardHeater( Port1,778,782 );
ReefAngel.WaterLevelATO( Port7,180,71,74 );
ReefAngel.StandardLights( Port8,15,0,2,0 );
ReefAngel.PWM.SetChannel( 0,PWMSlope(19,00,21,00,15,51,20,0) ); //MOON
ReefAngel.PWM.SetChannel( 1,PWMSlope(12,30,20,00,15,50,30,0) ); //RB
ReefAngel.PWM.SetChannel( 2,PWMSlope(12,20,20,00,15,95,30,0) ); //WHITE
ReefAngel.PWM.SetChannel( 3,PWMSlope(12,15,20,00,15,70,30,0) ); //BLUE&CYAN
ReefAngel.PWM.SetChannel( 4,PWMSlope(12,00,20,30,15,70,30,0) ); //UV
if ( ReefAngel.HighATO.IsActive())
ReefAngel.Relay.On(Port2);
ReefAngel.Relay.Off(Port2);
if (hour() >=13 && hour() < 20)
// if (ReefAngel.RF.Mode==Night) ReefAngel.RF.SetMode(Feeding_Stop,0,0);
// ReefAngel.RF.SetMode(ReefCrest,60,20);
feeding=now();
if (now()-feeding<5400) {
// if (now()-feeding > 1 && now()-feeding < 5400) { // 1 second after feeding mode until 60 minutes after feeding mode.
ReefAngel.RF.SetMode(Smart_NTM,75,10);
ReefAngel.RF.SetMode(Constant,10,0);
if (vtechmode!=InternalMemory.RFMode_read())
InternalMemory.RFMode_write(vtechmode);
if (vtSpeed!=InternalMemory.RFSpeed_read())
InternalMemory.RFSpeed_write(vtSpeed);
if (vtDuration!=InternalMemory.RFDuration_read())
InternalMemory.RFDuration_write(vtDuration);
char text[7];
// Date and Time
ReefAngel.LCD.DrawDate( 6, 2 );
ReefAngel.LCD.DrawText(0,255,18,12,"EcoSmart Vortech");
ReefAngel.LCD.Clear(255, 1, 19, 128, 29);
if (vtechmode == 0) ReefAngel.LCD.DrawLargeText(COLOR_LIMEGREEN,255,35,21,"Constant");
else if (vtechmode == 1) ReefAngel.LCD.DrawLargeText(COLOR_GOLD,255,42,21,"Lagoon");
else if (vtechmode == 2) ReefAngel.LCD.DrawLargeText(COLOR_GOLD,255,25,21,"Reef Crest");
else if (vtechmode == 3) ReefAngel.LCD.DrawLargeText(COLOR_CORNFLOWERBLUE,255,22,21,"Short Pulse");
else if (vtechmode == 4) ReefAngel.LCD.DrawLargeText(COLOR_PINK,255,25,21,"Long Pulse");
else if (vtechmode == 5) ReefAngel.LCD.DrawLargeText(COLOR_MAGENTA,255,8,21,"Nutrient Trnsp.");
else if (vtechmode == 6) ReefAngel.LCD.DrawLargeText(COLOR_MAGENTA,255,23,21,"Tidal Swell");
else if (vtechmode == 9) ReefAngel.LCD.DrawLargeText(COLOR_WHITE,0,45,21,"Night");
ReefAngel.LCD.DrawText(0,255,4,30,"RF Speed:");
ReefAngel.LCD.Clear(255,59,29,128,39);
ReefAngel.LCD.DrawText(COLOR_BLUE, DefaultBGColor,71,31,vtSpeed);
ReefAngel.LCD.DrawText(COLOR_BLUE, DefaultBGColor,90,31,"/");
ReefAngel.LCD.DrawText(COLOR_BLUE, DefaultBGColor,100,31,vtDuration);
ReefAngel.LCD.DrawText(0,255,10,40,"Salt");
ReefAngel.LCD.DrawLargeText(COLOR_INDIANRED, 255, 10, 50, text, Num8x8);
/* ReefAngel.LCD.DrawText(0,255,50,40,"Fresh");
ReefAngel.LCD.DrawLargeText(COLOR_INDIANRED, 255, 50, 50, text, Num8x8);
ReefAngel.LCD.DrawText(0,255,100,40,"pH");
ReefAngel.LCD.DrawLargeText(COLOR_PLUM, 255, 85, 50, text, Num8x8);
ReefAngel.LCD.DrawText(0,255,13,58,"Salinity");
ReefAngel.LCD.DrawLargeText(COLOR_LIMEGREEN, 255, 13, 68, text, Num8x8);
// water level
ReefAngel.LCD.DrawText(0,255,68,58,"WL");
ReefAngel.LCD.DrawText( COLOR_CORNFLOWERBLUE,255, 68, 68, ReefAngel.WaterLevel.GetLevel() );
// Main Relay Box
ReefAngel.LCD.DrawOutletBox( 12, 108, TempRelay );
// Relay Expansion
ReefAngel.LCD.DrawOutletBox( 12, 120, TempRelay );
/* void Heater2(byte HeaterRelay, int LowTemp, int HighTemp)
if (ReefAngel.Params.Temp[T2_PROBE] == 0) return; // Don't turn the heater on if the temp is reading 0
if (ReefAngel.Params.Temp[T2_PROBE] <= LowTemp && ReefAngel.Params.Temp[T2_PROBE] > 0) ReefAngel.Relay.On(HeaterRelay); // If sensor 2 temperature <= LowTemp - turn on heater
if (ReefAngel.Params.Temp[T2_PROBE] >= HighTemp) ReefAngel.Relay.Off(HeaterRelay); // If sensor 2 temperature >= HighTemp - turn off heater
void Heater1(byte HeaterRelay, int LowTemp, int HighTemp)
if (ReefAngel.Params.Temp[T1_PROBE] == 0) return; // Don't turn the heater on if the temp is reading 0
if (ReefAngel.Params.Temp[T1_PROBE] <= LowTemp && ReefAngel.Params.Temp[T1_PROBE] > 0) ReefAngel.Relay.On(HeaterRelay); // If sensor 2 temperature <= LowTemp - turn on heater
if (ReefAngel.Params.Temp[T1_PROBE] >= HighTemp) ReefAngel.Relay.Off(HeaterRelay); // If sensor 2 temperature >= HighTemp - turn off heater
*/there's also a bug when it exits feeding mode it changes the vortechs to 100% constant.rimai wrote:I was able to replicate the issue.
It's related to the RANet code indeed.
This will be fixed in the next update.
https://github.com/reefangel/Libraries/issues/202
I confirmed this again after tonight's feeding.bencollinz wrote:there's also a bug when it exits feeding mode it changes the vortechs to 100% constant.rimai wrote:I was able to replicate the issue.
well, in my code after it exists the smart_ntm part of it after 5400 seconds it then changes the vortechs to 100% constant. and again, i need to reboot to fix it.
I commented this outlnevo wrote:I think that's your code doing that. Can you comment out your feeding routine section in full and verify that it exists as a bug.
feeding=now();
{lnevo wrote:There was more that needed commenting. It would make no sense for your ra to put it into any particular mode after the 5400 seconds. Can you post the full code and I'll revert with the correct change.
#define Heater 1
#define Return 2
#define 3
#define Skimmer 4
#define Vortech1 5
#define Vortech2 6
#define ATO 7
// ReefAngel.PHMin=576; // PH7.0
// ReefAngel.PHMax=842; // PH10.0
// ReefAngel.SalMax=3300; // 35ppt
/* if (ReefAngel.DisplayedMenu==FEEDING_MODE)
feeding=now();
// if (now()-feeding > 1 && now()-feeding < 5400) { // 1 second after feeding mode until 90 minutes after feeding mode.
char text[7];
// Date and Time
// water level
// Main Relay Box
// Relay Expansion
*/Code: Select all
#define Heater 1
#define Return 2
#define 3
#define Skimmer 4
#define Vortech1 5
#define Vortech2 6
#define ATO 7
feeding=now();
char text[7];
// Date and Time
// water level
// Main Relay Box
// Relay Expansion
